* monitor/mon-prmisc.c: Correct print line.
* shell/Makefile.am: Added new file telnetd.c.
* shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files.
* shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments:
- The shell_init has a new parameter 'forever' because in
/dev/console you need that this process runs forever but in
tcp/ip not. (respawn?)
- A new task for every session opened trought tcp/ip telnet client.
(the chargen,daytime and more are possible of implementation but
I ask me if they are necesary)
- Exit from the session delete the task and when the client fails too.
- More cmds have been implemented. (very reduced version of these)
umask, chmod, id, whoami, rm, cat, ...
- A reduced line edit has been implemented.
Ctrl-C abort the input,
Ctrl-d in the first position gives EOF (logout).
'\b' and DEL makes the rubout operation.
I think that readline() for every session spents a lot of resources.
* shell/cmds.c, shell/shell.c: Remove fileno-hacks.
* monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__.
* Added initial shell functionality.
* Makefile.am, configure.in, wrapup/Makefile.am:
* shell/.cvsignore, shell/Makefile.am, shell/README,
shell/cmds.c, shell/shell.c, shell/shell.h: New files.
* devnull/devnull.c (null_initialize): Added check to
ensure that the driver is only initialized once. Otherwise,
it will abort when the device /dev/null is present.
(null_write): Do not dereference a NULL pointer.
* monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* devnull: New addition. Moved from libcpu/sh.
* devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore,
devnull/Makefile.am: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect
addition of above.
* mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>.
* monitor/mon-driver.c: Accounted for addition of "_entry" to
fields in rtems_driver_address_table.
* cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am,
monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am,
untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am:
Include compile.am.
all APIs.
* mw-fb/.cvsignore: New file.
* Added generic Micro FrameBuffer interface for MicroWindows.
This interface allows MicroWindows to under RTEMS. A sample
driver has been developed for the pc386 BSP. See
pc386/fb_vga.c as a sample.
* Added Uniform Input Device interface for MicroWindows.
See PC386 bsp for sample drivers for mouse and keyboard (console).
* mw-bf: New directory.
* Makefile.am, configure.in, wrapup/Makefile.am: Account for mw-fb.
* mw-fb/Makefile.am: New file.
* mw-fb/mw_fb.c: New file.
* mw-fb/mw_fb.h: New file.
* mw-fb/mw_uid.c: New file.
* mw-fb/mw_uid.h: New file.
that breaks when the target has 16 bit address space. One of the H8
multilibs is a 16-bit address space CPU. When a real attempt is
made to support this CPU model, the code that assumes an address
is 32 bits will have to change. This constant is probably not
flagging all impacted code.
to:
I have also added the ability to register and unregister commands. This
allows me to create a set of monitor commands for the network stack plus
basic memory dump/patch commands (needs a working probe interface). I
will also look at a basic ls/cd/rm/mv/cp command set at some stage.
I have been thinking about changing the monitor in the future to more
like a light weight RTEMS shell, `eshell' for embedded shell. This is a
story for another day but is a process or getting the commands to map to
the filesystem (eg, major=commands, minor=command) and supporting an
environment. The filesystem provide a structure for the commands.
that contains:
* Removes MKLIB
handling)
converted to automake.
to convert the libmisc directory from Makefile.in to Makefile.am.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
are a dummy for linking programs together when you are primarily
concerned with tricking another package into building.
This may grow into something which could help link programs on
the command line by having a default start sequence.
c/src/lib/libmisc to c/src/libmisc.
avoid cyclic dependencies generated when moving packages to the
top level.
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
defined.
Include files now installed as <rtems/*.h>.
it work.
This makes the headings line up above the columns a little better.
Now that it's so easy to include/exclude the stack check code I find
myself adding it to all my `debug' targets.
