proper include files added.
from the application code, this file required more visibility than
is given by default to application code.
system exit.
like signal dispatching.
correct Information block.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
+ variable length messages
+ named devices
+ debug monitor
