path: root/cpukit/libnetworking/libc (follow)
* 2002-03-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-011-9/+9
| | | | * libc/rcmd.c: Replace __rtems w/ __rtems__.
| | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * arpa/Makefile.am: Remove AUTOMAKE_OPTIONS. * kern/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * lib/Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS. * machine/Makefile.am: Remove AUTOMAKE_OPTIONS. * net/Makefile.am: Remove AUTOMAKE_OPTIONS. * netinet/Makefile.am: Remove AUTOMAKE_OPTIONS. * nfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * pppd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS. * sys/Makefile.am: Remove AUTOMAKE_OPTIONS. * vm/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-03-20 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill2002-03-202-2/+26
| | | | | | | | | * PR158 * libc/rcmd.c, libc/rcmd.c: Enable the rcmd() library call by commenting out the parts that deal with signals. This enables RTEMS to 'rsh' command to a server connecting fd to remote stdio. The 'server-side' parts of this file which deal with authentication are disabled since they are not needed.
* 2001-05-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-101-1/+1
| | | | * libc/Makefile.am: Remove -D__STRICT_ANSI__.
* 2000-12-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-081-1/+2
| | | | | | | | | | * libc/linkaddr.c: Initialized variable to remove warning. * modem/ppp.c, modem/ppp_tty.c: Made numerous variable declarations conditional on PPP_COMPRESS and PPP_FILTER. Commented out variables that were not used because the code using them was commented out. Removed totally unused variables. * modem/pppcompress.c: Added parentheses to avoid warnings. * pppd/pppmain.c: Removed numerous warnings.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-271-1/+1
| | | | * libc/res_init.c: Fix typo - adding missing # on include.
* 2000-11-25 Eric Norum <eric.norum@usask.ca>Joel Sherrill2000-11-251-1/+5
| | | | * libc/res_init.c: Move include to avoid compiler dumping core.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-6/+7
| | | | | | | * kern/Makefile.am, lib/Makefile.am, libc/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-13/+13
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-031-0/+57
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Made to compile after hacking tftp driver into beginnings of a mini-filesystem.Joel Sherrill1999-01-211-2/+2
* All warnings removed.Joel Sherrill1998-08-211-1/+1
* Fixed warning about pointer/integer conversion which turned out to beJoel Sherrill1998-08-211-1/+1
| | | | a missed "&" on a write.
* Added CVS IdsJoel Sherrill1998-08-2029-0/+56
* Fixed many warnings.Joel Sherrill1998-08-2017-61/+88
* Base filesJoel Sherrill1998-08-1970-0/+15065
