PR 352/rtems_misc
* shell/shell.c: make rtems_shell main task an FP enabled task.
* stackchk/check.c: Fix problem where _Objects_Get_information()
will dereference a null pointer when checking the interrupt stack.
If there's something at 0, you may be ok at run time but it is wrong.
* monitor/mon-command.c: Correct two potential NULL references.
* configure.ac: Fix tests for GCC.
* configure.ac: Add check for weak function attribute.
Remove AM_CONDITIONAL([RTEMS_LIBSHELL].
Add AM_CONDITIONAL(LIBSHELL), AM_CONDITIONAL(LIBSERDBG).
* capture/Makefile.am: Use *.a instead of *-tmp.a.
* cpuuse/Makefile.am: Use *.a instead of *-tmp.a.
* devnull/Makefile.am: Use *.a instead of *-tmp.a.
* dummy/Makefile.am: Use *.a instead of *-tmp.a.
* dumpbuf/Makefile.am: Use *.a instead of *-tmp.a.
* monitor/Makefile.am: Use *.a instead of *-tmp.a.
* mw-fb/Makefile.am: Use *.a instead of *-tmp.a.
* rtmonuse/Makefile.am: Use *.a instead of *-tmp.a.
* serdbg/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSERDBG is true.
* shell/Makefile.am: Use *.a instead of *-tmp.a.
Build iff LIBSHELL is true.
* stackchk/Makefile.am: Use *.a instead of *-tmp.a.
* untar/Makefile.am: Use *.a instead of *-tmp.a.
* configure.ac: Require autoconf-2.57+automake-1.7.2.
* capture/Makefile.am: Eliminate C_O_FILES.
* cpuuse/Makefile.am: Ditto.
* devnull/Makefile.am: Ditto.
* dummy/Makefile.am: Ditto.
* dumpbuf/Makefile.am: Ditto.
* monitor/Makefile.am: Ditto.
* rtmonuse/Makefile.am: Ditto.
* serdbg/Makefile.am: Ditto.
* shell/Makefile.am: Ditto.
* stackchk/Makefile.am: Ditto.
* untar/Makefile.am: Ditto.
* mw-fb/Makefile.am: Eliminate C_O_FILES.
Eliminate SRCS.
Moving libmisc from rtems/c/src to rtems/cpukit.
* Makefile.am: Reflect new path.
* configure.ac: Reflect new path.
Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP.
Remove RTEMS_PROJECT_ROOT.
* capture/Makefile.am: Reflect new path.
Remove OBJS from all-local.
* mw-fb/Makefile.am: Ditto.
* wrapup/Makefile.am: Reflect new path.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* capture/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shell/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* untar/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* stackchk/check.c: Better handling of task name.
* monitor/mon-commands.c: Removed warnings for RTEMS_UNIX.
* capture/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serdbg/serdbgio.c: Add #include <unistd.h>.
* shell/Makefile.am: Add RTEMS_LIBSHELL conditional.
* wrapup/Makefile.am: Add RTEMS_LIBSHELL conditional.
* configure.ac: Check for stdio assignments.
* stackchk/check.c: Removed warnings.
* stackchk/check.c: Removed warning.
* monitor/mon-command.c: Don't build rtems_monitor_line_editor for
RTEMS_UNIX to avoid gcc warning.
* capture/capture.c, monitor/mon-manager.c, stackchk/check.c:
Patch to remove problems introduced by object name rework.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* shell/shell.c: #include <time.h>
* wrapup/Makefile.am: Eliminate LIBNAME.
* capture/Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Use .$(OBJEXT) instead of .o.
* dummy/Makefile.am: Use .$(OBJEXT) instead of .o.
* dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o.
* monitor/Makefile.am: Use .$(OBJEXT) instead of .o.
* mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* serdbg/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Use .$(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use .$(OBJEXT) instead of .o.
* untar/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Remove shell.h from EXTRA_DIST.
* cpuuse/cpuuse.c (CPU_usage_Dump) : Corrected so it honors when an
object name is raw versus being a string.
