path: root/cpukit/libmisc (follow)
* CleanupRalf Corsepius2003-07-081-12/+0
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0828-121/+170
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac. * capture/config.h: New. * capture/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * cpuuse/config.h: New. * cpuuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * devnull/config.h: New. * devnull/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * dummy/config.h: New. * dummy/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * dumpbuf/config.h: New. * dumpbuf/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * monitor/config.h: New. * monitor/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * mw-fb/config.h: New. * mw-fb/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * rtmonuse/config.h: New. * rtmonuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * serdbg/config.h: New. * serdbg/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * shell/config.h: New. * shell/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * stackchk/config.h: New. * stackchk/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * untar/config.h: New. * untar/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0831-0/+175
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * capture/capture-cli.c: Add config-header support. * capture/capture.c: Add config-header support. * cpuuse/cpuuse.c: Add config-header support. * devnull/devnull.c: Add config-header support. * dummy/dummy.c: Add config-header support. * dumpbuf/dumpbuf.c: Add config-header support. * monitor/mon-command.c: Add config-header support. * monitor/mon-config.c: Add config-header support. * monitor/mon-dname.c: Add config-header support. * monitor/mon-driver.c: Add config-header support. * monitor/mon-extension.c: Add config-header support. * monitor/mon-itask.c: Add config-header support. * monitor/mon-manager.c: Add config-header support. * monitor/mon-monitor.c: Add config-header support. * monitor/mon-mpci.c: Add config-header support. * monitor/mon-object.c: Add config-header support. * monitor/mon-prmisc.c: Add config-header support. * monitor/mon-queue.c: Add config-header support. * monitor/mon-server.c: Add config-header support. * monitor/mon-symbols.c: Add config-header support. * monitor/mon-task.c: Add config-header support. * mw-fb/mw_fb.c: Add config-header support. * mw-fb/mw_uid.c: Add config-header support. * rtmonuse/rtmonuse.c: Add config-header support. * serdbg/serdbg.c: Add config-header support. * serdbg/serdbgio.c: Add config-header support. * serdbg/termios_printk.c: Add config-header support. * shell/cmds.c: Add config-header support. * stackchk/check.c: Add config-header support. * untar/untar.c: Add config-header support.
* 2003-07-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-072-1/+5
| | | | * configure.ac: Remove RTEMS_BSP from RTEMS_CHECK_MULTIPROCESSING.
* 2003-06-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-06-042-1/+5
| | | | * stackchk/check.c: Removed warnings.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-04-172-2/+4
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-112-1/+4
* Merger from rtems-4-6-branch.Ralf Corsepius2003-02-282-33/+102
* 2003-02-14 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-02-142-1/+6
| | | | | PR 352/rtems_misc * shell/shell.c: make rtems_shell main task an FP enabled task.
* 2003-01-27 Dan Smisko <dan@balanced.com>Joel Sherrill2003-01-272-1/+7
| | | | | | * stackchk/check.c: Fix problem where _Objects_Get_information() will dereference a null pointer when checking the interrupt stack. If there's something at 0, you may be ok at run time but it is wrong.
* 2003-01-27 Dan Smisko <dan@balanced.com>Joel Sherrill2003-01-272-2/+6
| | | | * monitor/mon-command.c: Correct two potential NULL references.
* 2002-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-252-2/+6
| | | | * configure.ac: Fix tests for GCC.
