* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -1/+0 |
* | Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h. | Ralf Corsepius | 2011-03-02 | 1 | -1/+1 |
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 1 | -0/+4 |
* | Include <errno.h> (POSIX,C99) instead of <sys/errno.h> (BSD'ism). | Ralf Corsepius | 2008-12-22 | 1 | -1/+1 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 1 | -125/+49 |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -17/+17 |
| | | | | * libnetworking/netinet/ip_mroute.c: Eliminate __P(). | ||||
* | 2004-12-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-12-02 | 1 | -0/+1 |
| | | | | | * libnetworking/kern/kern_sysctl.c, libnetworking/netinet/ip_mroute.c, libnetworking/sys/socketvar.h: Remove warnings. | ||||
* | All warnings removed. | Joel Sherrill | 1998-08-21 | 1 | -2/+2 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+2302 |
