* libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h,
librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c,
librpc/src/rpc/pmap_getport.c: Remove warnings.
PR 755/rtems
* libnetworking/libc/res_init.c, libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/nfs/bootp_subr.c: Include <rtems/bsdnet/servers.h>.
PR 620/networking
* libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/rtems/rtems_bsdnet.h: Enhance NTP API.
* libnetworking/lib/ftpfs.c, libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/lib/tftpDriver.c, libnetworking/machine/endian.h,
libnetworking/net/if_ppp.c, libnetworking/rtems/rtems_bsdnet.h,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/rtems/rtems_glue.c,
libnetworking/rtems/rtems_syscall.c: Convert to using c99 fixed size
types.
* libnetworking/lib/ftpfs.c: Switch bcopy to memcpy.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* libc/Makefile.am: Remove.
* lib/Makefile.am: Remove.
* Makefile.am: Merge-in the Makefile.ams above.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, libc/Makefile.am, lib/Makefile.am, wrapup/Makefile.am:
* kern/kern_mib.c: Use RTEMS_VERSION to setup osrelease.
PR 341/networking
* lib/ftpfs.c: Account for NULL at end of strings when malloc()'ing
memory.
* kern/Makefile.am: Remove C_O_FILES;
Don't let all-local depend on $OBJS)
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* Pass to eliminate warnings.
* kern/uipc_mbuf.c: Conditional SYSINIT() usage on __rtems__.
Fix return statement without a value.
* lib/ftpfs.c: read and write filesystem routines return ssize_t.
* lib/syslog.c: Add include of <string.h> to eliminate warning.
* lib/tftpDriver.c: read and write filesystem routines return ssize_t.
* libc/gethostbydns.c: Prototype abort().
* libc/inet_ntoa.c: Prototype strcpy().
* libc/rcmd.c: Add include of <sys/select.h>
* net/if_loop.c: Turn token at end of endif to comment.
* net/rtsock.c, nfs/bootp_subr.c: Conditional SYSINIT() usage
on __rtems__.
* rtems/rtems_bootp.c: Add include of <rtems/rtems_bsdnet_internal.h>.
* rtems/rtems_bsdnet_internal.h: Added prototypes for memcpy() and
memset() since the BSD code tries to avoid using libc .h files
since it is used to being in the kernel.
* rtems/rtems_syscall.c: read and write filesystem routines
return ssize_t.
* kern/Makefile.am: Use .$(OBJEXT) instead of .o.
* wrapup/Makefile.am: Ditto.
* kern/Makefile.am: Eliminate LIBNAME.
* wrapup/Makefile.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib.
* Addition of a ftp client filesystem, comparable to the tftp one.
* lib/ftpfs.c, rtems/ftpfs.h: New files.
* lib/Makefile.am, rtems/Makefile.am: Modified to reflect above.
* arpa/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* kern/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
* lib/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* libc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* machine/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* net/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* netinet/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* nfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* sys/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* vm/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Relocate c/src/libnetworking.
* Makefile.am: Reflect moval.
* machine/Makefile.am: Ditto.
* vm/Makefile.am: Ditto.
* sys/Makefile.am: Ditto.
* arpa/Makefile.am: Ditto.
* kern/Makefile.am: Ditto.
* configure.ac: Dittp.
* wrapup/Makefile.am: Ditto. Remove references to networking apps.
* arpa/Makefile.am: Remove AUTOMAKE_OPTIONS.
* kern/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/Makefile.am: Remove AUTOMAKE_OPTIONS.
* netinet/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pppd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sys/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/tftpDriver.clib/tftpDriver.c: Fix TFTP block number checking.
* lib/tftpDriver.c: Remove set_errno_and_return_minus_one, include
<rtems/seterr.h>.
* lib/tftpDriver.c: Allow chdir() to work on TFTP `directories'
(path names with a / at the end) while disallowing open() operations
on TFTP `directories'.
* lib/tftpDriver.c: Restore write capability.
* lib/tftpDriver.c: Properly handles ../ components in chdir() and
open() operations within the TFTP file system.
* lib/tftpDriver.c: Add limited chdir() support to the TFTP
filesystem.
* lib/tftpDriver.c: Add some debugging capability.
* lib/rtems_bsdnet_ntp.c: Modifications to make the RTEMS NTP
synchronization a little more robust -- no NTP daemon yet, but
at least it trys a little harder when the primary NTP server is down.
* lib/tftpDriver.c: Reduce first timeout interval. This
improves throughput on systems which are dropping packets.
Only the first timeout is reduced. This keeps the number
of extra packets down on networks that are very busy and
dropping lots of packets.
* lib/tftpDriver.c: Added write capability.
* lib/tftpDriver.c: add comments to handlers struct function pointers.
* rtems/rtems_glue.c: move pointer arithmetic to be _after_
pointer has been checked against NULL.
* kern/Makefile.am, lib/Makefile.am, libc/Makefile.am,
net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am,
pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
./bootstrap
more flexible about the error status returned from a timeout.
report by Nick.SIMON@syntegra.bt.co.uk:
TFTP uses UDP and UDP packets are prime targets for getting dropped when
the network gets busy. I want the number of retries quite large in my
application. I see that PACKET_REPLY_MILLISECONDS is, in fact, not
being used.
system table from when the rtems_filesystem_operations_table structure changed
and the initializer in libnetworking/lib/tftpDriver.c did not get
updated.
Patches against 1105 snapshot to add NTP server support to network
configuration/BOOTP.
the minor number indicated the port number to try.
I get the following warning when compiling the latest snapshot. I had
a quick look at the source -- it certainly looks to me like this is a
real bug.
../../../../src/rtems-19990709/c/src/lib/libc/mount.c:97: warning:
`options' might be used uninitialized in this function
Also, I changed the TFTP test program and TFTP driver to reflect the
changes in the way paths are passed to the TFTP driver. The TFTP driver
now needs a proper `dotted-decimal' hostname as the second component of
the path name.
mount() was changed to avoid the use of a string as the options.
