The holder field is enough to determine if a mutex is locked or not.
This leads also to better error status codes in case a
rtems_semaphore_release() is done for a mutex without having the
ownership.
We can use the holder pointer to get the identifier if necessary.
The thread deletion is now supported on SMP.
This change fixes the following PRs:
PR1814: SMP race condition between stack free and dispatch
PR2035: psxcancel reveals NULL pointer access in _Thread_queue_Extract()
The POSIX cleanup handler are now called in the right context (should be
called in the context of the terminating thread).
http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_09.html
Add a user extension the reflects a thread termination event. This is
used to reclaim the Newlib reentrancy structure (may use file
operations), the POSIX cleanup handlers and the POSIX key destructors.
Use posix keys for current shell environment instead of task variables. With
this patch the shell needs one posix-key and one posix-key-value-pair
configured.
Update documentation for the shell.
Adapt samples/fileio:
- Add necessary objects.
- Add login function and custom device name for better testing of the shell.
Print the uptime and difference in nanoseconds to the previous
record in the ctrace output. For example:
0:00:59.474927121 14760 0a01000c TNTD 235 235 CREATED_BY
0:00:59.474927418 297 0a010012 /dev 235 235 CREATED
0:00:59.474930799 3381 0a01000c TNTD 235 235 STARTED_BY
0:00:59.474931105 306 0a010012 /dev 235 235 STARTED
0:00:59.475072297 141192 0a01000c TNTD 235 235 SWITCHED_OUT
Use the new API to get the uptime in nanoseconds and update the capture
engine.
The capture did not work due to changes in the workspace allocator.
The engine now scans all existing tasks when enabled and does any
allocations then.
Fixed a bug in the ctset commandi in the CLI.
Updated the capture engine to use 64bit nanosec timestamps.
Fixed the CLI showing the stack usage.
Control the help command break with the SHELL_LINES evironment variable
where the numeric value is the number of lines to break on. If the
value is 0 the output is not broken. The default is 16 lines.
Add shell documentation for the help command.
It looks like the paths that use tval are if 0'ed for RTEMS.
Making all conditional on __rtems__ including the declaration.
Upcast multiplication to 64-bit integer arithmetic.
Check the return value from mkdir instead of failing silently.
1063857 Unchecked return value from library
In case the length of cwd path plus the userScriptName exceeds
PATH_MAX (255), the strncat calls will overflow scriptFile. Also
check for getcwd failure.
Stops a resource leak in the event that the system cannot malloc
Add and use _Per_CPU_Get_by_index() and _Per_CPU_Get_index(). Add
_Per_CPU_Send_interrupt(). This avoids direct access of
_Per_CPU_Information.
FIXME: This area needs proper locking.
TOD_MILLISECONDS_TO_TICKS().
application visible API.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
Move implementation specific parts of tasks.h and tasks.inl into new
header file tasksimpl.h. The tasks.h contains now only the application
visible API.
Move implementation specific parts of region.h and region.inl into new
header file regionimpl.h. The region.h contains now only the
Move implementation specific parts of part.h and part.inl into new
header file partimpl.h. The part.h contains now only the application
visible API.
Move implementation specific parts of event.h, event.inl, eventset.h and
eventset.inl into new header file eventimpl.h. The event.h contains now
only the application visible API.
Move implementation specific parts of attr.h and attr.inl into new
header file attrimpl.h. The attr.h contains now only the application
visible API.
Move implementation specific parts of extension.h and extension.inl into
new header file extensionimpl.h. The extension.h contains now only the
Move implementation specific parts of watchdog.h and watchdog.inl into
new header file watchdogimpl.h. The watchdog.h contains now only the
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
Move implementation specific parts of message.h and message.inl into new
header file messageimpl.h. The message.h contains now only the
Move implementation specific parts of sem.h and sem.inl into new header
file semimpl.h. The sem.h contains now only the application visible
API.
Rename in rtems_smp_get_processor_count(). Always provide
<rtems/score/smp.h> and <rtems/rtems/smp.h>. Add
_SMP_Get_processor_count(). This function will be a compile time
constant defined to be one on uni-processor configurations. This allows
iterations over all processors without overhead on uni-processor
configurations.
