This adds some commands that are usefull for debugging simple serial
interfaces.
Even if they are a complete re-implementation, the i2c* commands use a
simmilar call like the Linux i2c tools.
An automatic link from every place in the documentation which mentions
"IO" to this dd command internal "IO" typedef is not really nice.
The compiler warning was:
../../../cpukit/libmisc/rtems-fdt/rtems-fdt.c:267:5: warning:
'strncpy' specified bound depends on the length of the source argument
267 | strncpy(path, name, namelen);
It turns out that the `strncpy()` nor the buffer `path` is needed when
one uses `strncmp()` instead of `strcmp()`. This needs some change to
the algorithm but has the advantage that `name` is never truncated
to the size of the buffer `path`.
This reverts commit 355bc37ad35a7d67a7209130171febe805c67f62.
Note:
rtems-fdt.c, rtems-fdt-shell.c and cpukit/include/rtems/rtems-fdt.h
seem to be dead code. They implement a shell command `fdt` but that
command is not part of the shell nor of any macro in
cpukit/include/rtems/shellconfig.h.
Using strlcpy() instead of strncpy():
1) Prevents the compiler warnings
2) Ensures, the string is NUL terminated.
3) Avoids that strncpy() unnecessary fills the unused part of the buffer with
0 bytes.
(Note that realpath() also returns NULL if the file does not exist - that
happens always if someone creates a new file with the editor of the shell.)
realpath() requires a buffer of size PATH_MAX and not of size
FILENAME_MAX according to 'man realpath (3)'.
This is an illegal use of strcpy() because one is not allowed to
use this function with overlapping source and destination buffers;
whereas memmove() is explicitly designed to handle such cases.
The copiler warning was:
../../../cpukit/libmisc/shell/shell.c:626:13: warning:
'strcpy' accessing between 1 and 2147483645 bytes at offsets
0 and [1, 2147483647] may overlap up to 2147483644 bytes at
offset [1, 2147483644] [-Wrestrict]
With some compiler warnings enabled, the implicit cast may trigger
a compiler warning. The explicit cast avoids this.
The shell has an 'fdisk' command which has sub-commands 'mount' and 'unmount'.
These two sub-commands have a bug which causes them to be not able
to mount anything. This proposed patch removes the buggy file
cpukit/libblock/src/bdpart-mount.c and the mount/unmount commands
from 'fdisk' as bug fix. The 'fdisk' command itself is not removed.
The reasons for removing the sub-commands (instead of fixing the issue) are:
1) The bug has been introduced on 2010-May-31 with commit
29e92b090c8bc35745aa5c89231ce806bcb11e57. Since ten years no one
can use this feature, nor has anybody complained about it.
2) Besides of the 'fdisk' 'mount' sub-command, the shell has the
usual 'mount' and 'unmount' commands which can serve as
substitutes.
3) There are additional minor issues (see further down) which needed to
be addressed when the file will be kept.
What follows below is the precise bug description.
The bug is in function rtems_bdpart_mount() which is only be used
by the 'fdisk' shell command to mount all partitions of a disk with a
single command:
> fdisk DISK_NAME mount
> mounts the file system of each partition of the disk
> fdisk DISK_NAME unmount
> unmounts the file system of each partition of the disk
The whole command does not work because in file
cpukit/libblock/src/bdpart-mount.c line 103 specifies the file system type
of each partition to be "msdos". Yet, "msdos" does not exist. The name
must be "dosfs".
Beside of this fundamental problem, there are more issues with the code
in bdpart-mount.c:
1) The function returns RTEMS_SUCCESSFUL despite the mount always fails.
2) The reason for errors is not written to the terminal.
3) The directory '/mnt' is created but not deleted later on (failure or not).
3) There is no documentation about this special 'fdisk' feature in the
RTEMS Shell Guide ('fdisk' is mentioned but its documentation is a
bit short):
https://docs.rtems.org/branches/master/shell/
file_and_directory.html#fdisk-format-disk
4) Only "msdos" formatted partitions can be mounted and all partitions
are mounted read-only. This is hard coded and cannot be changed by
options. Moreover, there is no information about this to the user of
the shell (i.e. using 'fdisk' mount requires insider knowledge).
