* | 2008-08-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-18 | 1 | -3/+4 |
| | | | | | | | | * libcsupport/include/rtems/libcsupport.h, libcsupport/src/scandir.c, libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-monitor.c, libmisc/serdbg/serdbg.c, libmisc/serdbg/serdbg.h, libnetworking/netinet/in_cksum_powerpc.h, shttpd/compat_rtems.h: Fix warnings. | ||||
* | Added PowerPC specific header checksum code. | Joel Sherrill | 1999-02-04 | 1 | -34/+5 |
* | New file. Based on the i386 version. | Joel Sherrill | 1999-02-02 | 1 | -0/+202 |
