Print wait object identifier only if it exists.
Update #2858.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Add the special thread queue name _Thread_queue_Object_name to mark
thread queues embedded in an object with identifier. Using the special
thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for
this purpose since the thread wait information and thread state are
protected by different SMP locks in separate critical sections. Remove
STATES_THREAD_QUEUE_WITH_IDENTIFIER.
Add and use _Thread_queue_Object_initialize().
Update #2858.
Update #2803.
Update #2858.
Replace STATES_DELAYING with STATES_WAITING_FOR_TIME.
There is no need for separate timeout thread states. The
Thread_Control::Timer::header and Watchdog_Control::cpu members can be
used to figure out the kind of timeout.
Add thread state bit to identify thread queues that are embedded in an
Update #2825.
Initialize thread queue context early preferably outside the critical
section.
Remove implicit _Thread_queue_Context_initialize() from
_Thread_Wait_acquire().
Determine worker index via the current processor index to get consistent
job runs with respect to the cache topology.
Replace Thread_Scheduler_control::control and
Thread_Scheduler_control::own_control with new
Thread_Scheduler_control::home.
Update #2556.
Update #2556.
Update #2423.
Update #2423.
Add support to untar XZ compressed files.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Avoid direct access to thread internal data fields.
Commit 0fd6f25507fbea5f4892b71b58837cdda17856b4 relaxed the thread begin
extension execution environment. This broke the stack check which only
partially initialized the stack pattern in its create extension. Move
the part of the begin extension to the create extension.
Move the 64-bit field to a not 64-bit aligned structure offset to stop
the compiler from generating 64-bit load/store operations.
This patches some issues with the capture engine:
1. Check is the engine is open in ctrace commands.
2. Check all record open and appends for overflow.
3. Fix the record open to take the size of user data and
not the record header.
4. Use packed structs for data being written to the per
cpu buffers.
5. Remove direct struct access to the capture buffers to
avoid misaligned accesses.
6. Add support to extract records, no struct access to the
capture buffers.
7. Update ctrace to extract records from the capture buffers.
8. Add support to ctrace to always print the task name if it
has one.
9. Add support to manage names or the lack of a name.
10. Range of minor fixes.
11. Fix a long standing bug in ctset's handling of args.
Closes #2780.
This patch parses the mode field in the tar header and sets the
directory or file to the mode value in the header.
Closes #2768.
The _Thread_Lock_acquire() function had a potentially infinite run-time
due to the lack of fairness at atomic operations level.
Update #2412.
Update #2556.
Update #2765.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
Use same structure as POSIX API for thread priority conversion to/from
SuperCore.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
Rename RTEMS_PRINTF_ATTRIBUTE() into RTEMS_PRINTFLIKE() (similar to
<sys/cdefs.h> __printflike()) and move it to <rtems/score/basedefs.h>.
Support creating directories for files with a path depth greater than 1. Some
tar files can have files with a path depth greater than 1 and no directory
entry in the tar file to create a directory.
Support overwriting existing files and directories failing in a similar
way to tar on common hosts. If a file is replaced with a file delete the
file and create a new file. If a directory replaces a file remove the file
and create the directory. If a file replaces a directory remove the directory,
and if the directory is not empty and cannot be removed report an error. If a
directory alreday exists do nothing leaving the contents untouched.
The untar code now shares the common header parsing and initial processing
with the actual writes still separate. No changes to the IMFS have been made.
Updates #2415.
Closes #2207.
Demonstrate that a read-modify-write atomic operation may be necessary
on some archtitectures to observe the latest value written.
Update #2723.
