Update #3132.
Update #3122.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Update #2132.
Update #2133.
Update #3082.
- Provide application support for handling FDT blobs in RTEMS. This
is useful when interfacing FPGA fabrics.
- Provide a shell command to list a blob as well as provide read
and write access to addresses in the FTB.
Closes #3099.
- Add 'rtems_shell_init_environment()' so a user can create the
shell environment without needing to run a shell.
- Move 'rtems_shell_lookup_topic', 'rtems_shell_can_see_cmd',
and 'rtems_shell_execute_cmd' from the internal interface to
the public interface.
Closes #3096.
This avoids an unnecessary use of the floating point unit.
Update #3076.
Update #2909.
Update #3056.
Display the scheduler name instead of the current CPU in the "task"
shell command. The current CPU could be misleading in case locking
protocols are involved. The "cpuuse" command can be used to obtain the
current CPU.
This reverts c475924d6d2ea7d5cba160a8a28e88642d6b46d8.
Update #2909.
Close #2994.
Update #2833.
Closes #2997.
Provide extentions to <inttpes.h> PRIxxx constants for more POSIX types.
Start with existing definitions found in RTEMS Project owned code
in cpukit/.
updates #2983.
close #2909.
Print wait object identifier only if it exists.
Update #2858.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Add the special thread queue name _Thread_queue_Object_name to mark
thread queues embedded in an object with identifier. Using the special
thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for
this purpose since the thread wait information and thread state are
protected by different SMP locks in separate critical sections. Remove
STATES_THREAD_QUEUE_WITH_IDENTIFIER.
Add and use _Thread_queue_Object_initialize().
Update #2858.
Update #2803.
Update #2858.
Replace STATES_DELAYING with STATES_WAITING_FOR_TIME.
There is no need for separate timeout thread states. The
Thread_Control::Timer::header and Watchdog_Control::cpu members can be
used to figure out the kind of timeout.
Add thread state bit to identify thread queues that are embedded in an
Update #2825.
Initialize thread queue context early preferably outside the critical
section.
Remove implicit _Thread_queue_Context_initialize() from
_Thread_Wait_acquire().
Determine worker index via the current processor index to get consistent
job runs with respect to the cache topology.
Replace Thread_Scheduler_control::control and
Thread_Scheduler_control::own_control with new
Thread_Scheduler_control::home.
Update #2556.
Update #2556.
Update #2423.
Update #2423.
Add support to untar XZ compressed files.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
