* | 2011-02-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-24 | 1 | -7/+13 |
| | | | | | | * libnetworking/netinet/ip_icmp.c, libnetworking/netinet/ip_icmp.h: Misc. changes from FreeBSD. * libnetworking/netinet/tcp_var.h: Include <netinet/tcp_timer.h>. | ||||
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 1 | -0/+4 |
* | Add missing initializers. | Ralf Corsepius | 2008-12-23 | 1 | -3/+3 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 1 | -17/+7 |
* | Further _IP_VHL removal preps. | Ralf Corsepius | 2007-03-29 | 1 | -1/+1 |
* | Preps to eliminate _IP_VHL (Abandoned in FreeBSD). | Ralf Corsepius | 2007-03-29 | 1 | -1/+30 |
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-30 | 1 | -1/+1 |
| | | | | | | | | | | | | | | * libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c, libnetworking/net/ethernet.h, libnetworking/net/if.h, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c, libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c, libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c, libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h, libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove warnings. Most of the warnings were 16/32 bit integer sizing issues. Some constants had L appended, some had casts add, some types were changed to reflect a bit width requirement. | ||||
* | Update icps_allecho counter. | Eric Norum | 2006-05-31 | 1 | -4/+7 |
* | Add flag to inhibit ICMP replies. | Eric Norum | 2006-05-30 | 1 | -3/+8 |
* | Add "ICMP panic avoided" diagnostic counter. | Eric Norum | 2005-05-24 | 1 | -1/+5 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-21 | 1 | -7/+4 |
* | 2005-05-20 Eric Norum <norume@aps.anl.gov> | Joel Sherrill | 2005-05-20 | 1 | -3/+4 |
| | | | | | | PR 793/networking * libnetworking/netinet/ip_icmp.c: Malicious ICMP packet causes panic. Just ignore it. | ||||
* | Partial updates from FreeBSD. | Ralf Corsepius | 2005-04-15 | 1 | -22/+43 |
* | Added debug #define and commented it out. | Joel Sherrill | 1999-02-02 | 1 | -0/+1 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+710 |
