path: root/cpukit/libmisc (follow)
* PR 2021 - mdump address problem with volatileRic Claus2012-03-301-9/+16
* libblock: New block IO control support functionsSebastian Huber2012-03-131-1/+1
* Filesystem: Reference counting for locationsSebastian Huber2012-03-133-0/+85
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | o A new data structure rtems_filesystem_global_location_t was introduced to be used for o the mount point location in the mount table entry, o the file system root location in the mount table entry, o the root directory location in the user environment, and o the current directory location in the user environment. During the path evaluation global start locations are obtained to ensure that the current file system instance will be not unmounted in the meantime. o The user environment uses now reference counting and is protected from concurrent access. o The path evaluation process was completely rewritten and simplified. The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation method. Recursive calls in the path evaluation have been replaced with iteration to avoid stack overflows. Only the evaluation of symbolic links is recursive. No dynamic memory allocations and intermediate buffers are used in the high level path evaluation. No global locks are held during the file system instance specific path evaluation process. o Recursive symbolic link evaluation is now limited by RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value via sysconf(). o The device file system (devFS) uses now no global variables and allocation from the workspace. Node names are allocated from the heap. o The upper layer lseek() performs now some parameter checks. o The upper layer ftruncate() performs now some parameter checks. o unmask() is now restricted to the RWX flags and protected from concurrent access. o The fchmod_h and rmnod_h file system node handlers are now a file system operation. o The unlink_h operation has been removed. All nodes are now destroyed with the rmnod_h operation. o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system operations. o The path evaluation and file system operations are now protected by per file system instance lock and unlock operations. o Fix and test file descriptor duplicate in fcntl(). o New test fstests/fsnofs01.
* Avoid NULL pointer accessSebastian Huber2012-02-131-3/+5
* PR 2001/shell - medit command argument parsing correctionJoel Sherrill2012-02-031-3/+1
| | | | | | | | | | | "medit" overran the argument list, choking on the NULL pointer following the last argument. Note that "medit" still only does byte-sized accesses, which limits its usefulness on most systems. Author: Werner Almesberger <werner@almesberger.net> Signed-off-by: Sebastien Bourdeauducq <sebastien@milkymist.org>
* PR 2012 - mdump/wdump shell cmds handle length arg incorrectly; add ldump cmdJoel Sherrill2012-02-024-134/+168
| | | | | | | | | | | | | * libmisc/shell/main_mdump.c: Reworked to fix bugs in handling of the length argument and to provide an "ldump" command. This file now also supports the "wdump" command. In addition, an RTEMS API function called rtems_mdump() is provided to allow easy dumping from application code. * libmisc/shell/main_mwdump.c: Obsolete file. * libmisc/Makefile.am: Removed main_mwdump.c * libmisc/shell/shellconfig.h: Added "ldump" command. * shell/memory.t: Added documentation for the "ldump" command Signed-off-by: Ric Claus <claus@SLAC.Stanford.edu>
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-061-2/+2
| | | | | * libmisc/stackchk/check.c: Make Stack_check_Initialize, Stack_check_Dump_threads_usage static.
* 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-062-1/+3
| | | | | | * libmisc/serdbg/serdbg.h: Add serdbg_init_dbg. * libmisc/serdbg/serdbgcnf.h: Remove conditional serdbg_init_dbg prototype.
* 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-061-1/+1
| | | | * libmisc/mouse/serial_mouse.c: Make serial_mouse_l_rint static.
* 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-064-6/+7
| | | | | | | | | | | * libmisc/monitor/mon-network.c: Include <rtems/monitor.h>. * libmisc/monitor/mon-object.c: Make rtems_monitor_object_canonical_next_remote, rtems_monitor_object_dump_1, rtems_monitor_object_dump_all static. * libmisc/monitor/mon-prmisc.c: Make rtems_monitor_dump_assoc_bitfield static. * libmisc/monitor/mon-symbols.c: Make rtems_monitor_symbol_dump_all static.
* 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-052-12/+12
| | | | | | | | | | | * libmisc/capture/capture.c: Make RTEMS_CAPTURE_* defines unsigned (Avoid implicit sign-conversions). Make rtems_capture_trigger static (Missing prototypes). Make rtems_capture_trigger static (Missing prototypes). * libmisc/capture/capture.h: Make RTEMS_CAPTURE_WATCH, RTEMS_CAPTURE_TRACED unsigned (Avoid implicit sign conversions).