* 2002-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-2415-25/+77
| | | | | | | | | | | | | | | | | | | | | * configure.ac: Add check for weak function attribute. Remove AM_CONDITIONAL([RTEMS_LIBSHELL]. Add AM_CONDITIONAL(LIBSHELL), AM_CONDITIONAL(LIBSERDBG). * capture/Makefile.am: Use *.a instead of *-tmp.a. * cpuuse/Makefile.am: Use *.a instead of *-tmp.a. * devnull/Makefile.am: Use *.a instead of *-tmp.a. * dummy/Makefile.am: Use *.a instead of *-tmp.a. * dumpbuf/Makefile.am: Use *.a instead of *-tmp.a. * monitor/Makefile.am: Use *.a instead of *-tmp.a. * mw-fb/Makefile.am: Use *.a instead of *-tmp.a. * rtmonuse/Makefile.am: Use *.a instead of *-tmp.a. * serdbg/Makefile.am: Use *.a instead of *-tmp.a. Build iff LIBSERDBG is true. * shell/Makefile.am: Use *.a instead of *-tmp.a. Build iff LIBSHELL is true. * stackchk/Makefile.am: Use *.a instead of *-tmp.a. * untar/Makefile.am: Use *.a instead of *-tmp.a. * wrapup/Makefile.am: Reflect changes above.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-1214-41/+32
| | | | | | | | | | | | | | | | | * configure.ac: Require autoconf-2.57+automake-1.7.2. * capture/Makefile.am: Eliminate C_O_FILES. * cpuuse/Makefile.am: Ditto. * devnull/Makefile.am: Ditto. * dummy/Makefile.am: Ditto. * dumpbuf/Makefile.am: Ditto. * monitor/Makefile.am: Ditto. * rtmonuse/Makefile.am: Ditto. * serdbg/Makefile.am: Ditto. * shell/Makefile.am: Ditto. * stackchk/Makefile.am: Ditto. * untar/Makefile.am: Ditto. * mw-fb/Makefile.am: Eliminate C_O_FILES. Eliminate SRCS.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-1216-59/+80
| | | | | | | | | | | | | | | | | | | | | | | Moving libmisc from rtems/c/src to rtems/cpukit. * Makefile.am: Reflect new path. * configure.ac: Reflect new path. Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP. Remove RTEMS_PROJECT_ROOT. * capture/Makefile.am: Reflect new path. Remove OBJS from all-local. * cpuuse/Makefile.am: Ditto. * devnull/Makefile.am: Ditto. * dummy/Makefile.am: Ditto. * dumpbuf/Makefile.am: Ditto. * monitor/Makefile.am: Ditto. * mw-fb/Makefile.am: Ditto. * rtmonuse/Makefile.am: Ditto. * serdbg/Makefile.am: Ditto. * shell/Makefile.am: Ditto. * stackchk/Makefile.am: Ditto. * untar/Makefile.am: Ditto. * wrapup/Makefile.am: Reflect new path.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-102-1/+4
| | | | * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-1014-13/+16
| | | | | | | | | | | | | | | | * capture/Makefile.am: Don't include @RTEMS_BSP@.cfg. * cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg. * devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg. * dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg. * dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg. * monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg. * mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg. * rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg. * serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg. * shell/Makefile.am: Don't include @RTEMS_BSP@.cfg. * stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg. * untar/Makefile.am: Don't include @RTEMS_BSP@.cfg. * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-12-032-11/+27
| | | | * stackchk/check.c: Better handling of task name.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-152-1/+8
| | | | * monitor/mon-commands.c: Removed warnings for RTEMS_UNIX.
* 2002-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-147-7/+34
| | | | | | | | | | * capture/Makefile.am: Remove AUTOMAKE_OPTIONS. * serdbg/Makefile.am: Remove AUTOMAKE_OPTIONS. * serdbg/serdbgio.c: Add #include <unistd.h>. * shell/Makefile.am: Add RTEMS_LIBSHELL conditional. * wrapup/Makefile.am: Add RTEMS_LIBSHELL conditional. * configure.ac: Check for stdio assignments. Add RTEMS_LIBSHELL conditional.
* 2002-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-012-1/+5
* 2002-10-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-312-2/+7
| | | | * stackchk/check.c: Removed warning.
* 2002-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-262-0/+7
| | | | | * monitor/mon-command.c: Don't build rtems_monitor_line_editor for RTEMS_UNIX to avoid gcc warning.
* 2002-10-24 Fabrizio Pirovano <pirovano.thysys@tiscalinet.it>Joel Sherrill2002-10-244-5/+13
| | | | | * capture/capture.c, monitor/mon-manager.c, stackchk/check.c: Patch to remove problems introduced by object name rework.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-3/+9
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-08-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-303-3/+7
| | | | | * shell/shell.c: #include <time.h> * wrapup/Makefile.am: Eliminate LIBNAME.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1113-13/+28
| | | | | | | | | | | | | | | * capture/Makefile.am: Use .$(OBJEXT) instead of .o. * cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o. * devnull/Makefile.am: Use .$(OBJEXT) instead of .o. * dummy/Makefile.am: Use .$(OBJEXT) instead of .o. * dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o. * monitor/Makefile.am: Use .$(OBJEXT) instead of .o. * mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o. * rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o. * serdbg/Makefile.am: Use .$(OBJEXT) instead of .o. * shell/Makefile.am: Use .$(OBJEXT) instead of .o. * stackchk/Makefile.am: Use .$(OBJEXT) instead of .o. * untar/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-092-1/+5
| | | | * shell/Makefile.am: Remove shell.h from EXTRA_DIST.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-022-1/+15
| | | | | * cpuuse/cpuuse.c (CPU_usage_Dump) : Corrected so it honors when an object name is raw versus being a string.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-302-0/+7
| | | | | * stackchk/check.c: Don't reference the RTEMS allocated interrupt stack if the port doesn't configure using it.
