* | Patch from Eric Norum <eric@cls.usask.ca>: | Joel Sherrill | 1999-07-12 | 1 | -20/+15 |
| | | | | | | | | | | | | | | I get the following warning when compiling the latest snapshot. I had a quick look at the source -- it certainly looks to me like this is a real bug. ../../../../src/rtems-19990709/c/src/lib/libc/mount.c:97: warning: `options' might be used uninitialized in this function Also, I changed the TFTP test program and TFTP driver to reflect the changes in the way paths are passed to the TFTP driver. The TFTP driver now needs a proper `dotted-decimal' hostname as the second component of the path name. | ||||
* | After comments D. V. Henkel-Wallace <gumby@zembu.com>, the interface to | Joel Sherrill | 1999-06-15 | 1 | -1/+1 |
| | | | | mount() was changed to avoid the use of a string as the options. | ||||
* | Error reporting fixed by Jennifer. | Joel Sherrill | 1999-05-07 | 1 | -15/+15 |
* | Debugged and now works except for handling of minor number. | Joel Sherrill | 1999-02-04 | 1 | -313/+429 |
* | Made to compile after hacking tftp driver into beginnings of a mini-filesystem. | Joel Sherrill | 1999-01-21 | 1 | -34/+109 |
* | Added comments for changing to a filesystem | Joel Sherrill | 1999-01-19 | 1 | -0/+4 |
* | Added CVS Ids | Joel Sherrill | 1998-08-20 | 2 | -0/+8 |
* | Fixed many warnings. | Joel Sherrill | 1998-08-20 | 2 | -2/+4 |
* | Base files | Joel Sherrill | 1998-08-19 | 4 | -0/+839 |
