* cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am,
monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am,
untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am:
Include compile.am.
that contains:
* Removes MKLIB
handling)
to convert the libmisc directory from Makefile.in to Makefile.am.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
This makes the headings line up above the columns a little better.
Now that it's so easy to include/exclude the stack check code I find
myself adding it to all my `debug' targets.
system exit.
like signal dispatching.
correct Information block.
