PR 1331/networking
* libmisc/shell/shell.c, telnetd/check_passwd.c, telnetd/telnetd.c,
telnetd/telnetd.h: Improve comments and explanation of options to
rtems_telnetd_initialize. Add extra newline to login sequence from
shell.
* libmisc/shell/utils-cp.c: Do not put a 64K buffer on the stack.
* libmisc/monitor/mon-monitor.c, rtems/include/rtems/rtems/types.h: Do
not have fp context type when no hardware or software floating point
is available.
* libmisc/shell/main_cp.c, libmisc/shell/main_ls.c,
libmisc/shell/main_mv.c, libmisc/shell/main_netstats.c,
libmisc/shell/main_rm.c, libmisc/shell/shell_script.c: Newlib >
1.16.0 requires __need_getopt_newlib to be defined to get visibility
on the reentrancy extensions.
PR 1328/cpukit
* libmisc/shell/main_mdump.c, libmisc/shell/main_mwdump.c: Fix printing
of more than 256 bytes.
* libmisc/shell/main_mallocinfo.c, libmisc/shell/main_wkspaceinfo.c:
Include information on whether C Program Heap and RTEMS Workspace are
separate.
* libcsupport/include/rtems/libio_.h, libcsupport/src/libio_sockets.c,
libfs/src/dosfs/fat.h, libfs/src/dosfs/msdos.h,
libfs/src/imfs/deviceio.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-object.c, libmisc/monitor/mon-symbols.c,
libmisc/monitor/monitor.h, libmisc/stackchk/internal.h,
rtems/inline/rtems/rtems/part.inl, score/include/rtems/system.h,
score/include/rtems/score/bitfield.h, score/src/mpci.c,
score/src/objectextendinformation.c, score/src/threadmp.c: Remove
extraneous spaces.
* libmisc/shell/shell.c: FALSE accidentally changed to true in switch
to bool type.
* libmisc/Makefile.am, libmisc/shell/shell.c, libmisc/shell/shell.h:
Split out rtems_shell_get_prompt() so it can be overridden by the
user.
* libmisc/shell/shell_getprompt.c: New file.
* libmisc/shell/internal.h: Don't include "config.h".
Adjust header guard.
* libmisc/dummy/dummy.c: Add missing initializers.
* score/src/threadinitialize.c: Change type of loop counter.
* libcsupport/src/error.c, libmisc/dummy/dummy.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c: Add 0 for missing initializers.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/scandir.c,
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-monitor.c,
libmisc/serdbg/serdbg.c, libmisc/serdbg/serdbg.h,
libnetworking/netinet/in_cksum_powerpc.h, shttpd/compat_rtems.h: Fix
warnings.
* libmisc/monitor/monitor.h, rtems/include/rtems/rtems/tasks.h,
score/include/rtems/score/thread.h, score/src/threadreset.c,
score/src/threadrestart.c, score/src/threadstart.c: New type
Thread_Entry_numeric_type for numeric arguments in thread entry
functions with at least one numeric argument.
* libcsupport/src/_rename_r.c: Fixed return code bug. Add a check
to see if the 'to' path was a directory and removed the directory.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added the mv command.
* libmisc/shell/main_mv.c, libmisc/shell/pathnames-mv.h: New.
PR 741/networking
* libmisc/dummy/dummy.c: Add dummy network configuration.
* rtems/include/rtems/rtems/sem.h, rtems/src/semobtain.c:
Changed option set type to rtems_option.
* score/src/objectgetinfo.c: Check return value of
_Objects_API_maximum_class().
* libmisc/monitor/mon-mpci.c, libmisc/monitor/monitor.h,
rtems/include/rtems/rtems/message.h, rtems/src/msgmp.c,
rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, score/include/rtems/score/coremsg.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/thread.h,
score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgseize.c,
score/src/coremsgsubmit.c:
Removed parameters of _Message_queue_Allocate(). Changed option set
type to rtems_option. Changed type of maximum message and packet size
to size_t. Changed the input buffer type for message send functions to
"const void *". Changed the pointer to the second return argument in
the thread wait information to a union. This union can contain a
pointer to an immutable or a mutable object. This is somewhat fragile.
An alternative would be to add a third pointer for immutable objects,
but this would increase the structure size.
* libmisc/shell/main_rm.c: sys/mount.h is not available when networking
is disabled but luckily it is not even needed to compile.
* ChangeLog, libmisc/monitor/mon-object.c: Add mising RTEMS_POSIX_API
conditional.
* libblock/Makefile.am: Removed src/show_bdbuf.c.
* libblock/src/show_bdbuf.c: Removed.
* libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c:
Rewritten the bdbuf code. Remove pre-emption disable, score
access, fixed many bugs and increased performance.
* libblock/include/rtems/blkdev.h: Added
RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up
comments. Added block and user fields to the sg buffer
request. Move to rtems_* namespace.
* libblock/include/rtems/diskdevs.h,
cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a
capabilities field for drivers. Change rtems_disk_lookup to
rtems_disk_obtain to match the release call. You do not lookup and
release a disk, you obtain and release a disk.
* libblock/include/rtems/ide_part_table.h,
libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c:
* libblock/include/rtems/nvdisk.h: Formatting change.