How to reproduce:
1) For testing, I use the 'testsuites/samples/fileio.exe' sample with qemu:
> cd rtems
> env QEMU_AUDIO_DRV="none" qemu-system-arm -net none -nographic \
> -M realview-pbx-a9 -m 256M -kernel \
> build/arm/realview_pbx_a9_qemu/testsuites/samples/fileio.exe
2) Type any key to stop the timer and enter the sample tool.
Type 's' to enter the shell, login as 'root' with the password
shown in the terminal.
3) Type the following shell commands (they create a RAM disk,
partition it, register it, format it and try to mount it):
> mkrd
> fdisk /dev/rda fat32 16 write mbr
> fdisk /dev/rda register
> mkdos /dev/rda1
> fdisk /dev/rda mount
4) The last line above is the command which fails - without an error
message. There exists a '/mnt' directory but no '/mnt/rda1' directory
as it should be:
> ls -la /mnt
5) If you change line 103 of 'cpukit/libblock/src/bdpart-mount.c'
from "msdos" to "dosfs", compile and build the executable and
re-run the above test, '/mnt/rda1' exists (but the file system
is mounted read-only).
Close #4131
This is actually an illegal use of strcpy() because one is not allowed to
use this function with overlapping source and destination buffers; whereas
../../../cpukit/libmisc/monitor/mon-editor.c:342:15: warning:
'strcpy' accessing 1 byte at offsets [0, 75] and [0, 75] overlaps
1 byte at offset [0, 74] [-Wrestrict]
rtems_name is a four byte integer.
Giving an rtems_name as value instead of a pointer to ctrace_task_name_add()
fixes not only the compiler warning but it is also a bit more safe
For those who have asked for the warning:
../../../cpukit/libmisc/capture/capture_support.c:352:49: warning:
taking address of packed member of 'struct rtems_capture_task_record'
may result in an unaligned pointer value [-Waddress-of-packed-member]
352 | ctrace_task_name_add (rec_out->task_id, &task_rec.name);
This patch fixes a tiny bug in the command line editing of the RTEMS shell.
Typing CTRL-U in the shell should remove all characters left of the cursor.
After pressing CTRL-U, the current implementation does wrongly place the cursor
at the end of the line instead at its beginning.
To reproduce the bug, start the shell and type 'abc123' (no <RETURN>):
> ~/src/rtems $ qemu-system-arm -net none -nographic -M realview-pbx-a9 \
-m 256M -kernel build/arm/realview_pbx_a9_qemu/testsuites/libtests/dl10.exe
> *** BEGIN OF TEST libdl (RTL) 10 ***
> *** TEST VERSION: 6.0.0.d9bdf166644f612dd628fe4951c12c6f8e94ba5f
> *** TEST STATE: USER_INPUT
> *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> *** TEST TOOLS: 10.2.1 20200904 \
(RTEMS 6, RSB 31f936a7b74d60bda609a9960c6e1a705ba54974, Newlib a0d7982)
> RTL (libdl) commands: dl, rtl
> RTEMS Shell on /dev/foobar. Use 'help' to list commands.
> SHLL [/] # abc123
Then move the cursor onto the '1' by hitting three times the <ARROW-LEFT> key.
Next type <CTRL>-U:
> SHLL [/] # 123
Note that the cursor is at the end of the line (after '3') instead of correctly
at the beginning (on the '1'), now.
Continuing typing 'echo ' incorrectly results in the output:
> SHLL [/] # 123echo 123
The patch changes this behavior so that the cursor in the second last step will
be on the '1' and typing 'echo ' will then correctly reflected as:
> SHLL [/] # echo 123
Close #4097.
Add Message_queue_Control::is_global if RTEMS_MULTIPROCESSING is defined. This
reduces the Message_queue_Control size in standard RTEMS configurations.
Update #4007.
Provide the default trace data in a separate file to avoid issues on targets
with a small-data area.
