* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -1/+0 |
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 1 | -0/+4 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 1 | -16/+8 |
* | Remove BSD "Add clause" (From FreeBSD). | Ralf Corsepius | 2008-09-01 | 1 | -4/+0 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-28 | 1 | -1/+1 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+479 |
