This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
Do not use the rtems_error() function since this function pulls in
exit() and abort(). The abort() function pulls in raise() which pulls
in the whole POSIX signals support. This change saves about 16KiB of
text/rodata on ARM Thumb-2 systems.
Close #3720.
The region_information_block typedef as no corresponding API. It has no
proper namespace prefix. A user can do nothing with it.
Close #3591.
Update #3375.
Update #3530.
Update #3533.
Do not discard a user provided task name in rtems_shell_init_env().
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3260.
Prepare for header file move to common include directory.
Update #3254.
Update #2132.
Update #2133.
Update #3082.
- Add 'rtems_shell_init_environment()' so a user can create the
shell environment without needing to run a shell.
- Move 'rtems_shell_lookup_topic', 'rtems_shell_can_see_cmd',
and 'rtems_shell_execute_cmd' from the internal interface to
the public interface.
Closes #3096.
Update #2833.
Provide extentions to <inttpes.h> PRIxxx constants for more POSIX types.
Start with existing definitions found in RTEMS Project owned code
in cpukit/.
updates #2983.
Update #2803.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
Update #2723.
of this patch set.
Works also with previous Newlib versions.
The rtrace command interfaces to the RTEMS Trace Linker's trace
buffering data allowing users to capture and report trace data.
This value depends on the _Heap_Initialize() call sequence and carries
no useful information.
