CID 26051: Unchecked return value from library in main_cp().
Closes #4365
CID 1255344: Unused value in copy().
Closes #4339
Update #3375.
* libmisc/shell/main_cp.c: Include "internal.h".
Make rtems_shell_main_cp non-static.
* libmisc/shell/cmds.c:
Make rtems_shell_main_monitor static.
* libmisc/shell/main_alias.c:
Make rtems_shell_rtems_main_alias static.
* libmisc/shell/main_blksync.c:
Make rtems_shell_main_blksync static.
* libmisc/shell/main_cat.c:
Make rtems_shell_main_cat static.
* libmisc/shell/main_chdir.c:
Make rtems_shell_main_chdir static.
* libmisc/shell/main_chmod.c:
Make rtems_shell_main_chmod static.
* libmisc/shell/main_chroot.c:
Make rtems_shell_main_chroot static.
Make rtems_shell_cp_exit, rtems_shell_main_cp static.
* libmisc/shell/main_cpuuse.c:
Make rtems_shell_main_cpuuse static.
* libmisc/shell/main_date.c:
Make rtems_shell_main_date static.
* libmisc/shell/main_dd.c:
Make rtems_shell_main_dd static.
* libmisc/shell/main_echo.c:
Make rtems_shell_main_echo static.
* libmisc/shell/main_getenv.c:
Make rtems_shell_main_getenv static.
* libmisc/shell/main_halt.c:
Make rtems_shell_main_halt static.
* libmisc/shell/main_cp.c, libmisc/shell/main_ls.c,
libmisc/shell/main_mv.c, libmisc/shell/main_netstats.c,
libmisc/shell/main_rm.c, libmisc/shell/shell_script.c: Newlib >
1.16.0 requires __need_getopt_newlib to be defined to get visibility
on the reentrancy extensions.
* libblock/Makefile.am: Removed src/show_bdbuf.c.
* libblock/src/show_bdbuf.c: Removed.
* libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c:
Rewritten the bdbuf code. Remove pre-emption disable, score
access, fixed many bugs and increased performance.
* libblock/include/rtems/blkdev.h: Added
RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up
comments. Added block and user fields to the sg buffer
request. Move to rtems_* namespace.
* libblock/include/rtems/diskdevs.h,
cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a
capabilities field for drivers. Change rtems_disk_lookup to
rtems_disk_obtain to match the release call. You do not lookup and
release a disk, you obtain and release a disk.
* libblock/include/rtems/ide_part_table.h,
libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c:
* libblock/include/rtems/nvdisk.h: Formatting change.
* libblock/src/blkdev.c: Move to rtems_* namespace. Change
rtems_disk_lookup to rtems_disk_obtain
* libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new
support for the block number in the scatter/grather request
struct. This allows non-continuous buffer requests for those
drivers that can support increasing performance.
* libblock/src/nvdisk.c: Move to rtems_* namespace. Removed
warnings. Added better error checking. Fixed some comments.
* libblock/src/ramdisk.c: Move to rtems_* namespace. Added some
trace functions to help debugging upper layers. Use the new
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains
API. Removed temporary hack and changed
set_errno_and_return_minus_one to
rtems_set_errno_and_return_minus_one. Move fat_buf_access from
header and stopped it being inlined. Updated to libblock changes.
* libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use
new chains API. Removed temporary hack and changed
rtems_set_errno_and_return_minus_one. Updated to libblock changes.
* libmisc/Makefile.am: Add new ls and rm command files.
* libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h,
libmisc/shell/filemode.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c,
libmisc/shell/vis.c, shell/vis.h: New.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Fixed the usage call bug.
* libmisc/shell/main_blksync.c: Updated to the new block IO ioctl
command.
* libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD
commands with more features.
* score/src/coremutex.c: Fix the strick order mutex code.
* libmisc/shell/shell.c: Change shell tasks mode to be timeslice
and no ASR.
* sapi/include/confdefs.h: Change ata_driver_task_priority to
rtems_ata_driver_task_priority. Add the new BD buf cache
parameters with defaults.
* score/src/interr.c: Do not return if the CPU halt call returns.
* libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/shell/shell_script.c: Add support to echo the commands to
stdout. This is useful with the -v script option to show commands
as the run. Also added support to chdir to the directory the task
invoking the script is in.
libmisc/shell/utils-cp.c: Update tro the latest FreeBSD version.
* libcsupport/Makefile.am, libcsupport/src/fchown.c: Add fchown
support.
* libmisc/shell/main_cp.c, libmisc/shell/main_netstats.c,
libmisc/shell/shell_script.c: Add memset() of getopt_data to
ensure it is zeroed out each time we use getopt_r().
* libmisc/shell/shell.c: Do not echo commands if input is not a tty.
This makes the scripts behave more like UNIX scripts.
* libmisc/Makefile.am, libmisc/shell/main_cp.c,
libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c,
libmisc/shell/main_mallocinfo.c, libmisc/shell/main_netstats.c,
libmisc/shell/main_perioduse.c, libmisc/shell/main_stackuse.c,
libmisc/shell/main_wkspaceinfo.c, libmisc/shell/print_heapinfo.c,
libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.c,
libmisc/shell/shellconfig.h, libmisc/shell/write_file.c: Add initial
capability to automatically execute a script from the filesystem. Add
echo command from NetBSD and sleep command.
* libmisc/shell/main_echo.c, libmisc/shell/main_sleep.c,
libmisc/shell/shell_script.c: New files.
* configure.ac: fixed bug that always enabled strict order
mutexes.
* score/inline/rtems/score/coremutex.inl: Fixed coding standard.
* score/src/coremutex.c: Add the holder's thread to the lock_mutex
list if the mutex is initialised locked.
* libnetworking/rtems/rtems_glue.c: Changed semaphore error
message to show the error is an rtems-net error.
* libmisc/monitor/mon-network.c: Removed warnings.
* telnetd/icmds.c: Changed shell_* to rtems_shell_*.
* score/Makefile.am: Fixed typo that stopped 'make tags' working.
* libmisc/shell/err.c, libmisc/shell/err.h, libmisc/shell/errx.c,
libmisc/shell/extern-cp.h, libmisc/shell/fts.c,
libmisc/shell/fts.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c, libmisc/shell/verr.c,
libmisc/shell/verrx.c, libmisc/shell/vwarn.c,
libmisc/shell/vwarnx.c, libmisc/shell/warn.c,
libmisc/shell/warnx.c: New. Ported from BSD.
* libmisc/shell/shellconfig.h: Add the cp command.
* libmisc/Makefile.am: Add the new files to the shell.
* libmisc/shell/shell.c, libmisc/shell/shell.h: Add scripting
support.
* libblock/src/flashdisk.c: Fixed disk drive count size setting
bug.
