path: root/cpukit/libmisc/stringto/stringto_template.h (follow)
* 2009-07-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-231-11/+30
| | | | | | | | | | | | | * libmisc/Makefile.am, libmisc/shell/main_chmod.c, libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c, libmisc/shell/main_mmove.c, libmisc/shell/main_msdosfmt.c, libmisc/shell/main_mwdump.c, libmisc/shell/main_sleep.c, libmisc/shell/main_umask.c, libmisc/shell/shell_script.c, libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h: Convert return type from bool to rtems_status_code and add rtems_string_to_pointer. Perform associated clean up and changes for return type change. * libmisc/stringto/stringtopointer.c: New file.
* 2009-07-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-221-1/+1
| | | | | | | | | | | | * libmisc/Makefile.am, libmisc/shell/main_chmod.c, libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c, libmisc/shell/main_mmove.c, libmisc/shell/main_msdosfmt.c, libmisc/shell/main_mwdump.c, libmisc/shell/main_sleep.c, libmisc/shell/main_umask.c, libmisc/shell/shell.h, libmisc/shell/shell_script.c, libmisc/stringto/stringto_template.h: Convert all shell code to use stringto.h mehods with better error checking. * libmisc/shell/str2int.c: Removed.
* 2009-07-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-221-0/+107
* Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am: Add the stringto family of string to number converters. These are error checking wrappers for the strtoXXX methods and do their best to return false if the conversion failed. The error checking required for this is tedious and error prone. Hence better to have in a family of helper routines. * libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h, libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c, libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c, libmisc/stringto/stringtolonglong.c, libmisc/stringto/stringtounsignedchar.c, libmisc/stringto/stringtounsignedint.c, libmisc/stringto/stringtounsignedlong.c, libmisc/stringto/stringtounsignedlonglong.c: New files.
