that contains:
* Removes MKLIB
handling)
converted to automake.
to convert the libmisc directory from Makefile.in to Makefile.am.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
are a dummy for linking programs together when you are primarily
concerned with tricking another package into building.
This may grow into something which could help link programs on
the command line by having a default start sequence.
c/src/lib/libmisc to c/src/libmisc.
avoid cyclic dependencies generated when moving packages to the
top level.
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
defined.
Include files now installed as <rtems/*.h>.
it work.
This makes the headings line up above the columns a little better.
Now that it's so easy to include/exclude the stack check code I find
myself adding it to all my `debug' targets.
enclose.
unsigned numbers.
proper include files added.
from the application code, this file required more visibility than
is given by default to application code.
system exit.
