* libmisc/untar/untar.c (_rtems_octal2ulong): Replace.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_load_tar.c,
libmisc/untar/untar.c, libmisc/untar/untar.h:
Various generalizations and fixes.
* Makefile.am: Add include/rtems/tar.h.
Merge-in header rules from libmisc/Makefile.am
* libmisc/Makefile.am: Remove header rules.
Remove lib-specific CPPFLAGS.
* configure.ac: Add checks for <tar.h>
* itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am,
libfs/Makefile.am, libmisc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am:
Remove AM_CPPFLAGS += -I$(top_builddir).
* libmisc/untar/untar.h: New prototype to eleminate warnings.
* libmisc/untar/untar.c: Cosmetics, add symlinks.
* libmisc/fsmount/fsmount.c: Include config.h.
* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/monitor/monitor.h, libmisc/rtmonuse/rtmonuse.h,
libmisc/shell/shell.h: Partial doxygenification.
* libmisc/capture/capture.h: Use INT32_C for constants.
* libmisc/monitor/mon-manager.c, libmisc/monitor/mon-object.c: Remove
references to _Object_Is_local in single processor configurations.
* monitor/monitor.h: Let rtems_monitor_config_dump return int.
* monitor/mon-config.c: Ditto. Use PRI*N macros.
* monitor/mon-itask.c, monitor/mon-prmisc.c: Use PRI*N macros.
* monitor/mon-prmisc.c, monitor/monitor.h: Let rtems_monitor_dump
return int's not uint32_t (They are printf return values).
* libmisc/monitor/mon-prmisc.c, libmisc/monitor/monitor.h:
rtems_monitor_dump_char(char ch).
* configure.ac, libmisc/cpuuse/README, libmisc/stackchk/README,
librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am,
score/include/rtems/score/mppkt.h: i960 obsoleted and all references
removed.
* libmisc/stackchk/check.c: Spacing.
PR 677/misc
* libmisc/dumpbuf/dumpbuf.h, libmisc/fsmount/fsmount.h,
libmisc/rtmonuse/rtmonuse.h, libmisc/serdbg/serdbg.h,
libmisc/serdbg/serdbgcnf.h, libmisc/serdbg/termios_printk.h,
libmisc/serdbg/termios_printk_cnf.h, libmisc/untar/untar.h: Add
extern C wrappers.
* libmisc/capture/capture-cli.c, libmisc/cpuuse/cpuuse.c,
libmisc/dumpbuf/dumpbuf.c, libmisc/fsmount/fsmount.c,
libmisc/monitor/mon-command.c, libmisc/monitor/mon-config.c,
libmisc/monitor/mon-dname.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c,
libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-mpci.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/mon-task.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/stackchk/check.c, libmisc/untar/untar.c: Use
fprintf(stdout,...) instead of printf.
* libmisc/serdbg/serdbgcnf.h: Include <rtems/serdbg.h> instead of
<serdbg.h>
* libmisc/serdbg/termios_printk_cnf.h: Include <rtems/termios_printk.h>
instead of <termios_printk.h>.
* libmisc/Makefile.am: Install serdbg.h, serdbgcnf.h,
termios_printk.h, termios_printk_cnf.h to $(includedir)/rtems.
* libmisc/serdbg/serdbg.c: Include <rtems/serdbg.h> instead of
<serdbg.h>.
* libmisc/serdbg/serdbgio.c: Include <rtems/serdbg.h> instead of
<serdbg.h>.
* libmisc/serdbg/termios_printk.c: Include <rtems/termios_printk.h>
* libmisc/dummy/dummy.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* libblock/include/rtems/bdbuf.h: Include <rtems/chain.h> instead of <chain.h>.
* libblock/include/rtems/ide_part_table.h: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/malloc.c: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/mount.c: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/unmount.c: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs.h: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs_directory.c: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs_load_tar.c: Include <rtems/chain.h> instead of <chain.h>.
* sapi/include/confdefs.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* sapi/include/confdefs.h: Include <rtems/console.h> instead of <console.h>.
* libfs/src/imfs/imfs_load_tar.c: Include <rtems/imfs.h> instead of <imfs.h>.
* libmisc/shell/cmds.c: Include <rtems/imfs.h> instead of <imfs.h>.
* libmisc/fsmount/fsmount.c: Include <rtems/imfs.h> instead of <imfs.h>.
* sapi/include/confdefs.h: Include <rtems/imfs.h> instead of <imfs.h>.
