Conflicts occured durning this patch and modifications in
the repo were favored over the patch.
http://www.google-melange.com/gci/task/view/google/gci2012/7959228
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* libmisc/stringto/stringtounsignedchar.c,
libmisc/stringto/stringtounsignedint.c: Reformat range check.
* libmisc/Makefile.am: Add stringto/stringtolongdouble.c.
* libmisc/stringto/stringtolongdouble.c: New.
* libmisc/stringto/stringto.h: Rename header-guard.
Add rtems_string_to_long_double.
* libmisc/stringto/stringtoint.c: Reformat range check.
Add check for result==0.
* libmisc/stringto/stringtofloat.c: Reformat range check.
Add check for result = -HUGE_VALF.
* libmisc/stringto/stringtodouble.c: Reformat range check.
Add check for result = -HUGE_VAL.
* libmisc/stringto/stringtolonglong.c: Reformat range check.
c99 portability improvements. Add check for result==0.
* libmisc/stringto/stringtounsignedlonglong.c: Reformat range check.
* libmisc/stringto/stringtounsignedlong.c: Reformat range check.
* libmisc/stringto/stringtolong.c: Reformat range check.
* libmisc/Makefile.am: Remove stringto/stringto_template.h.
* libmisc/stringto/stringto_template.h: Remove.
* libmisc/stringto/stringtodouble.c,
libmisc/stringto/stringtofloat.c: Rework.
* libmisc/stringto/stringtolong.c,
libmisc/stringto/stringtolonglong.c,
libmisc/stringto/stringtounsignedlong.c,
Rework.
* libmisc/stringto/stringtoint.c,
libmisc/stringto/stringtounsignedint.c,
libmisc/stringto/stringtounsignedchar.c: Rework.
* libmisc/stringto/stringtopointer.c: Rework.
* libmisc/stringto/stringto_template.h: Remove warning.
* libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h:
Tidy up as part of adding new test.
* libmisc/Makefile.am, libmisc/shell/main_chmod.c,
libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c,
libmisc/shell/main_mfill.c, libmisc/shell/main_mmove.c,
libmisc/shell/main_msdosfmt.c, libmisc/shell/main_mwdump.c,
libmisc/shell/main_sleep.c, libmisc/shell/main_umask.c,
libmisc/shell/shell_script.c, libmisc/stringto/stringto.h,
libmisc/stringto/stringto_template.h: Convert return type from bool
to rtems_status_code and add rtems_string_to_pointer. Perform
associated clean up and changes for return type change.
* libmisc/stringto/stringtopointer.c: New file.
libmisc/shell/shell.h, libmisc/shell/shell_script.c,
libmisc/stringto/stringto_template.h: Convert all shell code to use
stringto.h mehods with better error checking.
* libmisc/shell/str2int.c: Removed.
* Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am:
Add the stringto family of string to number converters. These are
error checking wrappers for the strtoXXX methods and do their best to
return false if the conversion failed. The error checking required
for this is tedious and error prone. Hence better to have in a family
of helper routines.
* libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h,
libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c,
libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c,
libmisc/stringto/stringtounsignedlonglong.c: New files.
