* | score: Rename interrupt stack symbols | Sebastian Huber | 2018-11-08 | 1 | -1/+1 |
| | | | | | | | | | | | | | Rename * _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin, * _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and * _Configuration_Interrupt_stack_size in _ISR_Stack_size. Move definitions to <rtems/score/isr.h>. The new names are considerable shorter and in the right namespace. Update #3459. | ||||
* | stackchk: Fix interrupt stack preparation | Sebastian Huber | 2018-09-24 | 1 | -9/+11 |
| | | | | | | We have to prepare the interrupt stack of each processor. Update #3459. | ||||
* | stackchk: Improve support for interrupt stacks | Sebastian Huber | 2018-09-21 | 1 | -29/+84 |
| | | | | | | | | Prepare the interrupt stack which may be used by the boot processor as initialization stack with the stack sanity pattern. Check the interrupt stack of the current processor in the thread begin and switch extension. Update #3459. | ||||
* | stackchk: Remove heap hack | Sebastian Huber | 2018-09-21 | 1 | -7/+1 |
| | | | | | It is now guranteed that threads do not use a freed stack during termination. | ||||
* | Rework initialization and interrupt stack support | Sebastian Huber | 2018-06-27 | 1 | -2/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Statically initialize the interrupt stack area (_Configuration_Interrupt_stack_area_begin, _Configuration_Interrupt_stack_area_end, and _Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the interrupt stack area in a special section ".rtemsstack.interrupt". Let BSPs define the optimal placement of this section in their linker command files (e.g. in a fast on-chip memory). This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the low level initialization code has all information available via global symbols. This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define superfluous, since the interrupt stacks are allocated by confdefs.h for all architectures. There is no need for BSP-specific linker command file magic (except the section placement), see previous ARM linker command file as a bad example. Remove _CPU_Install_interrupt_stack(). Initialize the hardware interrupt stack in _CPU_Initialize() if necessary (e.g. m68k_install_interrupt_stack()). The optional _CPU_Interrupt_stack_setup() is still useful to customize the registration of the interrupt stack area in the per-CPU information. The initialization stack can reuse the interrupt stack, since * interrupts are disabled during the sequential system initialization, and * the boot_card() function does not return. This stack resuse saves memory. Changes per architecture: arm: * Mostly replace the linker symbol based configuration of stacks with the standard <rtems/confdefs.h> configuration via CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND mode stack is still defined via linker symbols. These modes are rarely used in applications and the default values provided by the BSP should be sufficient in most cases. * Remove the bsp_processor_count linker symbol hack used for the SMP support. This is possible since the interrupt stack area is now allocated by the linker and not allocated from the heap. This makes some configure.ac stuff obsolete. Remove the now superfluous BSP variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp. bfin: * Remove unused magic linker command file allocation of initialization stack. Maybe a previous linker command file copy and paste problem? In the start.S the initialization stack is set to a hard coded value. lm32, m32c, mips, nios2, riscv, sh, v850: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. m68k: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. powerpc: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. * Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt stack on BSPs using the shared linkcmds.base (replacement for REGION_RWEXTRA). sparc: * Remove the hard coded initialization stack. Use the interrupt stack for the initialization stack on the boot processor. This saves 16KiB of RAM. Update #3459. | ||||
* | stackchk: Add SMP support | Sebastian Huber | 2018-06-20 | 1 | -37/+64 |
| | | | | | | | | | | | | Check the interrupt stacks of all processors. Set up the interrupt stack of the current processor for high water testing in the thread begin extension. This must be done after multi-threading started, since the initialization stacks may reuse the interrupt stacks. Disable thread dispatching in SMP configurations to prevent thread migration. Writing to the interrupt stack is only safe if done from the corresponding processor in thread context. Update #3459. | ||||