* stackchk/check.c: Don't reference the RTEMS allocated interrupt
stack if the port doesn't configure using it.
* wrapup/Makefile.am: Temporarily don't include serdbg since it
causes some BSPs to not link "main(){}" as required by autoconf.
* capture/capture.c: include <string.h> for memset.
* capture/capture-cli.c, cpuuse/cpuuse.c, monitor/mon-monitor.c,
monitor/mon-object.c, monitor/monitor.h: Corrected use of
_Objects_Information_table now that it is a two dimensional
array based upon API and class. In addition, in the monitor,
corrected an error which occured when a target has 64 bit pointers.
* stackchk/check.c: Corrected use of
* With the addition of serdbg, the standard polled I/O functions
for gdbstub and/or printk are optionally routed to any termios-aware
device driver, that supports polled mode. See libmisc/serdbg/README.
* serdbg/Makefile.am, serdbg/README, serdbg/serdbg.c, serdbg/serdbg.h,
serdbg/serdbgcnf.h, serdbg/serdbgio.c, serdbg/termios_printk.c,
serdbg/termios_printk.h, serdbg/termios_printk_cnf.h,
serdbg/.cvsignore: New files.
* configure.ac, Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
* wrapup/Makefile.am: Don't preinstall libmisc.a.
* coinfigure.ac, Makefile.am: Remove references to rootfs.
* rootfs/.cvsignore: Remove.
* rootfs/Makefile.am: Remove.
* rootfs/mkrootfs.h: Remove.
* rootfs/mkrootfs.c: Remove.
* configure.ac: Remove rootfs and NETWORKING macros.
* wrapup/Makefile.am: Remove rootfs and HAS_NETWORKING.
* Per PR194, added the Capture engine.
* capture/Makefile.am, capture/README, capture/capture-cli.c,
capture/capture-cli.h, capture/capture.c, capture/capture.h,
capture/.cvsignore: New files.
* Makefile.am, configure.ac, wrapup/Makefile.am: Modified to
reflect addition.
* dummy/Makefile.am, wrapup/Makefile.am: Fixed to generate
a library of the same name.
* monitor/mon-command.c: Per PR192 the RTEMS monitor makes everything
lowercase. The capture engine need to set triggers or watches on task
with uppercase names.
Also stop the monitor repeating command when enter is pressed.
* monitor/mon-monitor.c: Replace done with return (gcc3).
* devnull/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dummy/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shell/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR148.
* monitor/mon-prmisc.c: Fixed to print task states correctly.
* shell/shell.c: Remove #undef __STRICT_ANSI__.
* rootfs/Makefile.am: Use include_rtems_HEADERS instead of H_FILES.
* mw-fb/mw_uid.c: Apply rtems_set_errno_and_return_minus_one.
* rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* configure.in: Remove.
* dummy/dummy.c: Now a useful configuration that starts main().
* wrapup/Makefile.am: Include a base level configuration in
RTEMS library.
* untar/Makefile.am: Use 'PREINSTALL_FILES ='.
* monitor/Makefile.am: Use 'PREINSTALL_FILES ='.
* shell/Makefile.am: Use 'PREINSTALL_FILES ='.
* devnull/Makefile.am: Use 'PREINSTALL_FILES ='.
* dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='.
* mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='.
* stackchk/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* ChangeLog: Fixed typo in date.
* configure.in, rootfs/Makefile.am: Added conditional to make sure
rootfs does not get built with networking is disabled. Also
added include of compile.am to rootfs/Makefile.am.
* wrapup/Makefile.am: Added rootfs conditionally if networking enabled.
* Added support for populating the initial "root" filesystem
with information obtained via the DHCP response.
* rootfs: New directory.
* rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c,
rootfs/mkrootfs.h: New files.
* configure.in, Makefile.am: Modified to reflect addition.
* ChangeLog: Fixed some mistakes.
* devnull/devnull.c: Eliminate warning.
