PR 1262/filesystem
* libcsupport/Makefile.am, libnetworking/libc/herror.c,
libnetworking/libc/res_send.c, libnetworking/sys/uio.h,
telnetd/Makefile.am, telnetd/README, telnetd/preinstall.am,
telnetd/pty.c, telnetd/telnetd.c: Add support for readv() and
writev() including documentation and test case.
* libcsupport/src/readv.c, libcsupport/src/writev.c: New files.
* libnetworking/libc/strsep.c: Don't build if provided by libc.
* libnetworking/libc/rcmd.c: Eliminate __P(). Cosmetics.
* libnetworking/libc/gethostbyht.c: Remove warning on unused vars.
Remove isblank (supposed to be provided by libc).
Eliminate bcopy in favor of memcpy.
* libnetworking/netdb.h, libnetworking/libc/gethostbyht.c,
libnetworking/libc/gethostnamadr.c: This patch adds a functional
gethostbyname_r to RTEMS. We were having problems with multiple
threads calling gethostbyname, so we decided the best way to deal
with it was to do it properly, rather than kludge up our code to make
gethostbyname safe. We have found several slightly different
parameter lists for this function, it does not seem to be standard.
The one we used has the linux interface. In RTEMS there was an
existing gethostbyname_r inside a #ifdef _THREAD_SAFE which was NOT
Threadsafe, as this just called gethostbyname. So we have placed all
of the additional code inside the #ifdef _THREAD_SAFE.
* ftpd/ftpd.c, libcsupport/include/sys/ioccom.h,
libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c,
libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h,
libnetworking/net/if.c, libnetworking/net/if_ethersubr.c,
libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c,
libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings
due to improper use of int which shows up on 16 bit targets. Added
ioctl_command_t since IOCTL command argument does not reliably fit
into 16 bits.
* libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-command.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-symbols.c,
libmisc/rtmonuse/rtmonuse.c, libmisc/stackchk/check.c,
libnetworking/libc/res_debug.c, telnetd/telnetd.c: Remove printf
format warnings.
* libcsupport/src/utsname.c, libnetworking/libc/res_debug.c,
libnetworking/net/if_media.h, libnetworking/rtems/rtems_mii_ioctl.c,
librpc/src/rpc/svc_simple.c: Remove printf format warnings.
PR 842/networking
* libnetworking/libc/gethostbydns.c: Avoid use of dprintf(). Rename
dprintf to debugprintf().
* libnetworking/kern/kern_sysctl.c, libnetworking/libc/inet_ntop.c,
libnetworking/net/if_ppp.c, libnetworking/net/pppcompress.c,
libnetworking/net/slcompress.c, libnetworking/netinet/ip_output.c,
libnetworking/netinet/udp_usrreq.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_select.c,
libnetworking/rtems/rtems_showifstat.c,
libnetworking/rtems/rtems_showroute.c,
libnetworking/rtems/rtems_syscall.c: Fixed type mismatch and
uninitialized variable warnings.
PR 755/rtems
* libnetworking/libc/res_init.c, libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/nfs/bootp_subr.c: Include <rtems/bsdnet/servers.h>.
* libnetworking/libc/res_debug.c: Added const to eliminate warnings.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* libc/Makefile.am: Remove.
* lib/Makefile.am: Remove.
* Makefile.am: Merge-in the Makefile.ams above.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, libc/Makefile.am, lib/Makefile.am, wrapup/Makefile.am:
* kern/kern_mib.c: Use RTEMS_VERSION to setup osrelease.
* libc/getproto.c, libc/getprotoname.c: modification to call
getprotoent_static() if fopen() on /etc/protocols fails.
* kern/Makefile.am: Remove C_O_FILES;
Don't let all-local depend on $OBJS)
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* libc/rcmd.c, netinet/in_cksum_arm.c: Removed warnings.
* Pass to eliminate warnings.
* kern/uipc_mbuf.c: Conditional SYSINIT() usage on __rtems__.
Fix return statement without a value.
* lib/ftpfs.c: read and write filesystem routines return ssize_t.
* lib/syslog.c: Add include of <string.h> to eliminate warning.
* lib/tftpDriver.c: read and write filesystem routines return ssize_t.
* libc/gethostbydns.c: Prototype abort().
* libc/inet_ntoa.c: Prototype strcpy().
* libc/rcmd.c: Add include of <sys/select.h>
* net/if_loop.c: Turn token at end of endif to comment.
* net/rtsock.c, nfs/bootp_subr.c: Conditional SYSINIT() usage
on __rtems__.
* rtems/rtems_bootp.c: Add include of <rtems/rtems_bsdnet_internal.h>.
* rtems/rtems_bsdnet_internal.h: Added prototypes for memcpy() and
memset() since the BSD code tries to avoid using libc .h files
since it is used to being in the kernel.
* rtems/rtems_syscall.c: read and write filesystem routines
return ssize_t.
* libc/getservent.c: Per PR265, add #include <netinet/in.h> for
ntohl() function.
* Makefile.am, libc/res_send.c: Do not install or use <poll.h>
since RTEMS does not support it.
* kern/Makefile.am: Use .$(OBJEXT) instead of .o.
* wrapup/Makefile.am: Ditto.
* kern/Makefile.am: Eliminate LIBNAME.
* wrapup/Makefile.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib.
* arpa/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* kern/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
* lib/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* libc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* machine/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* net/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* netinet/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* nfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* sys/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* vm/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Relocate c/src/libnetworking.
* Makefile.am: Reflect moval.
* machine/Makefile.am: Ditto.
* vm/Makefile.am: Ditto.
* sys/Makefile.am: Ditto.
* arpa/Makefile.am: Ditto.
* kern/Makefile.am: Ditto.
* configure.ac: Dittp.
* wrapup/Makefile.am: Ditto. Remove references to networking apps.
* libc/rcmd.c: Replace __rtems w/ __rtems__.
* arpa/Makefile.am: Remove AUTOMAKE_OPTIONS.
* kern/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/Makefile.am: Remove AUTOMAKE_OPTIONS.
* netinet/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pppd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sys/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR158
* libc/rcmd.c, libc/rcmd.c: Enable the rcmd() library call by
commenting out the parts that deal with signals. This enables
RTEMS to 'rsh' command to a server connecting fd to remote stdio.
The 'server-side' parts of this file which deal with authentication
are disabled since they are not needed.
* libc/Makefile.am: Remove -D__STRICT_ANSI__.
* libc/linkaddr.c: Initialized variable to remove warning.
* modem/ppp.c, modem/ppp_tty.c: Made numerous variable declarations
conditional on PPP_COMPRESS and PPP_FILTER. Commented out variables
that were not used because the code using them was commented out.
Removed totally unused variables.
* modem/pppcompress.c: Added parentheses to avoid warnings.
* pppd/pppmain.c: Removed numerous warnings.
* libc/res_init.c: Fix typo - adding missing # on include.
* libc/res_init.c: Move include to avoid compiler dumping core.
* kern/Makefile.am, lib/Makefile.am, libc/Makefile.am,
net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am,
pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
