Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
Check the interrupt stacks of all processors. Set up the interrupt
stack of the current processor for high water testing in the thread
begin extension. This must be done after multi-threading started, since
the initialization stacks may reuse the interrupt stacks. Disable
thread dispatching in SMP configurations to prevent thread migration.
Writing to the interrupt stack is only safe if done from the
corresponding processor in thread context.
Update #3459.
Update #3459.
Update #3459.
Do not set the CONFIGURE_MAXIMUM_PROCESSORS in uni-processor default
configuration, since this may lead to an oversize workspace.
Update #3459.
Do not discard a user provided task name in rtems_shell_init_env().
Update #2843.
Update #2843.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3260.
Prepare for header file move to common include directory.
Update #3254.
Update #3254.
Update #3254.
Update #3254.
Update #3254.
Update #3254.
Stack_check_Dump_threads_usage
Pointers were being printed as 0x<decimal> rather than 0x<hex>. I altered the formatting define used
to give the correct formatting.
Close #3240
- Remove the macro defines and the need for tmacro.h by remapping the
symbols using ld's wrap option.
- Remove FLUSH_OUTPUT, it was empty.
- Move rtems_test_exit to libmisc/testsupport as a function.
Update #3199.
Add a tests enum and move all test banner test to the library in libmisc.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
Closes #2829.
Update #3132.
Update #3122.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Update #2132.
Update #2133.
Update #3082.
- Provide application support for handling FDT blobs in RTEMS. This
is useful when interfacing FPGA fabrics.
- Provide a shell command to list a blob as well as provide read
and write access to addresses in the FTB.
Closes #3099.
- Add 'rtems_shell_init_environment()' so a user can create the
shell environment without needing to run a shell.
- Move 'rtems_shell_lookup_topic', 'rtems_shell_can_see_cmd',
and 'rtems_shell_execute_cmd' from the internal interface to
the public interface.
Closes #3096.
This avoids an unnecessary use of the floating point unit.
Update #3076.
Update #2909.
Update #3056.
Display the scheduler name instead of the current CPU in the "task"
shell command. The current CPU could be misleading in case locking
protocols are involved. The "cpuuse" command can be used to obtain the
current CPU.
This reverts c475924d6d2ea7d5cba160a8a28e88642d6b46d8.
Update #2909.
Close #2994.
Update #2833.
Closes #2997.
Provide extentions to <inttpes.h> PRIxxx constants for more POSIX types.
Start with existing definitions found in RTEMS Project owned code
in cpukit/.
updates #2983.
