path: root/cpukit/libmisc/uuid (follow)
* gettimeofday: Add restrict keywordBryan Dunsmore2013-11-291-1/+1
* uuid: make integer arithmetic conversion explicitGedare Bloom2013-09-051-1/+1
| | | | Upcast multiplication to 64-bit integer arithmetic.
* 2011-10-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-021-3/+16
| | | | | * libmisc/uuid/gen_uuid.c: Introduce PRIutime_t, SCNutime_t and "utime_t" for 64bit-time_t support.
* Add HAVE_CONFIG_H guards around #include "config.h".Ralf Corsepius2010-03-279-2/+20
* 2010-03-12 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-03-121-1/+1
| | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c, httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c, libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c, libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c, libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c, libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c, libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_init.c, libnetworking/libc/res_query.c, libnetworking/rtems/rtems_mii_ioctl.c, score/src/objectgetnameasstring.c: Readdress use of ctype methods per recommendation from D.J. Delorie on the newlib mailing list. We should pass an unsigned char into these methods.
* 2010-03-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-03-111-1/+1
| | | | | | | | | | | | * ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c, libblock/src/diskdevs.c, libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c, libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c, libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_network.c, libnetworking/rtems/rtems_mii_ioctl.c, score/src/objectgetnameasstring.c: Fix warnings for ctype methods.
* Whitespace removal.Ralf Corsepius2009-11-291-1/+1
* Add HAVE_CONFIG_H guard.Ralf Corsepius2009-10-221-1/+4
| | | | | | Include <limits.h>. Shift pid_t's by (sizeof(pid_t)*CHAR_BIT)>>1 instead of hard-coded 16 to permit building on non 16bit-int targets.
* Add cast to uint32_t to allow 16bit shift on 16bit-int targets.Ralf Corsepius2009-10-221-1/+1
* 2009-05-06 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-05-061-0/+5
| | | | | * libmisc/uuid/gen_uuid.c, libnetworking/lib/syslog.c, telnetd/telnetd.c: Fixed warnings.
* added cpukit/libmisc/uuid/READMEThomas Doerfler2009-05-061-0/+14
* new filesThomas Doerfler2009-05-0514-0/+1573
