2021-04-07 | cpukit: Remove libnetworking | Vijay Kumar Banerjee | 1 | -209/+0 | |
Update #3850 | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -1/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
1998-08-19 | Base files | Joel Sherrill | 1 | -0/+210 | |