* | stackchk: Refactor Stack_check_Dump_threads_usage | Sebastian Huber | 2018-06-20 | 1 | -60/+49 |
* | stackchk: Remove dead code | Sebastian Huber | 2018-06-20 | 1 | -24/+0 |
* | Remove make preinstall | Chris Johns | 2018-01-25 | 1 | -139/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254. | ||||
* | libmisc/stackchk/check.c: correct formatting of stack pointers in ↵ | Andrei Chichak | 2017-12-07 | 1 | -2/+2 |
| | | | | | | | | Stack_check_Dump_threads_usage Pointers were being printed as 0x<decimal> rather than 0x<hex>. I altered the formatting define used to give the correct formatting. Close #3240 | ||||
* | Complete STACK_CHECKER_EXTENSION. Fixes #2889 | Stavros Passas | 2017-01-30 | 1 | -0/+1 |
* | score: Add and use _Thread_Get_name() | Sebastian Huber | 2017-01-13 | 1 | -33/+27 |
| | | | | Update #2858. | ||||
* | Rename is_internal to always_set_to_false | Sebastian Huber | 2016-12-12 | 1 | -1/+1 |
| | | | | Update #2825. | ||||
* | rtems: Add rtems_task_iterate() | Sebastian Huber | 2016-11-02 | 1 | -24/+22 |
| | | | | Update #2423. | ||||
* | stackchk: Fix stack checker thread initialization | Sebastian Huber | 2016-09-08 | 2 | -30/+4 |
| | | | | | | | Commit 0fd6f25507fbea5f4892b71b58837cdda17856b4 relaxed the thread begin extension execution environment. This broke the stack check which only partially initialized the stack pattern in its create extension. Move the part of the begin extension to the create extension. | ||||
* | stackchk: Use a const pattern to check | Sebastian Huber | 2016-09-08 | 1 | -89/+42 |
* | stackchk: Remove superfluous internal header file | Sebastian Huber | 2016-09-08 | 2 | -102/+25 |
* | Move printer initialization to separate header | Sebastian Huber | 2016-06-22 | 1 | -0/+1 |
| | | | | | | The RTEMS print user need to know nothing about a particular printer implementation. In particular get rid of the <stdio.h> include which would be visible via <rtems.h>. | ||||
* | libmisc/stackchk: Fix printk warnings. | Chris Johns | 2016-06-03 | 1 | -6/+6 |
* | libmisc: Fix printk format warnings. | Chris Johns | 2016-05-25 | 1 | -2/+2 |
* | cpukit, testsuite: Add rtems_printf and rtems_printer support. | Chris Johns | 2016-05-25 | 2 | -22/+19 |
| | | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work. | ||||
* | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | 2015-10-26 | 1 | -3/+3 |
* | basedefs.h: Add and use RTEMS_NO_RETURN | Sebastian Huber | 2015-10-26 | 1 | -1/+1 |
* | libmisc: Simplify <rtems/stackchk.h> | Sebastian Huber | 2015-06-26 | 2 | -1/+2 |
| | | | | | Drop the <rtems/score/percpu.h> include since this file exposes a lot of implementation details. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 3 | -3/+3 |
* | libmisc: Use _Thread_Get_executing() | Sebastian Huber | 2013-07-22 | 1 | -4/+5 |
* | libmisc: Doxygen Clean Up Task #1 | Ayush Awasthi | 2013-01-04 | 2 | -28/+38 |
| | | | | | Conflicts occured durning this patch and modifications in the repo were favored over the patch. | ||||
* | Header File Doxygen Enhancement Task #2 | Mathew Kallada | 2012-12-28 | 1 | -3/+7 |
* | libmisc: Doxygen Enhancement Task #1 | Mathew Kallada | 2012-12-21 | 2 | -9/+20 |
* | score: Add RTEMS_FATAL_SOURCE_STACK_CHECKER | Sebastian Huber | 2012-11-15 | 1 | -1/+4 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 4 | -10/+0 |
* | 2011-12-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-12-06 | 1 | -2/+2 |
| | | | | | * libmisc/stackchk/check.c: Make Stack_check_Initialize, Stack_check_Dump_threads_usage static. | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | 2011-06-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-06-17 | 1 | -8/+15 |
| | | | | | | | | | | | | | | | | | | | * libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h, posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h, score/include/rtems/score/apiext.h, score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/timespec.h, score/include/rtems/score/timestamp.h, score/include/rtems/score/timestamp64.h, score/include/rtems/score/tod.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h: Make @brief formatting more consistent. * score/include/rtems/score/rbtree.h: Also reformat. | ||||
* | 2011-02-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-23 | 1 | -2/+5 |
| | | | | | * libmisc/devnull/devnull.h, libmisc/stackchk/stackchk.h: Fix header guard. Add missing includes. | ||||
* | 2010-11-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-11-04 | 1 | -4/+3 |
