path: root/cpukit/libmisc (follow)
* 2004-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-231-741/+0
| | | | | * ChangeLog: Merge-in libmisc/ChangeLog, librpc/ChangeLog. * libmisc/ChangeLog, librpc/ChangeLog: Remove.
* Cleanup ChangeLog.Ralf Corsepius2004-01-231-308/+228
* 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-192-2/+8
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-0/+9
| | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-30/+22
| | | | * Makefile.am: Include compile.am again. Misc fixes.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-22/+45
| | | | | * Makefile.am: Add libs to CLEANFILES Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* 2004-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-092-100/+96
| | | | | * Makefile.am: Build lib*$(LIB_VARIANT).a instead of $(ARCH)/lib*.a.
* 2004-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-072-181/+129
| | | | * Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-17/+19
| | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-112-12/+17
| | | | * Makefile.am: Cosmetics.
* 2003-12-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-113-18/+55
| | | | | PR 540/rtems_misc * cpuuse/cpuuse.c, rtmonuse/rtmonuse.c: Correct object name printing.
* 2003-12-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-113-2/+7
| | | | | PR 531/rtems_misc * rtmonuse/rtmonuse.c, stackchk/check.c: Correct indexing.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-012-53/+71
| | | | | * Makefile.am: Add $(dirstamp) to compilation rules. Fix misc. typos.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-302-36/+46
| | | | * Makefile.am: Add $(dirstamp) to preinstallation rules.
* 2003-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-282-18/+113
| | | | * Makefile.am: Reformat.
* 2003-11-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2815-561/+290
| | | | | | | | | | | | | | | | | * capture/Makefile.am: Remove. * cpuuse/Makefile.am: Remove. * devnull/Makefile.am: Remove. * dummy/Makefile.am: Remove. * dumpbuf/Makefile.am: Remove. * fsmount/Makefile.am: Remove. * monitor/Makefile.am: Remove. * mw-fb/Makefile.am: Remove. * rtmonuse/Makefile.am: Remove. * serdbg/Makefile.am: Remove. * shell/Makefile.am: Remove. * stackchk/Makefile.am: Remove. * untar/Makefile.am: Remove. * Makefile.am: Merge-in the Makefile.ams above.
* 2003-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-284-50/+7
| | | | | | * wrapup/Makefile.am: Remove. * wrapup/.cvsignore: Remove. * Makefile.am: Reflect changes above.
* 2003-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2025-83/+65
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * capture/config.h: Remove. * capture/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * cpuuse/config.h: Remove. * cpuuse/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * devnull/config.h: Remove. * devnull/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * dummy/config.h: Remove. * dummy/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * dumpbuf/config.h: Remove. * dumpbuf/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * monitor/config.h: Remove. * monitor/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * mw-fb/config.h: Remove. * mw-fb/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * rtmonuse/config.h: Remove. * rtmonuse/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * serdbg/config.h: Remove. * serdbg/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * shell/config.h: Remove. * shell/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * stackchk/config.h: Remove. * stackchk/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir). * untar/config.h: Remove. * untar/Makefile.am: Remove config.h. AM_CPPFLAGS += -I$(top_builddir).
* 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-212-16/+20
| | | | * capture/capture-cli.c: Reflect new rtems_monitor_command_arg_t.
* 2003-09-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2003-09-269-67/+82
| | | | | | | | PR 495/rtems_misc * capture/capture-cli.c, monitor/mon-command.c, monitor/mon-config.c, monitor/mon-monitor.c, monitor/mon-object.c, monitor/mon-symbols.c, monitor/monitor.h, shell/cmds.c: Move to making libmisc 16/32 bit clean.
* *** empty log message ***Ralf Corsepius2003-09-221-1/+1
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-225-18/+22
| | | | | | | | | | | * monitor/monitor.h: Add rtems_monitor_commands[] (Illegally applied by shell/). Remove ifdef(__mips64) (Make broken code visible again). * monitor/mon-command.c: Add several ifndef RTEMS_UNIX to avoid warnings. * monitor/mon-monitor.c: Remove RTEMS_CPU_HAS_16_BIT_ADDRESSES (Make broken code visible again). * shell/cmds.c: Remove local decls of rtems_monitor_commands[].
* 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-194-8/+13
| | | | | | | * monitor/monitor.h: Remove STREQ, STNEQ (pollute namespace), RTEMS_MONITOR_PROMPT (pollutes namespace, useless). * monitor/mon-command.c: Add RTEMS_MONITOR_PROMPT. * monitor/mon-monitor.c: Apply private version of STREQ.
* 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-195-8/+21
| | | | | | | | * monitor/symbols.h: Convert to private header. * monitor/monitor.h: Don't include symbols.h. Add forward decls. for symbols from symbols.h. * monitor/Makefile.am: Don't install symbols.h. * monitor/mon-symbols.c: Include "symbols.h".