* 2002-07-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-242-2/+10
| | | | | * wrapup/Makefile.am: Temporarily don't include serdbg since it causes some BSPs to not link "main(){}" as required by autoconf.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-203-0/+7
| | | | * capture/capture.c: include <string.h> for memset.
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-016-41/+58
| | | | | | | | * capture/capture-cli.c, cpuuse/cpuuse.c, monitor/mon-monitor.c, monitor/mon-object.c, monitor/monitor.h: Corrected use of _Objects_Information_table now that it is a two dimensional array based upon API and class. In addition, in the monitor, corrected an error which occured when a target has 64 bit pointers.
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-012-12/+22
| | | | | | * stackchk/check.c: Corrected use of _Objects_Information_table now that it is a two dimensional array based upon API and class.
* 2002-06-25 Thomas Doerfler <Thomas.Doerfler@imd-systems.de>Joel Sherrill2002-06-2714-2/+1198
| | | | | | | | | | | | * With the addition of serdbg, the standard polled I/O functions for gdbstub and/or printk are optionally routed to any termios-aware device driver, that supports polled mode. See libmisc/serdbg/README. * serdbg/Makefile.am, serdbg/README, serdbg/serdbg.c, serdbg/serdbg.h, serdbg/serdbgcnf.h, serdbg/serdbgio.c, serdbg/termios_printk.c, serdbg/termios_printk.h, serdbg/termios_printk_cnf.h, serdbg/.cvsignore: New files. * configure.ac, Makefile.am, wrapup/Makefile.am: Modified to reflect addition.
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-262-9/+6
| | | | * wrapup/Makefile.am: Don't preinstall libmisc.a.
* 2002-05-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-243-2/+5
| | | | * coinfigure.ac, Makefile.am: Remove references to rootfs.
* 2002-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-173-7/+9
| | | | | | | | | * rootfs/.cvsignore: Remove. * rootfs/Makefile.am: Remove. * rootfs/mkrootfs.h: Remove. * rootfs/mkrootfs.c: Remove. * configure.ac: Remove rootfs and NETWORKING macros. * wrapup/Makefile.am: Remove rootfs and HAS_NETWORKING.
* 2002-05-16 Chris Johns <ccj@acm.org>Joel Sherrill2002-05-1511-3/+4206
| | | | | | | | | * Per PR194, added the Capture engine. * capture/Makefile.am, capture/README, capture/capture-cli.c, capture/capture-cli.h, capture/capture.c, capture/capture.h, capture/.cvsignore: New files. * Makefile.am, configure.ac, wrapup/Makefile.am: Modified to reflect addition.
* 2001-05-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-143-10/+12
| | | | | * dummy/Makefile.am, wrapup/Makefile.am: Fixed to generate a library of the same name.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-05-012-2/+9
| | | | | | | * monitor/mon-command.c: Per PR192 the RTEMS monitor makes everything lowercase. The capture engine need to set triggers or watches on task with uppercase names. Also stop the monitor repeating command when enter is pressed.
* 2002-04-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-042-4/+6
| | | | * monitor/mon-monitor.c: Replace done with return (gcc3).
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2814-14/+21
| | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * cpuuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * devnull/Makefile.am: Remove AUTOMAKE_OPTIONS. * dummy/Makefile.am: Remove AUTOMAKE_OPTIONS. * dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS. * monitor/Makefile.am: Remove AUTOMAKE_OPTIONS. * mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS. * rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtmonuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * shell/Makefile.am: Remove AUTOMAKE_OPTIONS. * stackchk/Makefile.am: Remove AUTOMAKE_OPTIONS. * untar/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-202-0/+10
| | | | | * PR148. * monitor/mon-prmisc.c: Fixed to print task states correctly.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-1/+4
| | | | * shell/shell.c: Remove #undef __STRICT_ANSI__.
* 2002-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-081-0/+4
| | | | * rootfs/Makefile.am: Use include_rtems_HEADERS instead of H_FILES.
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-042-1/+10
| | | | * mw-fb/mw_uid.c: Apply rtems_set_errno_and_return_minus_one.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-121-0/+4
| | | | * rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+50
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-0/+7
