* ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c,
httpd/websuemf.c, libblock/src/diskdevs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_network.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Fix warnings for ctype methods.
* libnetworking/lib/ftpfs.c: Use EINVAL not EBADRQC.
* libcsupport/src/termios.c, libfs/src/dosfs/msdos_format.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/pipe/fifo.c,
libnetworking/lib/rtems_bsdnet_ntp.c, libnetworking/lib/tftpDriver.c,
libnetworking/rtems/rtems_glue.c, libnetworking/rtems/rtems_select.c:
Eliminate uses of deprecated rtems_clock_get() and replace with
properly typed routine.
* libnetworking/lib/tftpDriver.c: Remove vim: meta-tags.
* libnetworking/lib/tftpDriver.c (rtems_tftp_eval_path):
Add missing parameter pathlen.
* libblock/src/bdbuf.c: Update comments.
* libblock/src/bdpart.c, libblock/src/ide_part_table.c: Get the
device from the rdev field of the stat buf.
* libcsupport/include/rtems/libio.h: Add a path length to evalpath
handler. Add parent locations to rmmod and unlink handlers.
* libcsupport/include/rtems/libio_.h: Add a path length to
rtems_filesystem_evaluate_path. Add
rtems_filesystem_evaluate_relative_path, rtems_filesystem_dirname,
and rtems_filesystem_prefix_separators. Remove
rtems_filesystem_evaluate_parent.
* libcsupport/src/base_fs.c, libcsupport/src/chdir.c,
libcsupport/src/chmod.c, libcsupport/src/chown.c,
libcsupport/src/chroot.c, libcsupport/src/fchdir.c,
libcsupport/src/link.c, libcsupport/src/mount.c,
libcsupport/src/open.c, libcsupport/src/privateenv.c,
libcsupport/src/readlink.c, libcsupport/src/unmount.c,
libcsupport/src/utime.c, libcsupport/src/unmount.c,
libcsupport/src/utime.c, libfs/src/devfs/devfs.h,
libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devstat.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_misc.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c,
libfs/src/imfs/imfs_load_tar.c, libfs/src/imfs/ioman.c,
libfs/src/pipe/pipe.c, libmisc/fsmount/fsmount.c,
libnetworking/lib/ftpfs.c: Add the length parameter to the eval
call.
* libcsupport/src/eval.c: Add rtems_filesystem_prefix_separators,
rtems_filesystem_evaluate_relative_path. Add the length parameter
to the eval call.
* libcsupport/src/rmdir.c: Find the parent pathloc then the node
pathloc from that node. Remove the call to find the parent given
the node pathloc.
* libcsupport/src/stat.c: Add the length parameter to the eval
call. Set the device into the rdev field.
* libcsupport/src/unlink.c: Find the parent pathloc then the node
the node pathloc.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/msdos_format.c: Get the
disk device number from the stat rdev field.
* libfs/src/dosfs/msdos.h: Add the length parameter to the eval
call. Add the parent pathloc to the rmnod handler.
* libfs/src/dosfs/msdos_dir.c: Add the parent pathloc to the rmnod
handler.
* libfs/src/dosfs/msdos_eval.c: Add the length parameter to the
eval and token call.
* libfs/src/imfs/imfs_directory.c: Add the parent pathloc to the
rmnod handler.
* libfs/src/imfs/imfs_fchmod.c: Do not test the mode flags for
only the allowed flags. Add the missing flags spec'ed in the POSIX
standard.
* libfs/src/imfs/imfs_fsunmount.c, libfs/src/imfs/imfs_rmnod.c,
libfs/src/imfs/imfs_unlink.c, libfs/src/imfs/memfile.c: Add the
parent node. Currently ignored in the IMFS.
* libfs/src/imfs/imfs_stat.c: Return the device number in the rdev
field.
* libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_symlink.c : Add
the length parameter to the token call.
* libfs/src/nfsclient/src/nfs.c: Add the length parameter to the
eval call and parent node to the rmnod and unlink command.
* libmisc/shell/internal.h: Remove the libc mounter decl to make
public.
* libmisc/shell/main_mount.c: Add support for hooking external
mount support for new file systems.
* libmisc/shell/shell.h: Add helper functions for the mount
command.
timeouts. Options are now per file system instance.
* libmisc/uuid/gen_uuid.c, libnetworking/lib/syslog.c,
telnetd/telnetd.c: Fixed warnings.
accept. Return EIO for close() errors. Changed PORT format string.
Fixed connection termination after store errors on passive connections.
Added magic device identifier for stat().
* libcsupport/include/rtems/libio.h: Add rtems_off64_t for
internal use. Update the internal off_t to the 64bit offset.
* libnetworking/lib/ftpfs.c, libnetworking/lib/tftpDriver.c,
libfs/src/nfsclient/src/nfs.c, libfs/src/imfs/imfs_fifo.c,
libfs/src/imfs/memfile.c, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/deviceio.c: Change off_t to
rtems_off64_t.
