1999-01-31 | New files added to ease debugging. | Joel Sherrill | 2 | -0/+96 | |
1998-12-01 | Include files now installed as <rtems/*.h>. | Joel Sherrill | 2 | -2/+2 | |
1998-12-01 | Removed unused file. | Joel Sherrill | 1 | -1/+1 | |
Include files now installed as <rtems/*.h>. | |||||
1998-11-23 | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 2 | -0/+14 | |
it work. | |||||
1998-04-27 | Cosmetic fix from Eric Norum: | Joel Sherrill | 1 | -1/+1 | |
This makes the headings line up above the columns a little better. Now that it's so easy to include/exclude the stack check code I find myself adding it to all my `debug' targets. | |||||
1998-04-15 | Fixed so this would compile without warning. | Joel Sherrill | 1 | -0/+2 | |
1998-04-15 | Stack check now initialized as part of initial extension set. | Joel Sherrill | 3 | -0/+65 | |
1998-04-06 | Increased stack space of the monitor task. | Joel Sherrill | 1 | -1/+1 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 5 | -5/+5 | |
1998-01-30 | Corrected Linux port for glibc2 | Joel Sherrill | 1 | -1/+2 | |
1998-01-23 | Solaris port updates from Chris Johns | Joel Sherrill | 1 | -6/+6 | |
1998-01-16 | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 3 | -3/+3 | |
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | |||||
1997-12-07 | Fixed indexing bug reported by Phil Wilshire. | Joel Sherrill | 1 | -1/+1 | |
1997-11-29 | Removed warnings. | Joel Sherrill | 2 | -1/+6 | |
1997-10-21 | Fixed a number of warnings regarding comparisons between signed and | Joel Sherrill | 4 | -9/+9 | |
unsigned numbers. | |||||
1997-10-21 | Fixed endian problem in printing object names. | Joel Sherrill | 1 | -0/+5 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 5 | -10/+10 | |
1997-09-21 | Cleaned up as part of adding the Monitor test. | Joel Sherrill | 17 | -27/+21 | |
1997-09-16 | updated | Joel Sherrill | 1 | -4/+11 | |
1997-08-22 | Removed assert condition when not initialized or there are 0 periods. | Joel Sherrill | 1 | -0/+5 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 5 | -25/+25 | |
of switching to the modified GNU GPL. | |||||
1997-04-09 | printing task names now instead of id numbers | Joel Sherrill | 1 | -3/+16 | |
1997-04-09 | new files. | Joel Sherrill | 5 | -0/+415 | |
1997-04-07 | changed signed int to unsigned int to eliminate a warning. | Joel Sherrill | 1 | -1/+1 | |
1996-09-18 | pointer arithmetic reworked to be more portable | Joel Sherrill | 1 | -8/+8 | |
1996-09-18 | casts added to numerous arguments, prototypes corrected, and | Joel Sherrill | 10 | -22/+27 | |
proper include files added. | |||||
1996-05-28 | added initial posix configuration support | Joel Sherrill | 2 | -11/+12 | |
1996-04-22 | updates from Tony Bennett | Joel Sherrill | 18 | -169/+125 | |
1996-03-06 | As part of reducing visibility into rtems and hiding the .inl files | Joel Sherrill | 7 | -0/+7 | |
from the application code, this file required more visibility than is given by default to application code. | |||||
1996-02-13 | removed post switch extension | Joel Sherrill | 1 | -1/+0 | |
1996-01-19 | Added condition compile flag for dump of stack usage information on | Joel Sherrill | 1 | -0/+10 | |
system exit. | |||||
1996-01-17 | Update from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 7 | -76/+75 | |
1996-01-15 | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 3 | -16/+27 | |
1995-09-29 | all targets compile .. tony's patches in place | Joel Sherrill | 5 | -31/+40 | |
1995-09-19 | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 2 | -4/+4 | |
single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | |||||
1995-09-11 | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 7 | -31/+64 | |
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | |||||
1995-08-28 | Added unused priority ceiling parameter to rtems_semaphore_create. | Joel Sherrill | 2 | -5/+5 | |
Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core. | |||||
1995-08-23 | Moved _Thread_Information -> _RTEMS_tasks_Information. | Joel Sherrill | 2 | -9/+19 | |
Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it. | |||||
1995-08-23 | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1 | -2/+2 | |
both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. | |||||
1995-08-18 | Modified references to task name. | Joel Sherrill | 1 | -2/+3 | |
1995-08-18 | + Added object type field to object id. | Joel Sherrill | 1 | -3/+7 | |
+ Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information | |||||
1995-08-17 | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 18 | -223/+3174 | |
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | |||||
1995-07-12 | Ada95, gnat, go32 | Joel Sherrill | 1 | -1/+1 | |
1995-06-07 | incorporated mc68302 support | Joel Sherrill | 1 | -1/+1 | |
1995-05-24 | Fully tested on all in-house targets | Joel Sherrill | 1 | -0/+1 | |
