These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* configure.ac: Check for rcmd in unistd.h.
* libnetworking/libc/rcmd.c: Build iff rcmd is declared in unistd.h.
Change rcmd's decl to match with Linux/FreeBSD's decl.
PR 1983/networking
* libnetworking/libc/gethostbyht.c (gethostent_r):
Abort if (!hostf).
* libnetworking/libc/ns_parse.c (ns_parserr):
Comment out if ( section < 0 ) (type is unsigned).
* libnetworking/libc/gethostbydns.c: Comment out __dns_getanswer
(Unused).
* libnetworking/libc/res_mkupdate.c (res_mkupdate):
Remove unused var "sp1".
* libnetworking/libc/res_comp.c: Eliminate unused var "ppch".
* libnetworking/libc/addr2ascii.c,
libnetworking/libc/ascii2addr.c,
libnetworking/libc/addr2ascii.3: Remove.
* libnetworking/Makefile.am: Reflect changes above.
* libnetworking/libc/gethostnamadr.c:
Cast addr to uintptr_t instead of size_t.
Try to make crazy address arithmetic more portable.
* libnetworking/libc/map_v4v6.c: Use uintptr_t instead of u_long for
better 16bit target compliance.
* libnetworking/libc/gethostbydns.c: Use uintptr_t instead of u_long
for 16bit target compliance.
* ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c,
httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c,
libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c,
libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_init.c, libnetworking/libc/res_query.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Readdress use of ctype methods per
recommendation from D.J. Delorie on the newlib mailing list. We
should pass an unsigned char into these methods.
* ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c,
httpd/websuemf.c, libblock/src/diskdevs.c,
libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c,
score/src/objectgetnameasstring.c: Fix warnings for ctype methods.
* cpukit/libblock/src/bdpart.c, libmisc/shell/main_msdosfmt.c,
libmisc/shell/main_rm.c, libnetworking/libc/gethostnamadr.c,
score/include/rtems/score/bitfield.h,
score/inline/rtems/score/priority.inl: Remove warnings.
* libnetworking/kern/kern_sysctl.c, libnetworking/libc/res_debug.c: Fix
warnings.
* libnetworking/lib/ftpfs.c, libnetworking/libc/inet_ntoa.c,
libnetworking/libc/rcmd.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_glue.c,
libnetworking/rtems/rtems_malloc_mbuf.c,
libnetworking/rtems/rtems_showicmpstat.c, libnetworking/sys/malloc.h:
Fix some warnings.
* libnetworking/Makefile.am, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getservbyname.c,
libnetworking/libc/getservbyport.c: Add initial versions of
getservbyport_r(), gethostbyaddr_r(), and getservbyport_r(). At this
point they are just simple weappers for the version without the _r in
the name.
PR 1262/filesystem
* libcsupport/Makefile.am, libnetworking/libc/herror.c,
libnetworking/libc/res_send.c, libnetworking/sys/uio.h,
telnetd/Makefile.am, telnetd/README, telnetd/preinstall.am,
telnetd/pty.c, telnetd/telnetd.c: Add support for readv() and
writev() including documentation and test case.
* libcsupport/src/readv.c, libcsupport/src/writev.c: New files.
* libnetworking/libc/strsep.c: Don't build if provided by libc.
* libnetworking/libc/rcmd.c: Eliminate __P(). Cosmetics.
* libnetworking/libc/gethostbyht.c: Remove warning on unused vars.
Remove isblank (supposed to be provided by libc).
Eliminate bcopy in favor of memcpy.
* libnetworking/netdb.h, libnetworking/libc/gethostbyht.c,
libnetworking/libc/gethostnamadr.c: This patch adds a functional
gethostbyname_r to RTEMS. We were having problems with multiple
threads calling gethostbyname, so we decided the best way to deal
with it was to do it properly, rather than kludge up our code to make
gethostbyname safe. We have found several slightly different
parameter lists for this function, it does not seem to be standard.
The one we used has the linux interface. In RTEMS there was an
existing gethostbyname_r inside a #ifdef _THREAD_SAFE which was NOT
Threadsafe, as this just called gethostbyname. So we have placed all
of the additional code inside the #ifdef _THREAD_SAFE.
* ftpd/ftpd.c, libcsupport/include/sys/ioccom.h,
libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c,
libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h,
libnetworking/net/if.c, libnetworking/net/if_ethersubr.c,
libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c,
libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings
due to improper use of int which shows up on 16 bit targets. Added
ioctl_command_t since IOCTL command argument does not reliably fit
into 16 bits.
* libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-symbols.c,
libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c,
libnetworking/libc/res_debug.c, telnetd/telnetd.c: Remove printf
format warnings.
* libcsupport/src/utsname.c, libnetworking/libc/res_debug.c,
libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c,
librpc/src/rpc/svc_simple.c: Remove printf format warnings.
PR 842/networking
* libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename
dprintf to debugprintf().
