This was requested to be executed prior to relicensing to BSD-2.
* libmisc/shell/print-ls.c: Include "internal.h".
* libmisc/shell/pwcache.c: Make user_from_uid static.
* libmisc/shell/shell.c: Make rtems_shell_init_env,
rtems_shell_env_free, rtems_shell_line_editor,
rtems_shell_init_issue, rtems_shell_task static.
* libmisc/shell/shell_cmdset.c: Make rtems_shell_add_topic static.
* libmisc/shell/shell_makeargs.c: Include <rtems/shell.h>.
* libmisc/shell/write_file.c: Include <rtems/shell.h>.
* libmisc/Makefile.am, libmisc/shell/main_cp.c,
libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c,
libmisc/shell/main_mallocinfo.c, libmisc/shell/main_netstats.c,
libmisc/shell/main_perioduse.c, libmisc/shell/main_stackuse.c,
libmisc/shell/main_wkspaceinfo.c, libmisc/shell/print_heapinfo.c,
libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.c,
libmisc/shell/shellconfig.h, libmisc/shell/write_file.c: Add initial
capability to automatically execute a script from the filesystem. Add
echo command from NetBSD and sleep command.
* libmisc/shell/main_echo.c, libmisc/shell/main_sleep.c,
libmisc/shell/shell_script.c: New files.
* libnetworking/rtems/tftp.h: Provide a decl to the TFTP file
system opts table.
* libnetworking/rtems/ftpfs.h: Provide a decl to the FTP file
system opts table.
* libmisc/Makefile.am: Add the mount command and supporting files.
* libmisc/preinstall.am: Rebuilt.
* libmisc/shell/cat_file.c, libmisc/shell/cmds.c,
libmisc/shell/main_alias.c, libmisc/shell/main_cat.c,
libmisc/shell/main_cd.c, libmisc/shell/main_chdir.c,
libmisc/shell/main_chmod.c, libmisc/shell/main_chroot.c,
libmisc/shell/main_dir.c, libmisc/shell/main_exit.c,
libmisc/shell/main_help.c, libmisc/shell/main_id.c,
libmisc/shell/main_logoff.c, libmisc/shell/main_ls.c,
libmisc/shell/main_mallocdump.c, libmisc/shell/main_mdump.c,
libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c,
libmisc/shell/main_mkdir.c, libmisc/shell/main_mmove.c,
libmisc/shell/main_mwdump.c, libmisc/shell/main_pwd.c,
libmisc/shell/main_rm.c, libmisc/shell/main_rmdir.c,
libmisc/shell/main_stackuse.c, libmisc/shell/main_tty.c,
libmisc/shell/main_umask.c, libmisc/shell/main_whoami.c,
libmisc/shell/shell.c, libmisc/shell/shell_cmdset.c,
libmisc/shell/shell_makeargs.c, libmisc/shell/str2int.c,
libmisc/shell/write_file.c: Move all shell_* types, variables and
functions to rtems_shell_* to avoid namespace clashes with
applications. The is an RTEMS shell after all.
* libmisc/shell/shell.h, libmisc/shell/internal.h,
libmisc/shell/shellconfig.h: Move all shell_* types, variables and
applications. Add the mount command supporting types.
* libmisc/shell/main_mount.c, libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_nfs.c,
libmisc/shell/main_mount_tftp.c: New.
* libmisc/Makefile.am, libmisc/shell/cmd_help.c, libmisc/shell/cmds.c,
libmisc/shell/internal.h, libmisc/shell/shell.c,
libmisc/shell/shell.h, libmisc/shell/shellconfig.h: Command set
processing now separated from main command loop. Addition of user
commands and aliases tested. Monitor registration now explicit.
* libmisc/shell/shell_cmdset.c, libmisc/shell/shell_makeargs.c,
libmisc/shell/write_file.c: New files.
* ChangeLog, preinstall.am, libmisc/Makefile.am, libmisc/shell/cmds.c,
libmisc/shell/shell.c, libmisc/shell/shell.h: Split shell commands
into multiple files and add initial stages of command configuration.
This seems to work but the monitor commands need to be integrated
this way and the ability to configure user commands needs to be
tested.
* libmisc/shell/cat_file.c, libmisc/shell/cmd_alias.c,
libmisc/shell/cmd_cat.c, libmisc/shell/cmd_cd.c,
libmisc/shell/cmd_chdir.c, libmisc/shell/cmd_chmod.c,
libmisc/shell/cmd_chroot.c, libmisc/shell/cmd_date.c,
libmisc/shell/cmd_dir.c, libmisc/shell/cmd_exit.c,
libmisc/shell/cmd_help.c, libmisc/shell/cmd_id.c,
libmisc/shell/cmd_logoff.c, libmisc/shell/cmd_ls.c,
libmisc/shell/cmd_mallocdump.c, libmisc/shell/cmd_mdump.c,
libmisc/shell/cmd_medit.c, libmisc/shell/cmd_mfill.c,
libmisc/shell/cmd_mkdir.c, libmisc/shell/cmd_mmove.c,
libmisc/shell/cmd_mwdump.c, libmisc/shell/cmd_pwd.c,
libmisc/shell/cmd_rm.c, libmisc/shell/cmd_rmdir.c,
libmisc/shell/cmd_tty.c, libmisc/shell/cmd_umask.c,
libmisc/shell/cmd_whoami.c, libmisc/shell/internal.h,
libmisc/shell/shellconfig.c, libmisc/shell/shellconfig.h,
libmisc/shell/str2int.c: New files.
