path: root/cpukit/libmisc/shell/shellconfig.c (follow)
* Include "config.h".Ralf Corsepius2008-08-211-0/+4
* 2008-03-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-03-051-0/+3
| | | | | | | | | | | | | | | * libmisc/Makefile.am, libmisc/shell/main_cp.c, libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c, libmisc/shell/main_mallocinfo.c, libmisc/shell/main_netstats.c, libmisc/shell/main_perioduse.c, libmisc/shell/main_stackuse.c, libmisc/shell/main_wkspaceinfo.c, libmisc/shell/print_heapinfo.c, libmisc/shell/shell.c, libmisc/shell/shell.h, libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.c, libmisc/shell/shellconfig.h, libmisc/shell/write_file.c: Add initial capability to automatically execute a script from the filesystem. Add echo command from NetBSD and sleep command. * libmisc/shell/main_echo.c, libmisc/shell/main_sleep.c, libmisc/shell/shell_script.c: New files.
* 2007-12-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-12-101-0/+14
* ChangeLog, preinstall.am, libmisc/Makefile.am, libmisc/shell/cmds.c, libmisc/shell/shell.c, libmisc/shell/shell.h: Split shell commands into multiple files and add initial stages of command configuration. This seems to work but the monitor commands need to be integrated this way and the ability to configure user commands needs to be tested. * libmisc/shell/cat_file.c, libmisc/shell/cmd_alias.c, libmisc/shell/cmd_cat.c, libmisc/shell/cmd_cd.c, libmisc/shell/cmd_chdir.c, libmisc/shell/cmd_chmod.c, libmisc/shell/cmd_chroot.c, libmisc/shell/cmd_date.c, libmisc/shell/cmd_dir.c, libmisc/shell/cmd_exit.c, libmisc/shell/cmd_help.c, libmisc/shell/cmd_id.c, libmisc/shell/cmd_logoff.c, libmisc/shell/cmd_ls.c, libmisc/shell/cmd_mallocdump.c, libmisc/shell/cmd_mdump.c, libmisc/shell/cmd_medit.c, libmisc/shell/cmd_mfill.c, libmisc/shell/cmd_mkdir.c, libmisc/shell/cmd_mmove.c, libmisc/shell/cmd_mwdump.c, libmisc/shell/cmd_pwd.c, libmisc/shell/cmd_rm.c, libmisc/shell/cmd_rmdir.c, libmisc/shell/cmd_tty.c, libmisc/shell/cmd_umask.c, libmisc/shell/cmd_whoami.c, libmisc/shell/internal.h, libmisc/shell/shellconfig.c, libmisc/shell/shellconfig.h, libmisc/shell/str2int.c: New files.