* 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-051-1/+1
| | | | * libmisc/mouse/mouse_parser.c: Make MOU_Data static.
* 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-052-1/+4
| | | | | * libmisc/shell/shell.h: Add rtems_shell_main_monitor. * libmisc/shell/cmds.c: Make rtems_shell_main_monitor non-static.
* 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-051-0/+4
| | | | * libmisc/shell/main_mv.c: Add prototype for main_mv.
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-041-1/+3
| | | | | * libmisc/shell/main_cp.c: Include "internal.h". Make rtems_shell_main_cp non-static.
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-041-0/+1
| | | | * libmisc/shell/main_ls.c: Include "internal.h".
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-041-1/+2
| | | | | * libmisc/shell/main_rm.c: Remove decl of user_from_uid. Comment out decl of fflagstostr.
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-041-2/+3
| | | | | * libmisc/shell/pwcache.c: Include "internal.h". Make user_from_uid non-static.
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-041-0/+2
| | | | * libmisc/shell/internal.h: Add user_from_uid, group_from_gid.
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-046-7/+11
| | | | | | | | | | | * libmisc/shell/print-ls.c: Include "internal.h". * libmisc/shell/pwcache.c: Make user_from_uid static. * libmisc/shell/shell.c: Make rtems_shell_init_env, rtems_shell_env_free, rtems_shell_line_editor, rtems_shell_init_issue, rtems_shell_task static. * libmisc/shell/shell_cmdset.c: Make rtems_shell_add_topic static. * libmisc/shell/shell_makeargs.c: Include <rtems/shell.h>. * libmisc/shell/write_file.c: Include <rtems/shell.h>.
* * libmisc/shell/main_help.c: Make rtems_shell_help_cmd,Ralf Corsepius2011-12-0433-51/+41
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | rtems_shell_help static. * libmisc/shell/main_hexdump.c: Make main_hexdump static. * libmisc/shell/main_id.c: Make rtems_shell_main_id static. * libmisc/shell/main_ifconfig.c: Make rtems_shell_main_ifconfig static. * libmisc/shell/main_ln.c: Make rtems_shell_main_ln static. * libmisc/shell/main_logoff.c: Make rtems_shell_main_logoff static. * libmisc/shell/main_ls.c: Make rtems_shell_main_ls static. * libmisc/shell/main_mallocinfo.c: Include <rtems/libcsupport.h>. Remove private decls of malloc_info, rtems_shell_print_unified_work_area_message. Make rtems_shell_main_malloc_info static. * libmisc/shell/main_medit.c: Remove private decl of rtems_shell_main_mdump. Make rtems_shell_main_medit static. * libmisc/shell/main_mfill.c: Make rtems_shell_main_mfill static. * libmisc/shell/main_mkdir.c: Make rtems_shell_main_mkdir static. * libmisc/shell/main_mknod.c: Make rtems_shell_main_mknod static. * libmisc/shell/main_mmove.c: Remove private decl of rtems_shell_main_mdump. Make rtems_shell_main_mmove static. * libmisc/shell/main_mount.c: Make rtems_shell_main_mount static. * libmisc/shell/main_msdosfmt.c: Make rtems_shell_main_msdos_format static. * libmisc/shell/main_mv.c: Include "internal.h". Make rtems_shell_mv_exit, rtems_shell_main_mv static. Remove private decls of strmode rtems_shell_main_cp, rtems_shell_main_rm. * libmisc/shell/main_mwdump.c: Make rtems_shell_main_mwdump static. * libmisc/shell/main_netstats.c: Make rtems_shell_main_netstats static. * libmisc/shell/main_perioduse.c: Make rtems_shell_main_perioduse static. * libmisc/shell/main_pwd.c: Make rtems_shell_main_pwd static. * libmisc/shell/main_rm.c: Include "internal.h". Make rtems_shell_rm_exit static. Remove private decl of strmode. * libmisc/shell/main_rmdir.c: Make rtems_shell_main_rmdir static. libmisc/shell/main_route.c: Make rtems_shell_main_route static. * libmisc/shell/main_setenv.c: Make rtems_shell_main_setenv static. * libmisc/shell/main_sleep.c: Make rtems_shell_main_sleep static. * libmisc/shell/main_stackuse.c: Make rtems_shell_main_stackuse static. * libmisc/shell/main_time.c: Make rtems_shell_main_time static. * libmisc/shell/main_tty.c: Make rtems_shell_main_tty static. * libmisc/shell/main_umask.c: Make rtems_shell_main_umask static. * libmisc/shell/main_unmount.c: Make rtems_shell_main_unmount static. * libmisc/shell/main_unsetenv.c: Make rtems_shell_main_unsetenv static. * libmisc/shell/main_whoami.c: Make rtems_shell_main_whoami static. * libmisc/shell/main_wkspaceinfo.c: Make rtems_shell_main_wkspace_info static.
