* libmisc/Makefile.am, libmisc/shell/main_chmod.c,
libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c,
libmisc/shell/main_mfill.c, libmisc/shell/main_mmove.c,
libmisc/shell/main_msdosfmt.c, libmisc/shell/main_mwdump.c,
libmisc/shell/main_sleep.c, libmisc/shell/main_umask.c,
libmisc/shell/shell_script.c, libmisc/stringto/stringto.h,
libmisc/stringto/stringto_template.h: Convert return type from bool
to rtems_status_code and add rtems_string_to_pointer. Perform
associated clean up and changes for return type change.
* libmisc/stringto/stringtopointer.c: New file.
libmisc/shell/shell.h, libmisc/shell/shell_script.c,
libmisc/stringto/stringto_template.h: Convert all shell code to use
stringto.h mehods with better error checking.
* libmisc/shell/str2int.c: Removed.
* libmisc/shell/cat_file.c, libmisc/shell/main_alias.c,
libmisc/shell/main_blksync.c, libmisc/shell/main_cat.c,
libmisc/shell/main_chdir.c, libmisc/shell/main_chmod.c,
libmisc/shell/main_chroot.c, libmisc/shell/main_cpuuse.c,
libmisc/shell/main_date.c, libmisc/shell/main_help.c,
libmisc/shell/main_id.c, libmisc/shell/main_logoff.c,
libmisc/shell/main_ls.c, libmisc/shell/main_mallocinfo.c,
libmisc/shell/main_mfill.c, libmisc/shell/main_mkdir.c,
libmisc/shell/main_mmove.c, libmisc/shell/main_mount.c,
libmisc/shell/main_mount_nfs.c, libmisc/shell/main_msdosfmt.c,
libmisc/shell/main_mwdump.c, libmisc/shell/main_perioduse.c,
libmisc/shell/main_pwd.c, libmisc/shell/main_rm.c,
libmisc/shell/main_rmdir.c, libmisc/shell/main_stackuse.c,
libmisc/shell/main_tty.c, libmisc/shell/main_umask.c,
libmisc/shell/main_unmount.c, libmisc/shell/main_whoami.c,
libmisc/shell/shell.h: Clean up done while writing documentation.
Some command improvements such as date now allows setting of the
current TOD. Often commands did not use stdout/stderr per
expectations and did not return -1 on an error.
* libmisc/shell/main_alias.c, libmisc/shell/main_blksync.c,
libmisc/shell/main_cat.c, libmisc/shell/main_cd.c,
libmisc/shell/main_date.c, libmisc/shell/main_dir.c,
libmisc/shell/main_exit.c, libmisc/shell/main_help.c,
libmisc/shell/main_mount_ftp.c, libmisc/shell/main_mount_msdos.c,
libmisc/shell/main_mount_nfs.c, libmisc/shell/main_mount_tftp.c,
libmisc/shell/shell_cmdset.c, libmisc/shell/shellconfig.h: Change
rtems_Shell_ to rtems_shell_.
* libnetworking/rtems/tftp.h: Provide a decl to the TFTP file
system opts table.
* libnetworking/rtems/ftpfs.h: Provide a decl to the FTP file
system opts table.
* libmisc/Makefile.am: Add the mount command and supporting files.
* libmisc/preinstall.am: Rebuilt.
* libmisc/shell/cat_file.c, libmisc/shell/cmds.c,
libmisc/shell/main_alias.c, libmisc/shell/main_cat.c,
libmisc/shell/main_cd.c, libmisc/shell/main_chdir.c,
libmisc/shell/main_chmod.c, libmisc/shell/main_chroot.c,
libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c,
libmisc/shell/main_dir.c, libmisc/shell/main_exit.c,
libmisc/shell/main_help.c, libmisc/shell/main_id.c,
libmisc/shell/main_logoff.c, libmisc/shell/main_ls.c,
libmisc/shell/main_mallocdump.c, libmisc/shell/main_mdump.c,
libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c,
libmisc/shell/main_mkdir.c, libmisc/shell/main_mmove.c,
libmisc/shell/main_mwdump.c, libmisc/shell/main_pwd.c,
libmisc/shell/main_rm.c, libmisc/shell/main_rmdir.c,
libmisc/shell/main_stackuse.c, libmisc/shell/main_tty.c,
libmisc/shell/main_umask.c, libmisc/shell/main_whoami.c,
libmisc/shell/shell.c, libmisc/shell/shell_cmdset.c,
libmisc/shell/shell_makeargs.c, libmisc/shell/str2int.c,
libmisc/shell/write_file.c: Move all shell_* types, variables and
functions to rtems_shell_* to avoid namespace clashes with
applications. The is an RTEMS shell after all.
* libmisc/shell/shell.h, libmisc/shell/internal.h,
libmisc/shell/shellconfig.h: Move all shell_* types, variables and
applications. Add the mount command supporting types.
* libmisc/shell/main_mount.c, libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_nfs.c,
libmisc/shell/main_mount_tftp.c: New.
* libmisc/Makefile.am, libmisc/shell/cat_file.c,
libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.h: Rename
cmd_XXX.c to main_XXX.c. Add cpuuse and stackuse commands.
* libmisc/shell/main_alias.c, libmisc/shell/main_cat.c,
libmisc/shell/main_umask.c, libmisc/shell/main_whoami.c: New files.
* libmisc/shell/cmd_alias.c, libmisc/shell/cmd_cat.c,
libmisc/shell/cmd_cd.c, libmisc/shell/cmd_chdir.c,
libmisc/shell/cmd_chmod.c, libmisc/shell/cmd_chroot.c,
libmisc/shell/cmd_date.c, libmisc/shell/cmd_dir.c,
libmisc/shell/cmd_exit.c, libmisc/shell/cmd_help.c,
libmisc/shell/cmd_id.c, libmisc/shell/cmd_logoff.c,
libmisc/shell/cmd_ls.c, libmisc/shell/cmd_mallocdump.c,
libmisc/shell/cmd_mdump.c, libmisc/shell/cmd_medit.c,
libmisc/shell/cmd_mfill.c, libmisc/shell/cmd_mkdir.c,
libmisc/shell/cmd_mmove.c, libmisc/shell/cmd_mwdump.c,
libmisc/shell/cmd_pwd.c, libmisc/shell/cmd_rm.c,
libmisc/shell/cmd_rmdir.c, libmisc/shell/cmd_tty.c,
libmisc/shell/cmd_umask.c, libmisc/shell/cmd_whoami.c: Removed.
