* | networking: alignment exception in ioctl(SIOCGIFCONF) | Till Straumann | 2015-02-23 | 1 | -11/+12 |
| | | | | | Access memory using a byte stream when copying to avoid unaligned access. update #1401 | ||||
* | ppp: PR1943: Avoid NULL pointer access | Sebastian Huber | 2014-10-08 | 1 | -8/+2 |
| | | | | | | | Waiting for mbufs at this level is a bad solution. It would be better to try to allocate a new mbuf chain before we hand over the current mbuf chain to the upper layer. In case the allocation fails we should drop the current packet and use its mbuf chain for a new packet. | ||||
* | ppp: Add ppp_unit() | Sebastian Huber | 2014-10-08 | 1 | -15/+21 |
| | | | | This makes porting to the new network stack easier. | ||||
* | ppp: Nothing to transmit hint for Termios driver | Sebastian Huber | 2014-10-07 | 1 | -1/+10 |
* | termios: Partially hide rtems_termios_tty | Sebastian Huber | 2014-10-07 | 2 | -3/+4 |
| | | | | | | | Move interrupt lock to device context and expose only this structure to the read, write and set attributes device handler. This makes these device handler independent of the general Termios infrastructure suitable for direct use in printk() support. | ||||
* | pppd: Fix warnings | Sebastian Huber | 2014-09-30 | 1 | -1/+11 |
* | libnetworking: Update due to Termios changes | Sebastian Huber | 2014-09-30 | 2 | -3/+3 |
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 1 | -1/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 23 | -66/+0 |
* | 2011-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-20 | 1 | -4/+1 |
| | | | | | * libnetworking/net/if_ethersubr.c (ether_output): Remove unused vars "hlen", "off". | ||||
* | Make self-contained. | Ralf Corsepius | 2011-05-11 | 7 | -4/+25 |
* | Include <sys/cdefs.h> (Eliminate rtems/bsd/sys/cdefs.h). | Ralf Corsepius | 2011-03-24 | 3 | -3/+3 |
* | Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h. | Ralf Corsepius | 2011-03-02 | 9 | -9/+9 |
* | 2011-02-25 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-25 | 1 | -2/+6 |
| | | | | | | | * libnetworking/rtems/rtems_mii_ioctl_kern.c: Do not use IFM_ACTIVE and IFM_AVALID in the media word. * libnetworking/net/if_media.h: Hack to get libbsdport interface drivers working. | ||||
* | 2011-02-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-23 | 1 | -0/+14 |
| | | | | | * libnetworking/net/if_pppvar.h: Add "extern C++" guards. Add header guard. | ||||
* | 2010-12-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-08 | 1 | -3/+1 |
| | | | | | | | * libnetworking/loop.h, libnetworking/net/if_loop.c, libnetworking/rtems/rtems_glue.c, libmisc/dummy/dummy-networking.c: Initialize loop back interface during normal initialization via rtems_bsdnet_initialize_network(). | ||||
* | 2010-05-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-29 | 1 | -1/+1 |
| | | | | | * libnetworking/net/if.c: Use uintptr_t and void* in _offsetof(). | ||||
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 11 | -0/+44 |
* | 2009-10-20 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-20 | 1 | -1/+1 |
| | | | | | | PR1424/networking * libnetworking/net/rtsock.c: (merged from BSD) copy information out to user buffer. | ||||
* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 1 | -1/+1 |
| | | | | | * libnetworking/net/ppp_tty.c: Reflect termios_baud_to_number having been renamed to rtems_termios_baud_to_number. | ||||
* | Remove PSEUDO_SET (Unused). | Ralf Corsepius | 2009-02-11 | 1 | -2/+1 |
* | Eliminate pppattach, pppintr (Unused). | Ralf Corsepius | 2009-02-04 | 1 | -4/+0 |
* | Eliminate pppintr (Unused). | Ralf Corsepius | 2009-02-04 | 1 | -8/+0 |
* | Add missing initializers. | Ralf Corsepius | 2008-12-22 | 1 | -6/+8 |
* | Include <errno.h> (POSIX,C99) instead of <sys/errno.h> (BSD'ism). | Ralf Corsepius | 2008-12-22 | 5 | -5/+5 |
* | Include <sys/socket.h> to make header self contained. | Ralf Corsepius | 2008-12-11 | 2 | -0/+3 |
* | #include <stdint.h> instead of <rtems/stdint.h>. | Ralf Corsepius | 2008-12-11 | 2 | -4/+2 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 10 | -203/+78 |
* | 2008-08-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-18 | 1 | -1/+0 |
| | | | | | * libnetworking/net/ppp_tty.c: Remove bogus local decl of termios_baud_to_number(int). | ||||
* | Bugfix: Moved definition of ppp_softc into source file. | Thomas Doerfler | 2008-05-27 | 2 | -2/+2 |
* | Add if_nameindex etc. (from FreeBSD). | Ralf Corsepius | 2007-10-04 | 1 | -0/+13 |
* | 2007-09-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-09-16 | 1 | -1/+3 |
| | | | | | * libnetworking/net/ppp_defs.h: Include rtems/stdint.h. Use uint32_t for ext_accm. | ||||
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 3 | -3/+3 |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 5 | -5/+5 |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 4 | -4/+4 |
* | Include <rtems/stdint.h> instead of <stdint.h>. | Ralf Corsepius | 2007-05-09 | 1 | -1/+1 |
* | Remove (Unused) | Ralf Corsepius | 2007-03-30 | 2 | -1800/+0 |
* | 2007-03-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-29 | 1 | -15/+6 |
| | | | | * libnetworking/net/netisr.h: Partial update from FreeBSD. | ||||
* | Remove (Unused). | Ralf Corsepius | 2007-03-28 | 1 | -5/+0 |
* | Use net/slcompress.h instead of net/pppcompress.h. | Ralf Corsepius | 2007-03-28 | 2 | -8/+8 |
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2007-03-28 | 1 | -1/+1 |
* | Remove (Abandoned in FreeBSD). | Ralf Corsepius | 2007-03-28 | 2 | -758/+0 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-28 | 1 | -6/+6 |
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2007-03-28 | 1 | -24/+29 |
* | Update from FreeBSD. | Ralf Corsepius | 2007-03-28 | 1 | -22/+22 |
* | Include <net/ppp_comp.h>. Warn about using it. | Ralf Corsepius | 2007-03-27 | 1 | -165/+2 |
* | 2007-03-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -0/+168 |
| | | | | * libnetworking/net/ppp_comp.h: New (copy of ppp-comp.h). | ||||
* | 2007-03-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -19/+22 |
| | | | | | * libnetworking/net/ppp-comp.h: Eliminate __P(). Cosmetics from FreeBSD. | ||||
* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -13/+22 |
| | | | | * libnetworking/net/raw_cb.c: Sync with FreeBSD. | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2007-03-26 | 2 | -35/+22 |
