- Add 'rtems_shell_init_environment()' so a user can create the
shell environment without needing to run a shell.
- Move 'rtems_shell_lookup_topic', 'rtems_shell_can_see_cmd',
and 'rtems_shell_execute_cmd' from the internal interface to
the public interface.
Closes #3104.
The problem exists for both RTEMS untar implementations and their
variants: Untar_FromMemory(), Untar_FromFile() and rtems_tarfs_load().
If filesystem object already exists at extracted directory path
then if it is directory, creation is ignored. Attempt
to delete/unlink object and make directory is tried for other cases.
This simple approach problem reported in ticket fixes #2413.
Behavior follows GNU tar and BSD tar practice for directories
but much more work is required to achieve full semantics
of the full featured tar implementation still.
Compiling dumpbuf.c causes the following warning to be issued:
warning: pointer targets in passing argument 1 of 'snprintf' differ in signedness [-Wpointer-sign]
This happens because line_buffer is declared as unsigned.
Closes #2411.
I also used the 'n' versions of the string functions, #define'd magic numbers
and added a few comments.
Updates #2405.
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
This was obsolete and broken based upon recent time keeping changes.
Thie build option was previously enabled by adding
USE_TICKS_FOR_STATISTICS=1 to the configure command line.
This propagated into the code as preprocessor conditionals
using the __RTEMS_USE_TICKS_FOR_STATISTICS__ conditional.
The cpuuse top command now supports the current load where the list of
tasks is ordered based on the current load rather than the total cpu usage.
This lets you see what is using the processor at any specific instance.
The ability to sort on a range of thread values is now supported.
Added memory usage stats for unified and separate workspace and C heaps as
well as displaying the allocated stack space.
Added a few more command keys to refresh the display, show all tasks in the
system, control the lines display and a scrolling mode that does not clear
the display on each refresh.
Removed support for tick kernel builds. The tick support in the kernel is to
be removed.
A thread join is twofold. There is one thread that exists and an
arbitrary number of threads that wait for the thread exit (one-to-many
relation). The exiting thread may want to wait for a thread that wants
to join its exit (STATES_WAITING_FOR_JOIN_AT_EXIT in
_POSIX_Thread_Exit()). On the other side we need a thread queue for all
the threads that wait for the exit of one particular thread
(STATES_WAITING_FOR_JOIN in pthread_join()).
Update #2035.
The rtrace command interfaces to the RTEMS Trace Linker's trace
buffering data allowing users to capture and report trace data.
The printing of 64bit diff's for the timestamp did not work on ARM
so I have changed this to 32bit. A 32bit nano-second diff between
events should be more than enough time.
Print '____' for POSIX thread output.
Add rtems_test_parallel_get_task_id().
These were remnants of pre-Doxygen comment style.
Deprecate Classic API Notepads. Mark task_set/get_note() with
the deprecated attribute, and also mark the notepads field.
Replace disable with enable option for notepads in confdefs.h,
and make notepads disabled by default. The previous option
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
will emit a compile-time warning. A new option
CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
on notepads, but it also will emit a compile-time warning
to indicate that notepads are deprecated.
Closes #2265
This value depends on the _Heap_Initialize() call sequence and carries
no useful information.
The Coverity issue was an ignored return value from a read()
in a loop which should have been a seek() since the data
read was ignored.
The file itself needed reformatting to conform to RTEMS style.
The use of __DATE__ prevents reproducible builds.
