- Remove the macro defines and the need for tmacro.h by remapping the
symbols using ld's wrap option.
- Remove FLUSH_OUTPUT, it was empty.
- Move rtems_test_exit to libmisc/testsupport as a function.
Update #3199.
Add a tests enum and move all test banner test to the library in libmisc.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
Update #3056.
Update #2825.
Determine worker index via the current processor index to get consistent
job runs with respect to the cache topology.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
Rename RTEMS_PRINTF_ATTRIBUTE() into RTEMS_PRINTFLIKE() (similar to
<sys/cdefs.h> __printflike()) and move it to <rtems/score/basedefs.h>.
Demonstrate that a read-modify-write atomic operation may be necessary
on some archtitectures to observe the latest value written.
of this patch set.
Add rtems_test_parallel_get_task_id().
