PR 1694/shell
* libmisc/shell/main_setenv.c: Address memory leak identified by
Coverity.
* libmisc/shell/main_date.c: Use snprintf() not sprintf().
* libmisc/monitor/mon-symbols.c: Fix length of buffer passed to
strncpy() so there is room for a NULL terminator.
Coverity Id 169
* libmisc/stackchk/check.c: Readd line accidentally deleted between
1.67 and 1.68.
Coverity Id 163
* libmisc/stackchk/check.c: Adjust conditional compilation.
* libmisc/untar/untar.c: Return if open fails.
Use ssize_t for read() return value.
* libmisc/fb/fb.h: Add constants for buffer modes.
* libmisc/stackchk/check.c: If this port does not allocate the
interrupt stack, then it must always be a thread stack. Do not
include code to print the interrupt stack information.
* libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.c: Now supports
both pax and GNU tar created tar files.
* libcsupport/src/privateenv.c, libmisc/cpuuse/cpuusagereport.c,
posix/Makefile.am, posix/include/rtems/posix/key.h,
posix/src/keycreate.c, posix/src/keydelete.c,
score/src/iterateoverthreads.c: Since removing ITRON, the loop over
all APIs for tasks has a path that cannot be reached. Either modify
the code or mark tests for NULL as RTEMS_DEBUG.
* posix/src/keyfreememory.c: New file.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libcsupport/include/rtems/libio_.h: Removed
rtems_filesystem_mount_table_control.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c libcsupport/src/statvfs.c,
libcsupport/src/unmount.c, libmisc/shell/main_mount.c: Documentation.
Removed rtems_filesystem_mounts_first() and
rtems_filesystem_mounts_next(). Added
rtems_filesystem_mount_iterate(). Changed return type of
rtems_filesystem_iterate(). Removed rtems_filesystem_nodes_equal().
* libmisc/dumpbuf/dumpbuf.c, libmisc/dumpbuf/dumpbuf.h: Add const.
* libmisc/stackchk/check.c: More clean up and coverage improvements..
* libmisc/stackchk/check.c: Clean up to improve coverage.
PR 1559/misc
Coverity Id 16
* libmisc/monitor/mon-editor.c: Fix buffer overflow.
* libmisc/shell/print-ls.c, libmisc/shell/main_msdosfmt.c:
Include <inttypes.h>.
Misc. 64bit-compatibility fixes.
* include/rtems/tar.h, libcsupport/include/tar.h: Remove.
* configure.ac: Require toolchain to provide tar.h.
* libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.h:
Use <tar.h> instead of <rtems/tar.h>.
PR 1524/filesystem
* libcsupport/src/rtems_mkdir.c: New file.
* libcsupport/src/Makefile.am: Reflect change above.
* libcsupport/include/rtems/libio.h: Added rtems_mkdir().
* libmisc/fsmount/fsmount.h, libmisc/fsmount/fsmount.c,
libblock/src/bdpart-mount.c, libnetworking/rtems/mkrootfs.h,
libnetworking/rtems/mkrootfs.c, libfs/src/pipe/pipe.c: Use
rtems_mkdir(). Removed rtems_fsmount_create_mount_point() and
rtems_rootfs_mkdir().
* libcsupport/include/rtems/libio_.h: Declare
* libcsupport/include/rtems/libio.h: Removed
rtems_filesystem_table_first(), rtems_filesystem_table_next() and
rtems_filesystem_table_node_t declarations. Declare
rtems_per_filesystem_routine, rtems_filesystem_iterate() and
rtems_filesystem_get_mount_handler().
* libcsupport/src/mount.c: Added rtems_filesystem_mounts_first() and
rtems_filesystem_mounts_next(). Simplify mount(). Removed
rtems_filesystem_mount_table_control_init. Use
* libcsupport/src/mount-mgr.c: Removed rtems_filesystem_mounts_first() and
rtems_filesystem_mounts_next(). Added rtems_filesystem_iterate() and
rtems_filesystem_get_mount_handler(). Use rtems_libio_lock() and
rtems_libio_unlock();
* sapi/include/confdefs.h, libmisc/shell/main_mount.c: Update for
mount API changes.
* libmisc/shell/print-ls.c: Remove (long) cast of st_ino.
* libcsupport/Makefile.am: Add mount-mgr.c.
* libcsupport/src/mount-mgr.c: New.
* include/rtems/fs.h: Added rtems_filesystem_location_mount.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New
mount interface. It is similar to Linux.
* libcsupport/include/rtems/libio_.h: Remove the
init_fs_mount_table call.
* libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use
the new mount call. Remove setting the root node in the global
pathloc. Mount does this now.
* libcsupport/src/privateenv.c: Remove the hack to set the root
mount table entry in the environment.
* libcsupport/src/unmount.cL Free the target string.
* libblock/src/bdpart-mount.c: New mount API.
* libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c,
libfs/src/imfs/miniimfs_init.c,
libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h,
libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h,
libnetworking/rtems/tftp.h: New mount_h API.
* libfs/src/devfs/devfs_eval.c: Local include of extern ops.
* libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount
me call and fixed the initialisation to happen when mounting.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount
filesystem files.
* libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to
the new mount table values.
* libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c,
libmisc/shell/main_mount_tftp.c: Removed.
* libmisc/shell/main_mount.c: Use the new mount API. Also access
the file system table for the file system types.
* libnetworking/lib/tftpDriver.c: Updated to the new mount
API. Fixed to allow mounting from any mount point. Also can now
have more than file system mounted.
* sapi/include/confdefs.h: Add file system configuration support.
PR 1531/newlib:
* libmisc/shell/fts.c:
Add local copy of ALIGN().
* libmisc/shell/fts.c: Cast to uintptr_t instead of long for better
16bit target compliance.
* libmisc/stringto/stringto_template.h: Remove warning.
* libmisc/shell/fts.c (fts_pow2): Rebase fts_pow2 on
SIZEOF_SIZE_T * CHAR_BIT.
to print addresses.
* libmisc/stackchk/check.c: Remove bogus casts.
Use PRIxPTR to printk pointers.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h: Add const
to fix warning. Spacing.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/monitor.h: Add reset
command.
* libmisc/shell/shell_makeargs.c: Fix bugs introduced by patch
attempting to add quoted arguments.
* ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c,
httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c,
libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c,
libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c,
libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c,
libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c,
libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_init.c, libnetworking/libc/res_query.c,
libnetworking/rtems/rtems_mii_ioctl.c,
score/src/objectgetnameasstring.c: Readdress use of ctype methods per
recommendation from D.J. Delorie on the newlib mailing list. We
should pass an unsigned char into these methods.
* ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c,
httpd/websuemf.c, libblock/src/diskdevs.c,
libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c,
score/src/objectgetnameasstring.c: Fix warnings for ctype methods.
* libmisc/shell/shell_makeargs.c: Fix warnings.
PR 1496/shell
* libmisc/shell/shell_makeargs.c: Add support for quoted arguments.
* libmisc/Makefile.am: Remove duplicate file from list.
* libmisc/shell/shell_script.c: Fix typo.
* libmisc/shell/main_msdosfmt.c, libmisc/shell/shellconfig.h: Fix
the alias as I did understand how it worked.
* libfs/src/dosfs/msdos_format.c: Test for a block device.