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-0414-15/+15
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * libmisc/shell/cmds.c: Make rtems_shell_main_monitor static. * libmisc/shell/main_alias.c: Make rtems_shell_rtems_main_alias static. * libmisc/shell/main_blksync.c: Make rtems_shell_main_blksync static. * libmisc/shell/main_cat.c: Make rtems_shell_main_cat static. * libmisc/shell/main_chdir.c: Make rtems_shell_main_chdir static. * libmisc/shell/main_chmod.c: Make rtems_shell_main_chmod static. * libmisc/shell/main_chroot.c: Make rtems_shell_main_chroot static. * libmisc/shell/main_cp.c: Make rtems_shell_cp_exit, rtems_shell_main_cp static. * libmisc/shell/main_cpuuse.c: Make rtems_shell_main_cpuuse static. * libmisc/shell/main_date.c: Make rtems_shell_main_date static. * libmisc/shell/main_dd.c: Make rtems_shell_main_dd static. * libmisc/shell/main_echo.c: Make rtems_shell_main_echo static. * libmisc/shell/main_getenv.c: Make rtems_shell_main_getenv static. * libmisc/shell/main_halt.c: Make rtems_shell_main_halt static.
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-041-3/+17
| | | | | * libmisc/shell/internal.h: #include "shell.h". Add various missing decls.
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-043-17/+20
| | | | | | * libmisc/shell/cat_file.c: #include <rtems/shell.h>. * libmisc/shell/filemode.c: #include "internal.h". * libmisc/shell/shell.h: Declare functions "extern".
* 2011-12-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-041-4/+4
| | | | * libmisc/shell/shell_cmdset.c: Remove superflous casts.
* 2011-11-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-11-281-1/+1
| | | | | | | | PR 1941/cpukit * libmisc/monitor/mon-server.c, score/include/rtems/system.h: Remove use of RTEMS_offset() in favor of standard offsetof(). This was undocumented and there was only one internal use. Change noted in 4.11 release notes.
* 2011-11-10 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-11-101-3/+1
| | | | | | | | | | | | | PR 1924/cpukit * sapi/include/rtems/config.h: New fields stack_space_size, unified_work_area, and stack_allocator_avoids_work_space in rtems_configuration_table. * sapi/include/confdefs.h: Removed rtems_unified_work_area (this is now part of the Configuration). Separate work space and stack space estimate. Added CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE configuration option. * libmisc/shell/main_wkspaceinfo.c, score/src/wkspace.c, libcsupport/src/malloc_initialize.c: Update due to API changes.
* 2011-11-07 Ralf Corsepius <ralf.corsepius@rtems.org>Joel Sherrill2011-11-071-0/+1
| | | | | | PR 1952/cpukit * libmisc/untar/untar.c: Add return code for failure when unable to write file.
* 2011-10-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-261-3/+1
| | | | | * libmisc/monitor/mon-monitor.c (rtems_monitor_wakeup): Remove unused var "status" (Avoid warning).
* 2011-10-18 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-181-1/+11
| | | | * libmisc/shell/fts.c: Conditionally use var "nostat".
* 2011-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-171-1/+4
| | | | | * libmisc/monitor/mon-editor.c (rtems_monitor_task): Comment out unused vars "debugee", "rp", "fp".
* 2011-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-171-0/+4
| | | | * libmisc/shell/main_ls.c: Comment out unused var kflag.
* 2011-10-12 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-121-3/+1
| | | | | * libmisc/mouse/serial_mouse.c (serial_mouse_initialize): Remove unused var "status" (Avoid warnings).
* 2011-10-09 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-091-36/+0
| | | | | * libmisc/serdbg/serdbg.h (putDebugChar, getDebugChar): Remove duplicate decls.
* 2011-10-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-021-3/+16
| | | | | * libmisc/uuid/gen_uuid.c: Introduce PRIutime_t, SCNutime_t and "utime_t" for 64bit-time_t support.
* 2011-10-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-021-1/+11
| | | | * libmisc/shell/main_time.c: Introduce PRIdtime_t.
