Include files now installed as <rtems/*.h>.
it work.
This makes the headings line up above the columns a little better.
Now that it's so easy to include/exclude the stack check code I find
myself adding it to all my `debug' targets.
enclose.
unsigned numbers.
proper include files added.
from the application code, this file required more visibility than
is given by default to application code.
system exit.
like signal dispatching.
correct Information block.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
+ variable length messages
+ named devices
+ debug monitor
