* | 2009-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-30 | 1 | -1/+1 |
| | | | | | * libnetworking/net/ppp_tty.c: Reflect termios_baud_to_number having been renamed to rtems_termios_baud_to_number. | ||||
* | Remove PSEUDO_SET (Unused). | Ralf Corsepius | 2009-02-11 | 1 | -2/+1 |
* | Eliminate pppattach, pppintr (Unused). | Ralf Corsepius | 2009-02-04 | 1 | -4/+0 |
* | Eliminate pppintr (Unused). | Ralf Corsepius | 2009-02-04 | 1 | -8/+0 |
* | Add missing initializers. | Ralf Corsepius | 2008-12-22 | 1 | -6/+8 |
* | Include <errno.h> (POSIX,C99) instead of <sys/errno.h> (BSD'ism). | Ralf Corsepius | 2008-12-22 | 5 | -5/+5 |
* | Include <sys/socket.h> to make header self contained. | Ralf Corsepius | 2008-12-11 | 2 | -0/+3 |
* | #include <stdint.h> instead of <rtems/stdint.h>. | Ralf Corsepius | 2008-12-11 | 2 | -4/+2 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 10 | -203/+78 |
* | 2008-08-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-18 | 1 | -1/+0 |
| | | | | | * libnetworking/net/ppp_tty.c: Remove bogus local decl of termios_baud_to_number(int). | ||||
* | Bugfix: Moved definition of ppp_softc into source file. | Thomas Doerfler | 2008-05-27 | 2 | -2/+2 |
* | Add if_nameindex etc. (from FreeBSD). | Ralf Corsepius | 2007-10-04 | 1 | -0/+13 |
* | 2007-09-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-09-16 | 1 | -1/+3 |
| | | | | | * libnetworking/net/ppp_defs.h: Include rtems/stdint.h. Use uint32_t for ext_accm. | ||||
* | Include <rtems/bsd/sys/cdefs.h> instead of <sys/cdefs.h>. | Ralf Corsepius | 2007-05-10 | 3 | -3/+3 |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 5 | -5/+5 |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 4 | -4/+4 |
* | Include <rtems/stdint.h> instead of <stdint.h>. | Ralf Corsepius | 2007-05-09 | 1 | -1/+1 |
* | Remove (Unused) | Ralf Corsepius | 2007-03-30 | 2 | -1800/+0 |
* | 2007-03-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-29 | 1 | -15/+6 |
| | | | | * libnetworking/net/netisr.h: Partial update from FreeBSD. | ||||
* | Remove (Unused). | Ralf Corsepius | 2007-03-28 | 1 | -5/+0 |
* | Use net/slcompress.h instead of net/pppcompress.h. | Ralf Corsepius | 2007-03-28 | 2 | -8/+8 |
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2007-03-28 | 1 | -1/+1 |
* | Remove (Abandoned in FreeBSD). | Ralf Corsepius | 2007-03-28 | 2 | -758/+0 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-28 | 1 | -6/+6 |
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2007-03-28 | 1 | -24/+29 |
* | Update from FreeBSD. | Ralf Corsepius | 2007-03-28 | 1 | -22/+22 |
* | Include <net/ppp_comp.h>. Warn about using it. | Ralf Corsepius | 2007-03-27 | 1 | -165/+2 |
* | 2007-03-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -0/+168 |
| | | | | * libnetworking/net/ppp_comp.h: New (copy of ppp-comp.h). | ||||
* | 2007-03-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -19/+22 |
| | | | | | * libnetworking/net/ppp-comp.h: Eliminate __P(). Cosmetics from FreeBSD. | ||||
* | 2007-03-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-03-27 | 1 | -13/+22 |
| | | | | * libnetworking/net/raw_cb.c: Sync with FreeBSD. | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2007-03-26 | 2 | -35/+22 |
* | More updates from FreeBSD. | Ralf Corsepius | 2007-03-25 | 2 | -8/+6 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2007-03-25 | 3 | -25/+22 |
* | Use struct rtems_termios_linesw instead of struct linesw (PR 1229). | Ralf Corsepius | 2007-03-18 | 1 | -2/+2 |
* | Remove __P(). | Ralf Corsepius | 2007-03-17 | 2 | -5/+5 |
* | Cosmetics from FreeBSD. | Ralf Corsepius | 2006-12-08 | 1 | -47/+45 |
* | 2006-09-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-09-14 | 1 | -5/+6 |