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0417-16/+25
| | | | | | | | | * cpuuse/cpuuse.c, cpuuse/cpuuse.h, devnull/devnull.c, devnull/devnull.h, dummy/dummy.c, dumpbuf/dumpbuf.c, dumpbuf/dumpbuf.h, fsmount/fsmount.c, fsmount/fsmount.h, serdbg/serdbgio.c, serdbg/termios_printk.c, stackchk/check.c, stackchk/internal.h, stackchk/stackchk.h, untar/untar.c, untar/untar.h: URL for license changed.
* 2003-08-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-142-23/+17
| | | | | | | | | PR 408/filesystem * cpuuse/cpuuse.c: Added sync() service. As part of adding this service, the new RTEMS service rtems_iterate_over_all_threads() was also added. This new service makes it easier to iterate over all the tasks/threads in a system and perform an action on them. This change is to use the new thread iteration service.
* 2003-08-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-142-4/+7
| | | | * fsmount/Makefile.am: Fix path to automake-includes.
* 2003-08-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-132-0/+6
| | | | * fsmount/.cvsignore: New file.
* 2003-08-06 Thomas Doerfler<Thomas.Doerfler@imd-systems.de>Jennifer Averett2003-08-068-2/+345
| | | | | | | | PR 369/filesystem * Makefile.am, shell/cmds.c, wrapup/Makefile.am: sample application to show the use of the DOSFS functions * fsmount/Makefile.am, fsmount/README, fsmount/fsmount.c, fsmount/fsmount.h: New files.
* 2003-08-05 Till Strauman <strauman@slac.stanford.edu>Jennifer Averett2003-08-052-25/+20
| | | | | PR 436/rtems_misc * monitor/mon-monitor.c: monitor registered commands list manipulation bugs
* CleanupRalf Corsepius2003-07-081-12/+0
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0828-121/+170
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac. * capture/config.h: New. * capture/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * cpuuse/config.h: New. * cpuuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * devnull/config.h: New. * devnull/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * dummy/config.h: New. * dummy/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * dumpbuf/config.h: New. * dumpbuf/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * monitor/config.h: New. * monitor/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * mw-fb/config.h: New. * mw-fb/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * rtmonuse/config.h: New. * rtmonuse/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * serdbg/config.h: New. * serdbg/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * shell/config.h: New. * shell/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * stackchk/config.h: New. * stackchk/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * untar/config.h: New. * untar/Makefile.am: Add config.h. Reflect having merged configure.ac into ../configure.ac. * wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-0831-0/+175
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * capture/capture-cli.c: Add config-header support. * capture/capture.c: Add config-header support. * cpuuse/cpuuse.c: Add config-header support. * devnull/devnull.c: Add config-header support. * dummy/dummy.c: Add config-header support. * dumpbuf/dumpbuf.c: Add config-header support. * monitor/mon-command.c: Add config-header support. * monitor/mon-config.c: Add config-header support. * monitor/mon-dname.c: Add config-header support. * monitor/mon-driver.c: Add config-header support. * monitor/mon-extension.c: Add config-header support. * monitor/mon-itask.c: Add config-header support. * monitor/mon-manager.c: Add config-header support. * monitor/mon-monitor.c: Add config-header support. * monitor/mon-mpci.c: Add config-header support. * monitor/mon-object.c: Add config-header support. * monitor/mon-prmisc.c: Add config-header support. * monitor/mon-queue.c: Add config-header support. * monitor/mon-server.c: Add config-header support. * monitor/mon-symbols.c: Add config-header support. * monitor/mon-task.c: Add config-header support. * mw-fb/mw_fb.c: Add config-header support. * mw-fb/mw_uid.c: Add config-header support. * rtmonuse/rtmonuse.c: Add config-header support. * serdbg/serdbg.c: Add config-header support. * serdbg/serdbgio.c: Add config-header support. * serdbg/termios_printk.c: Add config-header support. * shell/cmds.c: Add config-header support. * stackchk/check.c: Add config-header support. * untar/untar.c: Add config-header support.
* 2003-07-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-072-1/+5
| | | | * configure.ac: Remove RTEMS_BSP from RTEMS_CHECK_MULTIPROCESSING.
* 2003-06-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-06-042-1/+5
| | | | * stackchk/check.c: Removed warnings.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-04-172-2/+4
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-112-1/+4
* Merger from rtems-4-6-branch.Ralf Corsepius2003-02-282-33/+102
* 2003-02-14 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-02-142-1/+6
| | | | | PR 352/rtems_misc * shell/shell.c: make rtems_shell main task an FP enabled task.