* libblock/src/blkdev.c: Move to rtems_* namespace. Change
rtems_disk_lookup to rtems_disk_obtain
* libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new
support for the block number in the scatter/grather request
struct. This allows non-continuous buffer requests for those
drivers that can support increasing performance.
* libblock/src/nvdisk.c: Move to rtems_* namespace. Removed
warnings. Added better error checking. Fixed some comments.
* libblock/src/ramdisk.c: Move to rtems_* namespace. Added some
trace functions to help debugging upper layers. Use the new
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains
API. Removed temporary hack and changed
set_errno_and_return_minus_one to
rtems_set_errno_and_return_minus_one. Move fat_buf_access from
header and stopped it being inlined. Updated to libblock changes.
* libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use
new chains API. Removed temporary hack and changed
rtems_set_errno_and_return_minus_one. Updated to libblock changes.
* libmisc/Makefile.am: Add new ls and rm command files.
* libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h,
libmisc/shell/filemode.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c,
libmisc/shell/vis.c, shell/vis.h: New.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Fixed the usage call bug.
* libmisc/shell/main_blksync.c: Updated to the new block IO ioctl
command.
* libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD
commands with more features.
* score/src/coremutex.c: Fix the strick order mutex code.
* libmisc/shell/shell.c: Change shell tasks mode to be timeslice
and no ASR.
* sapi/include/confdefs.h: Change ata_driver_task_priority to
rtems_ata_driver_task_priority. Add the new BD buf cache
parameters with defaults.
* score/src/interr.c: Do not return if the CPU halt call returns.
* libmisc/shell/shell_script.c: Clean up code for command not found
including the error message.
* libmisc/monitor/mon-extension.c, libmisc/monitor/mon-itask.c,
libmisc/monitor/mon-part.c, libmisc/monitor/mon-prmisc.c,
libmisc/monitor/mon-queue.c, libmisc/monitor/mon-region.c,
libmisc/monitor/mon-sema.c, libmisc/monitor/mon-task.c,
libmisc/monitor/monitor.h: Use rtems_object_get_name() instead of
internal routine. This makes it possible to also print string names
of POSIX objects. Adjust task report to realign since we can have
longer names.
* libmisc/monitor/mon-monitor.c, libmisc/monitor/mon-object.c,
libmisc/monitor/monitor.h, libmisc/shell/main_chmod.c,
libmisc/shell/main_tty.c, libmisc/shell/main_umask.c,
libmisc/shell/main_whoami.c: Add pthread command to monitor when
POSIX is enabled. Remove include of rtems/monitor.h from files not
related.
* libmisc/shell/shellconfig.h, libmisc/stackchk/stackchk.h: Fix typos.
* libmisc/shell/shell.c, libmisc/shell/shell.h: New argument sequence
for rtems_shell_init(). This makes it possible to run the shell
forever or invoke it from a program as a subroutine, have a user
enter commands, and wait for it to exit.
* libmisc/shell/shell_script.c: Remove unused function.
* libmisc/monitor/mon-prmisc.c, rtems/include/rtems/rtems/attr.h:
Review association tables in monitor.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, libmisc/monitor/mon-task.c,
rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c,
rtems/src/ratemonperiod.c, score/include/rtems/score/thread.h,
score/src/threaddispatch.c, score/src/threadinitialize.c,
score/src/threadtickletimeslice.c: Add typedefs for cpu usage and
period timing statistics. Also renamed related variables and
structure members so they are the same whether you are using
nanosecond (e.g. struct timespec) or ticks (e.g. uint32_t)
granularity. This lays the groundwork for future cleanup.
* libmisc/shell/shell_getchar.c: Minor change so dropping connection
while at prompt results in shell logging out and connection still
being available.
* libmisc/shell/shell.c: Minor change so dropping connection during
login prompt results in connection still being available.
* libmisc/dummy/dummy.c, sapi/include/confdefs.h: Add checks for
application configuration errors. If any POSIX objects or a POSIX
init thread is configured without POSIX being configure, then error
out. Similarly for ITRON. Add
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER configuration
parameter so the application has to explicitly configure the Clock
driver in or out if the Timer driver is not configured. Also verify
RTEMS was built for multiprocessing, if the user tries to configure a
multiprocessing application.
* libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/shell/shell_script.c: Add support to echo the commands to
stdout. This is useful with the -v script option to show commands
as the run. Also added support to chdir to the directory the task
invoking the script is in.
libmisc/shell/utils-cp.c: Update tro the latest FreeBSD version.
* libcsupport/Makefile.am, libcsupport/src/fchown.c: Add fchown
support.
* libmisc/shell/shell.c: Copy the cmd line to a buffer to split
into argv parts. Was using the command line history buffer so the
history was being corrupted.
* libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/nfsclient/src/nfs.c: Remove CEXP references. CEXP is
external to RTEMS and even if in the cpukit it should not cross
reference in this way.
* libmisc/shell/shell_getchar.c: New. Taken from the monitor.
* libmisc/Makefile.am: Add shell_getchar.c and clean up a little
in the shell area.
* libmisc/shell/shell.c, libmisc/shell/shell.h: Add line editting
support.
* libmisc/shell/cmds.c: Directly register the command structure to
avoid unnecessary duplication of static strings. We know best this
time.