| | | | | | | | * libnetworking/net/route.c, librpc/src/rpc/auth_none.c, librpc/src/rpc/auth_unix.c, librpc/src/rpc/authunix_prot.c, librpc/src/rpc/rpc_callmsg.c, librpc/src/rpc/rpc_prot.c, librpc/src/rpc/rtems_portmapper.c: Removed warnings. | ||||
* | 2006-09-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-09-01 | 1 | -2/+2 |
| | | | | * libnetworking/net/if_loop.c: Remove warning. | ||||
* | *** empty log message *** | Joel Sherrill | 2006-09-01 | 3 | -5/+5 |
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-31 | 7 | -9/+9 |
| | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/include/sys/ioccom.h, libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c, libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h, libnetworking/net/if.c, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c, libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings due to improper use of int which shows up on 16 bit targets. Added ioctl_command_t since IOCTL command argument does not reliably fit into 16 bits. | ||||
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-30 | 8 | -12/+13 |
| | | | | | | | | | | | | | | * libcsupport/include/sys/ioccom.h, libnetworking/kern/uipc_socket2.c, libnetworking/net/ethernet.h, libnetworking/net/if.h, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/ppp_tty.c, libnetworking/net/pppcompress.c, libnetworking/net/slcompress.c, libnetworking/netinet/in.h, libnetworking/netinet/ip_icmp.c, libnetworking/netinet/tcp.h, libnetworking/netinet/tcp_seq.h, libnetworking/sys/protosw.h, libnetworking/sys/socketvar.h: Remove warnings. Most of the warnings were 16/32 bit integer sizing issues. Some constants had L appended, some had casts add, some types were changed to reflect a bit width requirement. | ||||
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-30 | 1 | -1/+1 |
| | | | | | | * libcsupport/src/utsname.c, libnetworking/libc/res_debug.c, libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c, librpc/src/rpc/svc_simple.c: Remove printf format warnings. | ||||
* | * libnetworking/net/if_ethersubr.c: (ether_ioctl) | Till Straumann | 2006-08-22 | 1 | -0/+3 |
| | | | | | Return error for unknown/unsupported ioctl command. (Change merged from freeBSD). | ||||
* | 2006-08-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-15 | 1 | -1/+1 |
| | | | | | | * libnetworking/kern/kern_sysctl.c: Change int to int32_t. * libnetworking/net/if_loop.c: Add cast to long. These plus a patch to machine/param.h let the h8300 build multilib. | ||||
* | 2006-06-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-06-24 | 1 | -2/+4 |
| | | | | | * libnetworking/net/if_var.h: #include <sys/queue.h>. Cosmetics from FreeBSD. | ||||
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-14 | 1 | -0/+527 |
| | | | | | * libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h: New (Moved from c/src/libchip). | ||||
* | 2005-11-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-11-08 | 1 | -2/+4 |
| | | | | | | | | * libnetworking/net/if.h: Add forward reference declaration to struct mbuf so ifru_tap callback is properly typed. * libnetworking/rtems/rtems_bsdnet.h: Add definition of _BSD_VISIBLE which needs to be defined so various pieces of the .h files are visible to device drives. | ||||
* | 2005-11-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-02 | 2 | -6405/+0 |
| | | | | | | * libnetworking/net/zlib.c: Remove. * libnetworking/net/zlib.h: Remove. * libnetworking/Makefile.am: Reflect changes above. | ||||
* | Update from FreeBSD. | Ralf Corsepius | 2005-10-27 | 2 | -39/+58 |
* | Remove. | Ralf Corsepius | 2005-10-27 | 1 | -11/+0 |
