path: root/cpukit/libmisc (follow)
* Patch rtems-4.5-beta3-mon.diff from Chris Johns <cjohns@cybertec.com.au>Joel Sherrill2000-06-143-174/+761
| | | | | | | | | | | | | | | to: I have also added the ability to register and unregister commands. This allows me to create a set of monitor commands for the network stack plus basic memory dump/patch commands (needs a working probe interface). I will also look at a basic ls/cd/rm/mv/cp command set at some stage. I have been thinking about changing the monitor in the future to more like a light weight RTEMS shell, `eshell' for embedded shell. This is a story for another day but is a process or getting the commands to map to the filesystem (eg, major=commands, minor=command) and supporting an environment. The filesystem provide a structure for the commands.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1211-21/+22
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-139-0/+29
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-086-90/+87
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-313-35/+27
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Removed warnings.Joel Sherrill1999-12-131-0/+1
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-238-18/+13
| | | | to convert the libmisc directory from Makefile.in to Makefile.am.
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-228-0/+351
* Updated copyright notice.Joel Sherrill1999-11-176-12/+6
* This is another pass at making sure that nothing outside the BSPJoel Sherrill1999-11-053-9/+3
| | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Modified to properly descend into the dummy directory.Joel Sherrill1999-10-271-1/+1
* New files from Ralf Corsepius <corsepiu@faw.uni-ulm.de> whichJoel Sherrill1999-10-272-0/+59
| | | | | | | | are a dummy for linking programs together when you are primarily concerned with tricking another package into building. This may grow into something which could help link programs on the command line by having a default start sequence.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to moveJoel Sherrill1999-10-261-2/+2
| | | | c/src/lib/libmisc to c/src/libmisc.
* Moved RTEMS error and association from libmisc to libc support toJoel Sherrill1999-10-111-1/+1
| | | | | avoid cyclic dependencies generated when moving packages to the top level.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-3/+3
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-0/+13
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-08-181-4/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Here is another fix, which addresses a few more or less severe bugs in configuration and unix/posix: * Configuration fix: c/src/lib/configure.in didn't handle RDBG correctly * Configuration fix: make depend was non-functional in c/src/lib/libc/Makefile.in * Configuration fix: stray comment removed from aclocal/target.m4 * RTEMS fix: termios support for unix/posix now uses the host's headers only (was completely broken). - Don't install RTEMS's newlib sys/termios.h for unix (sys/termios.h apparently is a newlib specific header) - To be able to compile RTEMS's termios.c with glibc2.1, glibc-2.1 needs __USE_MISC, which is a private define from gcc's features.h, being defined only when _BSD_SOURCE of _SVID_SOURCE is defined. RTEMS's termios apparently implements BSD, thus -D_BSD_SOURCE was added to Linux-posix.cfg. - Conflicting definitions for __USE_MISC and _BSD_SOURCE inside of RTEMS codes removed due to definition of _BSD_SOURCE on the toplevel. This fix has been tested with linux/posix (primary glibc2.1 native), linux/posix (secondary libc5 native), sh/gensh1, i386/pc386 and a couple of other bsp's/CPU. To apply: cd <srcdir> patch -p1 < rtems-rc-19990709-9.diff and aclocal -I aclocal && automake && autoconf cd c/src/lib; autoconf or ./autogen
* New file from Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.Joel Sherrill1999-07-091-0/+26
* Bug report from Ralf on UNIX port where the S_IR* constants were notJoel Sherrill1999-04-141-0/+1
| | | | defined.
* Untar support submitted by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.Joel Sherrill1999-04-062-0/+406
* New files added to ease debugging.Joel Sherrill1999-01-312-0/+96
* Include files now installed as <rtems/*.h>.Joel Sherrill1998-12-012-2/+2
* Removed unused file.Joel Sherrill1998-12-011-1/+1
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-232-0/+14
| | | | it work.
* Cosmetic fix from Eric Norum:Joel Sherrill1998-04-271-1/+1
| | | | | | This makes the headings line up above the columns a little better. Now that it's so easy to include/exclude the stack check code I find myself adding it to all my `debug' targets.
* Fixed so this would compile without warning.Joel Sherrill1998-04-151-0/+2
* Stack check now initialized as part of initial extension set.Joel Sherrill1998-04-153-0/+65
* Increased stack space of the monitor task.Joel Sherrill1998-04-061-1/+1
* updated copyright to 1998Joel Sherrill1998-02-175-5/+5
* Corrected Linux port for glibc2Joel Sherrill1998-01-301-1/+2
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-6/+6
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-163-3/+3
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Fixed indexing bug reported by Phil Wilshire.Joel Sherrill1997-12-071-1/+1
* Removed warnings.Joel Sherrill1997-11-292-1/+6
* Fixed a number of warnings regarding comparisons between signed andJoel Sherrill1997-10-214-9/+9
| | | | unsigned numbers.
* Fixed endian problem in printing object names.Joel Sherrill1997-10-211-0/+5
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-085-10/+10
* Cleaned up as part of adding the Monitor test.Joel Sherrill1997-09-2117-27/+21
* updatedJoel Sherrill1997-09-161-4/+11
* Removed assert condition when not initialized or there are 0 periods.Joel Sherrill1997-08-221-0/+5
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-225-25/+25
* printing task names now instead of id numbersJoel Sherrill1997-04-091-3/+16
* new files.Joel Sherrill1997-04-095-0/+415
* changed signed int to unsigned int to eliminate a warning.Joel Sherrill1997-04-071-1/+1
* pointer arithmetic reworked to be more portableJoel Sherrill1996-09-181-8/+8
* casts added to numerous arguments, prototypes corrected, andJoel Sherrill1996-09-1810-22/+27
| | | | proper include files added.
* added initial posix configuration supportJoel Sherrill1996-05-282-11/+12
* updates from Tony BennettJoel Sherrill1996-04-2218-169/+125
* As part of reducing visibility into rtems and hiding the .inl filesJoel Sherrill1996-03-067-0/+7
| | | | | from the application code, this file required more visibility than is given by default to application code.
* removed post switch extensionJoel Sherrill1996-02-131-1/+0