* 2011-09-16 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-09-163-1/+109
| | | | | | * libmisc/shell/shell-wait-for-input.c: New file. * libmisc/Makefile.am: Reflect change above. * libmisc/shell/shell.h: Declare rtems_shell_wait_for_input().
* 2011-09-15 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-09-154-35/+21
| | | | | | | * cpukit/libmisc/cpuuse/cpuuse.h, cpukit/libmisc/cpuuse/cpuusagedata.c, cpukit/libmisc/cpuuse/cpuusagereport.c, cpukit/libmisc/cpuuse/cpuusagereset.c: Fixed timestamp usage.
* 2011-09-02 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-09-021-21/+5
| | | | | * libmisc/monitor/mon-monitor.c: Removed "exit" and "quit" commands to avoid confusion. They were an alias to the "fatal" command.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* 2011-07-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-07-211-4/+4
| | | | | | * libfs/src/dosfs/fat_file.c, libmisc/monitor/monitor.h, score/cpu/m68k/rtems/score/cpu.h: Remove stray spaces from unsigned32 to uint32_t conversion.
* 2011-07-11 Sebastien Bourdeauducq <sebastien.bourdeauducq@gmail.com>Sebastian Huber2011-07-111-0/+1
| | | | | PR 1823/cpukit * libmisc/fb/fb.h: Added FBIOSETVIDEOMODE define.
* 2011-07-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-07-071-10/+10
| | | | | | * libblock/src/nvdisk-sram.c, libi2c/libi2c.c, libmisc/shell/main_msdosfmt.c: Eliminate use of GNU old-style field designator extension as recommended by clang.
* 2011-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-281-1/+1
| | | | | | | | PR 1826/cpukit * libmisc/cpuuse/cpuusagereport.c, rtems/Makefile.am, rtems/preinstall.am, rtems/include/rtems.h: Add SMP Helper methods to Classic API. * rtems/include/rtems/rtems/smp.h: New file.
* 2011-06-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-2412-20/+76
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/bspIo.h, include/rtems/concat.h, include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h, include/rtems/pci.h, include/rtems/userenv.h, libblock/include/rtems/flashdisk.h, libblock/include/rtems/nvdisk-sram.h, libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h, libcsupport/include/console.h, libcsupport/include/iosupp.h, libcsupport/include/spurious.h, libcsupport/include/motorola/mc68230.h, libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h, libcsupport/include/rtems/framebuffer.h, libcsupport/include/rtems/gxx_wrappers.h, libcsupport/include/rtems/libcsupport.h, libcsupport/include/rtems/libio_.h, libcsupport/include/rtems/malloc.h, libcsupport/include/rtems/termiostypes.h, libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h, libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h, libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h, libmisc/capture/capture-cli.h, libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h, libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h, libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h, libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h, libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h, posix/include/mqueue.h, posix/include/semaphore.h, posix/include/rtems/posix/aio_misc.h, posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/posixapi.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/sigset.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/time.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/priority.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, rtems/mainpage.h, rtems/include/rtems/rtems/barrier.h, rtems/include/rtems/rtems/object.h, rtems/include/rtems/rtems/timer.h, rtems/inline/rtems/rtems/barrier.inl, rtems/inline/rtems/rtems/timer.inl, rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h, sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h, score/include/rtems/score/object.h, score/include/rtems/score/priority.h, score/inline/rtems/score/object.inl, score/inline/rtems/score/priority.inl: Add @file Doxygen directives and descriptions to files which originated with RTEMS. This improves the file list page generated by Doxygen.
* 2011-06-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-171-8/+15
| | | | | | | | | | | | | | | | | | | * libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h, posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h, score/include/rtems/score/apiext.h, score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/timespec.h, score/include/rtems/score/timestamp.h, score/include/rtems/score/timestamp64.h, score/include/rtems/score/tod.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h: Make @brief formatting more consistent. * score/include/rtems/score/rbtree.h: Also reformat.
* 2011-06-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-161-5/+31
| | | | | | PR 1818/misc * libmisc/cpuuse/cpuusagereport.c: Add SMP support to CPU Usage Reporting.
* 2011-05-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-05-133-1/+168
| | | | | | * libmisc/devnull/devzero.c, libmisc/devnull/devzero.h: New files. * libmisc/Makefile.am, Makefile.am, preinstall.am: Reflect changes above.
* 2011-05-11 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-05-111-1/+1
| | | | * libmisc/shell/main_msdosfmt.c: Fixed NULL pointer access.
