* | shell: Use #include "..." for local header files | Sebastian Huber | 2018-10-09 | 1 | -1/+1 |
| | | | | Update #3375. | ||||
* | shell: Fix warnings | Sebastian Huber | 2017-02-14 | 1 | -2/+0 |
* | shell: Include <rtems/shell.h> early | Sebastian Huber | 2014-11-20 | 1 | -2/+3 |
| | | | | This avoids a conflict with the global variable defines. | ||||
* | libmisc/shell: Remove the need for -lm when linking from the ping command. | Chris Johns | 2014-10-04 | 1 | -5/+12 |
| | | | | | Remove the use of sqrt and so the need to link to -lm. Clean up some warnings. | ||||
* | shell: Add a ping command. | Chris Johns | 2014-09-16 | 1 | -0/+1976 |
The ping code is taken from a recent FreeBSD release. Some options have been tested, other not tested or do not work. This could be due to the age of our TCP/IP stack. This version of ping will not work if more than 64 file descriptors are open at once because the select FD size is 64 as set in newlib. |
