* | 2008-08-07 Chris Johns <chrisj@rtems.org> | Chris Johns | 2008-08-07 | 1 | -0/+40 |
* libcsupport/src/_rename_r.c: Fixed return code bug. Add a check to see if the 'to' path was a directory and removed the directory. * libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added the mv command. * libmisc/shell/main_mv.c, libmisc/shell/pathnames-mv.h: New. |