* itron/src/can_wup.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/chg_pri.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/dis_dsp.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ena_dsp.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/eventflags.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/exd_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ext_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/fmempool.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/frsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/get_tid.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itronintr.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itronsem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itrontime.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/mbox.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/mboxtranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/msgbuffer.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/msgbuffertranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/network.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/port.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/prcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/prcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/preq_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/psnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rel_wai.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rot_rdq.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sig_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/slp_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/snd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/snd_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sta_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sus_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sysmgmt.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/task.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ter_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/trcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/trcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/tslp_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/tsnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/twai_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/vmempool.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/wai_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/wup_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/rtems/config.h: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/confdefs.h: Include <rtems/itron.h> instead of <itron.h>.
* sapi/src/itronapi.c: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/confdefs.h: Include <rtems/rtc.h> instead of <rtc.h>.
* sapi/include/confdefs.h: Include <rtems/timerdrv.h> instead of <timerdrv.h>.
* libmisc/capture/capture-cli.c, libmisc/capture/capture.c,
libmisc/capture/capture.h, libmisc/cpuuse/cpuuse.c,
libmisc/devnull/devnull.c, libmisc/fsmount/fsmount.h,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-dname.c,
libmisc/monitor/mon-driver.c, libmisc/monitor/mon-extension.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-prmisc.c, libmisc/monitor/mon-queue.c,
libmisc/monitor/mon-server.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/monitor/symbols.h,
libmisc/mw-fb/mw_uid.c, libmisc/rtmonuse/rtmonuse.c,
libmisc/serdbg/serdbg.h, libmisc/serdbg/serdbgio.c,
libmisc/serdbg/termios_printk.c, libmisc/serdbg/termios_printk.h,
libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/stackchk/check.c,
libmisc/stackchk/internal.h: Convert to using c99 fixed size types.
* libmisc/shell/cmds.c: Remove warning.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* ChangeLog: Merge-in libmisc/ChangeLog, librpc/ChangeLog.
* libmisc/ChangeLog, librpc/ChangeLog: Remove.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* Makefile.am: Include compile.am again. Misc fixes.
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* Makefile.am: Build lib*$(LIB_VARIANT).a instead of
$(ARCH)/lib*.a.
* Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Cosmetics.
PR 540/rtems_misc
* cpuuse/cpuuse.c, rtmonuse/rtmonuse.c: Correct object name printing.
PR 531/rtems_misc
* rtmonuse/rtmonuse.c, stackchk/check.c: Correct indexing.
* Makefile.am: Add $(dirstamp) to compilation rules.
Fix misc. typos.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* Makefile.am: Reformat.
* capture/Makefile.am: Remove.
* cpuuse/Makefile.am: Remove.
* devnull/Makefile.am: Remove.
* dummy/Makefile.am: Remove.
* dumpbuf/Makefile.am: Remove.
* fsmount/Makefile.am: Remove.
* monitor/Makefile.am: Remove.
* mw-fb/Makefile.am: Remove.
* rtmonuse/Makefile.am: Remove.
* serdbg/Makefile.am: Remove.
* shell/Makefile.am: Remove.
* stackchk/Makefile.am: Remove.
* untar/Makefile.am: Remove.
* Makefile.am: Merge-in the Makefile.ams above.
* wrapup/Makefile.am: Remove.
* wrapup/.cvsignore: Remove.
* capture/config.h: Remove.
* capture/Makefile.am: Remove config.h.
* cpuuse/config.h: Remove.
* cpuuse/Makefile.am: Remove config.h.
* devnull/config.h: Remove.
* devnull/Makefile.am: Remove config.h.
* dummy/config.h: Remove.
* dummy/Makefile.am: Remove config.h.
* dumpbuf/config.h: Remove.
* dumpbuf/Makefile.am: Remove config.h.
* monitor/config.h: Remove.
* monitor/Makefile.am: Remove config.h.
* mw-fb/config.h: Remove.
* mw-fb/Makefile.am: Remove config.h.
* rtmonuse/config.h: Remove.
* rtmonuse/Makefile.am: Remove config.h.
* serdbg/config.h: Remove.
* serdbg/Makefile.am: Remove config.h.
* shell/config.h: Remove.
* shell/Makefile.am: Remove config.h.
* stackchk/config.h: Remove.
* stackchk/Makefile.am: Remove config.h.
* untar/config.h: Remove.
* untar/Makefile.am: Remove config.h.
* capture/capture-cli.c: Reflect new rtems_monitor_command_arg_t.
PR 495/rtems_misc
* capture/capture-cli.c, monitor/mon-command.c, monitor/mon-config.c,
monitor/mon-monitor.c, monitor/mon-object.c, monitor/mon-symbols.c,
monitor/monitor.h, shell/cmds.c: Move to making libmisc 16/32 bit
clean.
