* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | Use <sys/queue.h> instead of <rtems/bsd/sys/queue.h. | Ralf Corsepius | 2011-03-02 | 1 | -1/+1 |
* | Add HAVE_CONFIG_H support to let files receive configure defines. | Ralf Corsepius | 2010-03-28 | 1 | -0/+4 |
* | Include <errno.h> (POSIX,C99) instead of <sys/errno.h> (BSD'ism). | Ralf Corsepius | 2008-12-22 | 1 | -1/+1 |
* | Stop using old-style function definitions. | Ralf Corsepius | 2008-09-01 | 1 | -15/+6 |
* | Include <rtems/bsd/sys/queue.h> instead of <sys/queue.h>. | Ralf Corsepius | 2007-05-10 | 1 | -1/+1 |
* | More updates from FreeBSD. | Ralf Corsepius | 2007-03-25 | 1 | -5/+2 |
* | Partial update from FreeBSD. | Ralf Corsepius | 2007-03-25 | 1 | -4/+4 |
* | *** empty log message *** | Joel Sherrill | 2006-09-01 | 1 | -1/+1 |
* | Base files | Joel Sherrill | 1998-08-19 | 1 | -0/+315 |