Close #3883.
swab(3) has restrict qualifiers for src and dst.
Avoid relying on undefined overlapping swab behavior.
Obtained From: OpenBSD
The argument to the ctype functions must be an int and the value of the
character must be representable as an unsigned char or equal to the
value of the macro EOF. If the argument has any other value, the
behavior is undefined.
Clearing the std file handles when the main loop exited crashes
telnetd as it reuses its session threads.
Update #3973.
Update #3970.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
- Fix the passing of std[in/out] to child threads
- Fix deleting of managed memory in the key destructor
- Only set the key in the main loop thread
- Only allocate a shell env outside of the main loop
- Fix memory leak if the task start fails
- Remove error level from shell env, it cannot be returned this way. Add
exit_code but the API is broken so it cannot be returned.
Closes #3859
In uniprocessor and SMP configurations, the context switch extensions
were called during _Thread_Do_dispatch():
void _Thread_Do_dispatch( Per_CPU_Control *cpu_self, ISR_Level level )
Thread_Control *executing;
executing = cpu_self->executing;
do {
Thread_Control *heir;
heir = _Thread_Get_heir_and_make_it_executing( cpu_self );
_User_extensions_Thread_switch( executing, heir );
_Context_Switch( &executing->Registers, &heir->Registers );
} while ( cpu_self->dispatch_necessary );
In uniprocessor configurations, this is fine and the context switch
extensions are called for all thread switches except the very first
thread switch to the initialization thread. However, in SMP
configurations, the context switch may be invalidated and updated in the
low-level _Context_Switch() routine. See:
https://docs.rtems.org/branches/master/c-user/symmetric_multiprocessing_services.html#thread-dispatch-details
In case such an update happens, a thread will execute on the processor
which was not seen in the previous call of the context switch
extensions. This can confuse for example event record consumers which
use events generated by a context switch extension.
Fixing this is not straight forward. The context switch extensions call
must move after the low-level context switch. The problem here is that
we may end up in _Thread_Handler(). Adding the context switch
extensions call to _Thread_Handler() covers now also the thread switch
to the initialization thread. We also have to save the last executing
thread (ancestor) of the processor. Registers or the stack cannot be
used for this purpose. We have to add it to the per-processor
information. Existing extensions may be affected, since now context
switch extensions use the stack of the heir thread. The stack checker
is affected by this.
Calling the thread switch extensions in the low-level context switch is
difficult since at this point an intermediate stack is used which is
only large enough to enable servicing of interrupts.
Update #3885.
Move the is SMP enabled configuration constant out of the
configuration table.
Since this was the last configuration constant in
rtems_configuration_table, remove this type.
Update #3875.
With the removal of the CONFIGURE_HAS_OWN_INIT_TASK_TABLE configuration
option at most one Classic API user initialization task can be
configured.
Provide an RTEMS API configuration table for backward compatibility.
Update #3873.
Use a dedicated system initialization step for the stack checker
interrupt stack support.
Update #3838.
- This patch is based on the patch attached to #3552 submitted
by jameszxj.
Closes #3552
Update #3753.
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
Move variant, discipline, and global information to flags stored in a
node pointer of active semaphores.
Update #3833.
Close #3823.
Close #3823.
Update #3823.
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Add and use _Thread_Get_unmapped_real_priority().
Do not use the rtems_error() function since this function pulls in
exit() and abort(). The abort() function pulls in raise() which pulls
in the whole POSIX signals support. This change saves about 16KiB of
text/rodata on ARM Thumb-2 systems.
Update #3732.
Add rtems_scheduler_get_processor() as a replacement for
rtems_get_current_processor(). The rtems_get_current_processor() is a
bit orphaned. Adopt it by the Scheduler Manager. This is in line with
the glibc sched_getcpu() function.
Deprecate rtems_get_current_processor().
Update #3731.
One reason to move the test support into a dedicated library are the
standard output __wrap_*() functions. They may conflict with
application level wrappers.
Update #3199.
Close #3720.
This makes the @file documentation independent of the actual file name.
Update #3707.
Closes #3684
