* libnetworking/net/if.h: Avoid use of struct mbuf to avoid unintended
dependencies added by the RTEMS specific tap interface.
* libnetworking/net/if.h: Revert include of sys/mbuf.h in this .h file
since it causes other problems.
* libnetworking/net/if.h, libnetworking/net/if_ppp.c,
libnetworking/net/ppp_tty.c: Removed warnings.
* libnetworking/kern/kern_sysctl.c, libnetworking/libc/inet_ntop.c,
libnetworking/net/if_ppp.c, libnetworking/net/pppcompress.c,
libnetworking/net/slcompress.c, libnetworking/netinet/ip_output.c,
libnetworking/netinet/udp_usrreq.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_select.c,
libnetworking/rtems/rtems_showifstat.c,
libnetworking/rtems/rtems_showroute.c,
libnetworking/rtems/rtems_syscall.c: Fixed type mismatch and
uninitialized variable warnings.
* libnetworking/net/if.h: Update from FreeBSD.
* libnetworking/net/if_loop.c: Reflect updates.
* libnetworking/net/if_ppp.c: Reflect updates.
* libnetworking/net/if_types.h: Update from FreeBSD.
* libnetworking/net/ethernet.h: Add RTEMS outdated either_input.
* libnetworking/net/if.c: Partial update from FreeBSD.
* libnetworking/net/if_ethersubr.c: Partial update from FreeBSD.
* libnetworking/net/if_var.h: New (extracted from net/if.h).
* libnetworking/Makefile.am: Add net/if_var.h.
* libnetworking/net/rtsock.c: More updates from FreeBSD.
* libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h:
Ansification, cosmetics from FreeBSD.
* libnetworking/net/if_pppvar.h: Ansify.
* libnetworking/net/if_ethersubr.c,
libnetworking/net/radix.h,
libnetworking/netinet/if_ether.h,
libnetworking/netinet/igmp_var.h,
libnetworking/netinet/in_var.h,
libnetworking/netinet/tcp_timer.h,
libnetworking/rtems/rtems_glue.c:
Misc. updates from FreeBSD and bugfixes tripped by GCC-4.0.0.
* libnetworking/net/radix.c, libnetworking/net/radix.h,
libnetworking/net/route.h, libnetworking/netinet/if_ether.h,
libnetworking/netinet/in_var.h, libnetworking/netinet/tcp_timer.h,
libnetworking/netinet/udp_usrreq.c, libnetworking/netinet/udp_var.h,
libnetworking/sys/callout.h, libnetworking/sys/socketvar.h,
libnetworking/sys/sysctl.h: Cosmetics from FreeBSD.
* libnetworking/Makefile.am: Reflect changes below.
* libnetworking/net/slcompress.h: New (from FreeBSD).
* libnetworking/net/slcompress.c: New (from FreeBSD).
* libnetworking/opt_atalk.h, libnetworking/opt_bdg.h,
libnetworking/opt_inet.h, libnetworking/opt_inet6.h,
libnetworking/opt_ipx.h, libnetworking/opt_mac.h,
libnetworking/opt_netgraph.h: New (Stubs).
* libnetworking/net/if_loop.c: Cosmetical update from FreeBSD.
* libnetworking/net/if_ethersubr.c: Update from FreeBSD.
* libnetworking/net/ethernet.h: Remove BYTE_PACK.
* libnetworking/net/ethernet.h: Update from FreeBSD.
* libnetworking/net/if_ethersubr.c: Cosmetical updates from FreeBSD.
Add ether_sprintf.
* libnetworking/net/if.h; Cosmetical updates from FreeBSD.
Remove if_poll* (Not implemented in RTEMS, abandoned by FreeBSD).
* libnetworking/net/route.c: Reflect changes to radix.h.
* libnetworking/net/radix.h, libnetworking/net/radix.c: Partial
* libnetworking/net/bpf.h: Partial update from FreeBSD.
* libnetworking/lib/ftpfs.c, libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/lib/tftpDriver.c, libnetworking/machine/endian.h,
libnetworking/net/if_ppp.c, libnetworking/rtems/rtems_bsdnet.h,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/rtems/rtems_glue.c,
libnetworking/rtems/rtems_syscall.c: Convert to using c99 fixed size
types.
* libnetworking/net/radix.c: Remove warning.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
PR pppd/564
* libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/ppp_tty.c: ppp0 Interface lose packets if the
system use a slow baudrate for the modem or the tcp/ip-packet is
fragmented.
PR 481/networking
* net/ethernet.h, net/if_arp.h, netinet/if_ether.h: Network structs
should be packed