* libmisc/shell/main_msdosfmt.c: Add an info level so the format
code can tell the user what is happening. Add more options to
control the format configuration.
* libfs/src/dosfs/msdos_format.c: Add a print function to display
the format progress and print statements. Select a better default
cluster size depending on the size of the disk. This lowers the
size of the FAT on large disks. Read and maintain the MRB
partition information.
* libfs/src/dosfs/dosfs.h, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/fat_file.h,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_conv.c,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_file.c,
libfs/src/dosfs/msdos_handlers_dir.c,
libfs/src/dosfs/msdos_handlers_file.c,
libfs/src/dosfs/msdos_init.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Add
long file name support. Change off_t to rtems_off64_t.
Request reply after data write connection close.
* libcsupport/src/symlink.c: Check if path evaluation handler exists.
* libnetworking/lib/ftpfs.c: Cleanup.
oparations table for mount command is now const.
* libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h: Rewrite of
the FTP file system which implements now the trivial command state
machines of RFC 959. For the data transfer passive (= default) and
active (= fallback) modes are now supported.
* libmisc/shell/main_mount_ftp.c: Update for FTP file system changes.
* libnetworking/lib/ftpfs.c: Enable write and mount filesystem
with read-write access.
* libnetworking/lib/rtems_bsdnet_ntp.c: Revert previous patch.
* libnetworking/lib/ftpfs.c: Use ssize_t for read retval (Fix
comparision of unsigned < 0).
* libnetworking/lib/rtems_bsdnet_ntp.c: Let TCP/IP stack pick port
rather than hard coding selection.
* libnetworking/lib/ftpfs.c, libnetworking/libc/inet_ntoa.c,
libnetworking/libc/rcmd.c, libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_malloc_mbuf.c,
libnetworking/rtems/rtems_showicmpstat.c, libnetworking/sys/malloc.h:
Fix some warnings.
* libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h,
librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c,
librpc/src/rpc/pmap_getport.c: Remove warnings.
PR 755/rtems
* libnetworking/libc/res_init.c, libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/nfs/bootp_subr.c: Include <rtems/bsdnet/servers.h>.
PR 620/networking
* libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/rtems/rtems_bsdnet.h: Enhance NTP API.
* libnetworking/lib/ftpfs.c, libnetworking/lib/rtems_bsdnet_ntp.c,
libnetworking/lib/tftpDriver.c, libnetworking/machine/endian.h,
libnetworking/net/if_ppp.c, libnetworking/rtems/rtems_bsdnet.h,
libnetworking/rtems/rtems_bsdnet_internal.h,
libnetworking/rtems/rtems_syscall.c: Convert to using c99 fixed size
types.
* libnetworking/lib/ftpfs.c: Switch bcopy to memcpy.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* libc/Makefile.am: Remove.
* lib/Makefile.am: Remove.
* Makefile.am: Merge-in the Makefile.ams above.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, libc/Makefile.am, lib/Makefile.am, wrapup/Makefile.am:
* kern/kern_mib.c: Use RTEMS_VERSION to setup osrelease.
PR 341/networking
* lib/ftpfs.c: Account for NULL at end of strings when malloc()'ing
memory.
* kern/Makefile.am: Remove C_O_FILES;
Don't let all-local depend on $OBJS)
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* Pass to eliminate warnings.
* kern/uipc_mbuf.c: Conditional SYSINIT() usage on __rtems__.
Fix return statement without a value.
* lib/ftpfs.c: read and write filesystem routines return ssize_t.
* lib/syslog.c: Add include of <string.h> to eliminate warning.
* lib/tftpDriver.c: read and write filesystem routines return ssize_t.
* libc/gethostbydns.c: Prototype abort().
* libc/inet_ntoa.c: Prototype strcpy().
* libc/rcmd.c: Add include of <sys/select.h>
* net/if_loop.c: Turn token at end of endif to comment.
* net/rtsock.c, nfs/bootp_subr.c: Conditional SYSINIT() usage
on __rtems__.
* rtems/rtems_bootp.c: Add include of <rtems/rtems_bsdnet_internal.h>.
* rtems/rtems_bsdnet_internal.h: Added prototypes for memcpy() and
memset() since the BSD code tries to avoid using libc .h files
since it is used to being in the kernel.
* rtems/rtems_syscall.c: read and write filesystem routines
return ssize_t.
* kern/Makefile.am: Use .$(OBJEXT) instead of .o.
* wrapup/Makefile.am: Ditto.
* kern/Makefile.am: Eliminate LIBNAME.
* wrapup/Makefile.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib.
* Addition of a ftp client filesystem, comparable to the tftp one.
* lib/ftpfs.c, rtems/ftpfs.h: New files.
* lib/Makefile.am, rtems/Makefile.am: Modified to reflect above.
* arpa/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* kern/Makefile.am: Include $(top_srcdir)/../automake/*.am.
Use ../aclocal.
* lib/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* libc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* machine/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* net/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* netinet/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* nfs/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* sys/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* vm/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/../automake/*.am.
