* libmisc/Makefile.am, libmisc/shell/main_chmod.c,
libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c,
libmisc/shell/main_mfill.c, libmisc/shell/main_mmove.c,
libmisc/shell/main_msdosfmt.c, libmisc/shell/main_mwdump.c,
libmisc/shell/main_sleep.c, libmisc/shell/main_umask.c,
libmisc/shell/shell_script.c, libmisc/stringto/stringto.h,
libmisc/stringto/stringto_template.h: Convert return type from bool
to rtems_status_code and add rtems_string_to_pointer. Perform
associated clean up and changes for return type change.
* libmisc/stringto/stringtopointer.c: New file.
* Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am:
Add the stringto family of string to number converters. These are
error checking wrappers for the strtoXXX methods and do their best to
return false if the conversion failed. The error checking required
for this is tedious and error prone. Hence better to have in a family
of helper routines.
* libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h,
libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c,
libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c,
libmisc/stringto/stringtolonglong.c,
libmisc/stringto/stringtounsignedchar.c,
libmisc/stringto/stringtounsignedint.c,
libmisc/stringto/stringtounsignedlong.c,
libmisc/stringto/stringtounsignedlonglong.c: New files.