| | | | | | | * libmisc/stackchk/check.c: Make compile again. * sapi/src/io.c, score/src/heap.c: Address dead assignment issues found by clang. | ||||
* | 2010-11-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-11-04 | 1 | -10/+16 |
| | | | | | * libmisc/stackchk/check.c: Address casting issue highlighted by clang. There was no need for an intermediate cast to a structure pointer. | ||||
* | 2010-08-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-08-25 | 1 | -0/+1 |
| | | | | | | Coverity Id 169 * libmisc/stackchk/check.c: Readd line accidentally deleted between 1.67 and 1.68. | ||||
* | 2010-08-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-08-25 | 1 | -2/+1 |
| | | | | | Coverity Id 163 * libmisc/stackchk/check.c: Adjust conditional compilation. | ||||
* | 2010-08-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-08-02 | 1 | -10/+17 |
| | | | | | | * libmisc/stackchk/check.c: If this port does not allocate the interrupt stack, then it must always be a thread stack. Do not include code to print the interrupt stack information. | ||||
* | 2010-07-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-07-04 | 1 | -1/+0 |
| | | | | | | | | | | | | | | | | * libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c, libcsupport/src/__times.c, libcsupport/src/libio_init.c, libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c, libcsupport/src/mount.c, libcsupport/src/rewinddir.c, libcsupport/src/seekdir.c, libcsupport/src/telldir.c, libcsupport/src/unmount.c, libfs/src/dosfs/fat.c, libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c, libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c, libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c, libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c, telnetd/telnetd.c: Remove include of assert.h when it is not needed. | ||||
* | 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-23 | 1 | -10/+15 |
| | | | | * libmisc/stackchk/check.c: More clean up and coverage improvements.. | ||||
* | 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-23 | 1 | -22/+28 |
| | | | | * libmisc/stackchk/check.c: Clean up to improve coverage. | ||||
* | 2010-04-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-10 | 1 | -11/+10 |
| | | | | | * libmisc/stackchk/check.c: Remove bogus casts. Use PRIxPTR to printk pointers. | ||||
* | 2010-01-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-01-19 | 1 | -2/+2 |
| | | | | * libmisc/stackchk/check.c: Fix warning. | ||||
* | 2010-01-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-01-18 | 1 | -10/+9 |
| | | | | | | | | | | Coverity Id 12 Coverity Id 13 Coverity Id 14 Coverity Id 15 * libmisc/stackchk/check.c: Rewrote loop to avoid possible buffer overruns when the pattern area size is not a multiple of 16. There were no current ports impacted by this but better to be safe. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -3/+3 |
* | 2009-09-09 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Joel Sherrill | 2009-09-09 | 1 | -1/+8 |
| | | | | | | | | | * score/include/rtems/score/heap.h, score/inline/rtems/score/heap.inl, score/src/heapallocate.c, score/src/heap.c, score/src/heapextend.c, score/src/heapresizeblock.c, score/src/heapwalk.c: Documenation. Simplified block resize. Improved heap walk. Changed heap layout to avoid a special case for _Heap_Is_used() and _Heap_Is_free(). * libmisc/stackchk/check.c: Update for heap API changes. | ||||
* | 2009-09-06 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Joel Sherrill | 2009-09-06 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/free.c, libmisc/stackchk/check.c, rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c, rtems/src/regionextend.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c, score/src/pheapallocate.c, score/src/pheapallocatealigned.c, score/src/pheapextend.c, score/src/pheapfree.c, score/src/pheapgetblocksize.c, score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c, score/src/pheapgetsize.c, score/src/pheapinit.c, score/src/pheapresizeblock.c, score/src/pheapwalk.c: Update for heap API changes. * score/include/rtems/score/apimutex.h, score/include/rtems/score/object.h: Documentation. * score/include/rtems/score/heap.h, score/include/rtems/score/protectedheap.h, score/inline/rtems/score/heap.inl, score/src/heap.c, score/src/heapallocate.c, score/src/heapallocatealigned.c, score/src/heapextend.c, score/src/heapfree.c, score/src/heapgetfreeinfo.c, score/src/heapgetinfo.c, score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c, score/src/heapwalk.c: Overall cleanup. Added boundary constraint to allocation function. More changes follow. |
