2021-04-07 | cpukit: Remove libnetworking | Vijay Kumar Banerjee | 1 | -220/+0 | |
Update #3850 | |||||
2018-09-10 | network: Use kernel/user space header files | Sebastian Huber | 1 | -0/+2 | |
Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375. | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -1/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2009-02-11 | Remove domain_set (Unused). | Ralf Corsepius | 1 | -2/+0 | |
2008-09-01 | Stop using old-style function definitions. | Ralf Corsepius | 1 | -13/+6 | |
2007-03-28 | Eliminate __P(). | Ralf Corsepius | 1 | -5/+5 | |
1999-05-17 | Patch from D. V. Henkel-Wallace <gumby@zembu.com> to remove compiler | Joel Sherrill | 1 | -2/+2 | |
warnings. | |||||
1998-08-20 | Fixed many warnings. | Joel Sherrill | 1 | -1/+3 | |
1998-08-19 | Base files | Joel Sherrill | 1 | -0/+226 | |
