* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-26 | 1 | -14/+14 |
| | | | | * libnetworking/netinet/ip_var.h: Eliminate __P(). | ||||
* | Remove BYTE_PACK. | Ralf Corsepius | 2005-05-27 | 1 | -8/+7 |
* | 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-12 | 1 | -28/+29 |
| | | | | | * libnetworking/netinet/ip_var.h: Partial update from FreeBSD. Remove some useless BYTE_PACKs. | ||||
* | Define BYTE_PACK. | Ralf Corsepius | 2005-05-12 | 1 | -0/+4 |
* | Use -D_KERNEL instead of -DKERNEL for greater FreeBSD compliance. | Ralf Corsepius | 2004-04-20 | 1 | -2/+2 |
* | 2002-07-17 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-07-17 | 1 | -8/+9 |
| | | | | | * netinet/in.h, netinet/ip.h, netinet/ip_var.h, netinet/tcp.h: Modified to added packed attribute.o | ||||
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+211 |