* 2003-01-27 Dan Smisko <dan@balanced.com>Joel Sherrill2003-01-272-1/+7
| | | | | | * stackchk/check.c: Fix problem where _Objects_Get_information() will dereference a null pointer when checking the interrupt stack. If there's something at 0, you may be ok at run time but it is wrong.
* 2003-01-27 Dan Smisko <dan@balanced.com>Joel Sherrill2003-01-272-2/+6
| | | | * monitor/mon-command.c: Correct two potential NULL references.
* 2002-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-252-2/+6
| | | | * configure.ac: Fix tests for GCC.
* 2002-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-2415-25/+77
| | | | | | | | | | | | | | | | | | | | | * configure.ac: Add check for weak function attribute. Remove AM_CONDITIONAL([RTEMS_LIBSHELL]. Add AM_CONDITIONAL(LIBSHELL), AM_CONDITIONAL(LIBSERDBG). * capture/Makefile.am: Use *.a instead of *-tmp.a. * cpuuse/Makefile.am: Use *.a instead of *-tmp.a. * devnull/Makefile.am: Use *.a instead of *-tmp.a. * dummy/Makefile.am: Use *.a instead of *-tmp.a. * dumpbuf/Makefile.am: Use *.a instead of *-tmp.a. * monitor/Makefile.am: Use *.a instead of *-tmp.a. * mw-fb/Makefile.am: Use *.a instead of *-tmp.a. * rtmonuse/Makefile.am: Use *.a instead of *-tmp.a. * serdbg/Makefile.am: Use *.a instead of *-tmp.a. Build iff LIBSERDBG is true. * shell/Makefile.am: Use *.a instead of *-tmp.a. Build iff LIBSHELL is true. * stackchk/Makefile.am: Use *.a instead of *-tmp.a. * untar/Makefile.am: Use *.a instead of *-tmp.a. * wrapup/Makefile.am: Reflect changes above.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-1214-41/+32
| | | | | | | | | | | | | | | | | * configure.ac: Require autoconf-2.57+automake-1.7.2. * capture/Makefile.am: Eliminate C_O_FILES. * cpuuse/Makefile.am: Ditto. * devnull/Makefile.am: Ditto. * dummy/Makefile.am: Ditto. * dumpbuf/Makefile.am: Ditto. * monitor/Makefile.am: Ditto. * rtmonuse/Makefile.am: Ditto. * serdbg/Makefile.am: Ditto. * shell/Makefile.am: Ditto. * stackchk/Makefile.am: Ditto. * untar/Makefile.am: Ditto. * mw-fb/Makefile.am: Eliminate C_O_FILES. Eliminate SRCS.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-1216-59/+80
| | | | | | | | | | | | | | | | | | | | | | | Moving libmisc from rtems/c/src to rtems/cpukit. * Makefile.am: Reflect new path. * configure.ac: Reflect new path. Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP. Remove RTEMS_PROJECT_ROOT. * capture/Makefile.am: Reflect new path. Remove OBJS from all-local. * cpuuse/Makefile.am: Ditto. * devnull/Makefile.am: Ditto. * dummy/Makefile.am: Ditto. * dumpbuf/Makefile.am: Ditto. * monitor/Makefile.am: Ditto. * mw-fb/Makefile.am: Ditto. * rtmonuse/Makefile.am: Ditto. * serdbg/Makefile.am: Ditto. * shell/Makefile.am: Ditto. * stackchk/Makefile.am: Ditto. * untar/Makefile.am: Ditto. * wrapup/Makefile.am: Reflect new path.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-102-1/+4
| | | | * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-1014-13/+16
| | | | | | | | | | | | | | | | * capture/Makefile.am: Don't include @RTEMS_BSP@.cfg. * cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg. * devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg. * dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg. * dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg. * monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg. * mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg. * rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg. * serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg. * shell/Makefile.am: Don't include @RTEMS_BSP@.cfg. * stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg. * untar/Makefile.am: Don't include @RTEMS_BSP@.cfg. * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-12-032-11/+27
| | | | * stackchk/check.c: Better handling of task name.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-152-1/+8
| | | | * monitor/mon-commands.c: Removed warnings for RTEMS_UNIX.
* 2002-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-147-7/+34
| | | | | | | | | | * capture/Makefile.am: Remove AUTOMAKE_OPTIONS. * serdbg/Makefile.am: Remove AUTOMAKE_OPTIONS. * serdbg/serdbgio.c: Add #include <unistd.h>. * shell/Makefile.am: Add RTEMS_LIBSHELL conditional. * wrapup/Makefile.am: Add RTEMS_LIBSHELL conditional. * configure.ac: Check for stdio assignments. Add RTEMS_LIBSHELL conditional.
